| Fifteen15 |
 Fifteen15 World Chat Champion
 Posted: 01:46 - 09 Nov 2011 Post subject: How to downshift while blipping throttle? |
The last couple of weeks I've been trying to learn how to downshift while blipping the throttle to keep things smooth. In theory I can do it, clutch in, gas on and off, clutch out, however putting it into practice on the bike is a totally different ball game. I just can't figure it out. My bike either jerks too much (presuming I'm blipping too much with the throttle), or if it IS smooth, I'm still not sure whether I've done it right. I would ask my friends who ride but none of them blip the throttle when downshifting. I am however determined to get it right no matter how long it takes
So how did you learn how to do it? Any tips? ____________________ "Pain is weakness leaving the body, and blood makes the grass grow faster...but I'll wear my gear anyway"
| Matt06 |
 Matt06 World Chat Champion
 Posted: 01:51 - 09 Nov 2011 Post subject: |
Could of merged this question into the other gear related one.
Basically, don't use the clutch........... haha
That's the main area where you are going wrong. To 'quick shift' you don't use the clutch. Its only really worth doing if you are really on it and the timing needs to be right. ____________________ Current: MT-10, Bandit, Grom, GPZ500
Previous: YBR125, GSXR400, ZXR400, MT-03, NTV650, R6, z750, ZX6R, MT-09
| Fifteen15 |
| johnsmith222 |
 johnsmith222 World Chat Champion
| Matt06 |
 Posted: 02:04 - 09 Nov 2011 Post subject: |
So are these questions a joke? ____________________ Current: MT-10, Bandit, Grom, GPZ500
Previous: YBR125, GSXR400, ZXR400, MT-03, NTV650, R6, z750, ZX6R, MT-09 |
| johnsmith222 |
| Matt06 |
 Posted: 02:26 - 09 Nov 2011 Post subject: |
| J5 wrote: | | Matt06 wrote: | So are these questions a joke? |
I'm not too sure, but in my opinion the OP sounds very inexperienced and I think the best advice is not to overcomplicate things and just for s/he to concentrate on riding as smoothly as possible. |
Hmmmmmmm.................
You are right though, if this is genuine.
Just also thought how did this guy end up not knowing how to change gears smoothly and riding an SV650? ____________________ Current: MT-10, Bandit, Grom, GPZ500
| Frost |
 Frost World Chat Champion
 Posted: 03:17 - 09 Nov 2011 Post subject: |
Unless you're riding a shit hot 2 stroke there's no reason to blip on the down shift.
Smooth shifting can be done by by giving a little throttle as you let the clutch back out on a down shift to syncronise the engine speed tot he road speed. The amount of throttle depends on how fast you're slowing down etc.
You can also double clutch. Thats letting the clutch out in neutral before pulling it back in to change to the next gear. Doesn't work on bikes though  |
| Jim Mc |
 Jim Mc Nearly there...
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 08:58 - 09 Nov 2011 Post subject: Re: How to downshift while blipping throttle? |
This is all an opinion, it works for me, my practice tips are what I did - experiences may vary. Some may disagree with me, that is fine, tell the OP how you do it.
How I do it:
Two fingers on the brake lever, other two and thumb gripping the throttle. Apply brakes, as the bike is slowing, I blip the throttle so it raises a few k whilst slipping my fingers over the brake lever so I am braking consistently but my hand can move to actuate the throttle. At exactly the same time as I begin the blip I pull the clutch, then quickly tap down the gear and before the revs have dropped smoothly release the clutch. It should be quick and smooth. If it is jerky, the revs jump when you release the clutch and the bike slows down then you either didn't blip it enough or more likely you took too long between blipping and changing gear/releasing the clutch.
What I did to practice:
To practice, slip the clutch like you probably are doing already but do a slow blip as well, it should work exactly the same as just slipping but you can feel the bike needs to slip the clutch less for the engine and gears to mesh, you don't get the same resistance slowing you down that you get if you just slip the clutch. Gradually increase the speed at which you release the clutch and do shorter sharper blips to match. Getting it monumentally wrong can mean your back wheel locks up so don't just dump the clutch without blipping, of you slip the clutch slowly and blip to begin with you can get a feel for what works.
It is kind of covered here:
https://www.youtube.com/watch?v=L8pnaRpDU1A
Try it on deserted roads to begin with, fucking it up is unlikely but it is best to be away from others when practising new things. |
| evoboy |
 evoboy World Chat Champion
 Posted: 11:00 - 09 Nov 2011 Post subject: |
Its only really needed for when your going some and using high revs.
Mainly on Twins to stop the back wheel locking up when changing down quickly.
https://www.youtube.com/watch?v=G-A24JljUrE
^^ Can sorta see how i do (on my SlowAsFukASAKI ) it by listening to the engine revs and watching the tacho. But that is on track. It isnt really needed as such on the road. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| stonesie |
 stonesie World Chat Champion
 Posted: 11:31 - 09 Nov 2011 Post subject: |
On the SV I had to blip or the thing would either launch me forwards in a painful nuts/tank meeting or slip the back wheel, this time of year it was mainly the latter which to an inexperianced rider is butt clenching stuff.
To practice how much to blip what I did was very simmilar to DonnyBrago..
Clutch in
down 1 gear
Blip
Clutch out, but not all the way. You want it to be slipping but not too much.
Practice on quiet roads first at low speeds and once you start getting it smooth try letting the clutch all the way out, when thats smooth start speeding the whole process up into a nice slick combination...
You will get it
Biggest problem I'm having at the moment is converting to an IL4, it revs up much faster, but ive already figured out that bliping on a downshift at about 6K makes it do a double backfire  |
| robbieguy2003 |
 robbieguy2003 World Chat Champion
 Posted: 14:08 - 09 Nov 2011 Post subject: |
I think it's worth doing just to be a bit smoother. It also lets you keep the bikes weight where you want it, jerky shifting moves it around. If you're riding in the wet or on greasy roads or end up on loose chippings this stuff will help make things a little better.
I find - Shifting up;
Do the steps at the same time
Step 1 - Clutch in, Lower throttle - not off, just lower it's use
Step 2 - Gear up
Step 3 - Clutch out
Step 4 - Throttle on
Shifting Down;
Step 1 - Clutch in, Blip Throttle, Change Down
Step 2 - Clutch out - At first, do this slowly rather than dropping the clutch, take it out to biting point, then back in again slightly, then back out again, it'll give the engine/wheel speed more time if the throttle blip wasn't so precise.
Over time it'll just smooth out but it takes time. On the RR i only really do this if braking from 60mph or above and coming onto a slow roundabout or something. Otherwise I just slowly bring the clutch in and out to get the revs and let the engine settle.
Racing I think is different but i think the principle of being smooth applies, you just have to get it right more, do it quicker and at higher speeds. ____________________ Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03 |
| goto10 |
 goto10 World Chat Champion
 Posted: 14:24 - 09 Nov 2011 Post subject: Re: How to quick shift? |
| J5 wrote: | | ImNoSuperman wrote: | The last couple of weeks I've been trying to learn how to quick shift. In theory I can do it, clutch in, gas on and off, clutch out, however putting it into practice on the bike is a totally different ball game. I just can't figure it out. My bike either jerks too much (presuming I'm blipping too much with the throttle), or if it IS smooth, I'm still not sure whether I've done it right. I would ask my friends who ride but none of them quick shift. I am however determined to get it right no matter how long it takes
So how did you learn how to do it? Any tips? |
Are you reving your bike with the clutch in before shifting up?
If you want to change gear while acclerating through the gears you want to accelerate hard in 2nd, put slight pressure under your gear shifter before you want to change up, snap the throttle on and off quickly and you'll pretty much instantly be in 3rd gear and accelerating.
Although I really think you should learn how to change gear the standard way first. |
Wrong way around, he wants to know about downshifting!
I do this in a car when downshifting (heel & toe) - it's something I learnt from track days and I also find myself doing it when on the road too, on a bike it's much easier to do and I find myself doing it out of habit from doing it in the car. Granted, it's not essential but it balances things nicely (and also kinder to the drivetrain as a whole because the speeds of the engine and transmission are equalised)
Just keep practicing it and it'll be 2nd nature in no time. ____________________ '12 NC700S & '12 CB600F Hornet [Stolen by some dickless twat] Suzuki GT500 shed |
| johnsmith222 |
| N cee thirty |
 N cee thirty Banned
| johnsmith222 |
| BIKEVIDDER |
 BIKEVIDDER Scooby Slapper
 Posted: 18:24 - 09 Nov 2011 Post subject: |
Tootle along in third with a comfortable engine speed, note speed.
Thrash & change up, thrash a little more.
Shut off & coast down to lower gear comfy speed, get foot ready, get hand over clutch lever ready.
As you dip clutch open & close throttle as quick as you can raising revs by a couple of thou' & down shift gear..
It really is a case of ride & just pick things up as you go along though. Each time you do something wrong try something different.
It will come eventually.
I ride a twin & only blip a small amount during "town" riding, tight twisties need slightly more oomph  ____________________ GROWING OLD DISGRACFULLY |
There is a gap of 1 year, 38 days between these two posts... |
| sim2kuk2011 |
 sim2kuk2011 Two Stroke Sniffer
| Fifteen15 |
| J4mes |
 J4mes World Chat Champion
| Alpha-9 |
 Alpha-9 Super Spammer
| johnsmith222 |
| T0MMY |
 T0MMY World Chat Champion
| Acemastr |
 Acemastr World Chat Champion
 Posted: 21:43 - 19 Dec 2012 Post subject: |
I do it everytime, even with the back wheel lifting from the front braking.
Like a boss  ____________________ 2017 KTM 350 XC-F - 2014 Yamaha R6 - 2005 Yamaha YZ125
2016 Toyota Tacoma Limited |
The last post was made 13 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
