Project GSXR 400
aceofhearts
PostPosted: 23:07 - 17 Dec 2012    Post subject: Project GSXR 400 Reply with quote
Here is my new project bike!
Its an early 90's Suzuki GSXR 400, which has been off the road for a while and is currently in several pieces. So far from a quick look around i can see it needs a new oil cooler, brake pads, chain, spark plugs and wiring bits. It also needs the exhaust and airbox refitting and to get it running, and also raising the front back up as the forks are currently very low in the clamps.
I will start stripping it down and investigating this week Thumbs Up
All advice and ideas welcome
https://thumbsnap.com/s/7Hg3i6iZ.jpg
https://thumbsnap.com/s/Cny2ccIz.jpg
https://thumbsnap.com/s/TUyJus47.jpg
https://thumbsnap.com/s/H8hDp9Sn.jpg
aceofhearts
PostPosted: 22:01 - 24 Dec 2012    Post subject: Reply with quote
Had my first quick look around the bike yesterday and spotted a few issues, mainly around the loom and wiring (most of it is not connected)
Does anyone have a wiring diagram for the bike at all? I have not had much luck looking for workshop manuals Sad
I will get cracking on with it more next week when i can sort out a space in the outbuilding Thumbs Up
Nope.
PostPosted: 22:09 - 24 Dec 2012    Post subject: Reply with quote
Wiring Diagram for the 76A:
https://www.graniterock.co.uk/400manuals/GSX-R400_GK76A_Wiring_Diagram.pdf
Spec sheet:
https://www.graniterock.co.uk/400manuals/GSX-R400_GK76A_Spec_sheet.pdf
Other Manuals:
You need to join 400gb forums, theres a wealth of information on most 400 grey imports.
So what are you plans, full strip and rebuild including motor? Or just a general tidy up?
Don't forget to change the carb seals!
aceofhearts
PostPosted: 23:38 - 24 Dec 2012    Post subject: Reply with quote
Thanks, thats a great help Thumbs Up
I will join the forums now and have a read through. Plans are to hopefully get the engine running and if all is well do a strip / rebuild to get the bike up to scratch.
I have also had a look on the net but are there any generally recommended parts suppliers?
I also see the Sachs in your signature, got any pics? That was my first 125 so have a bit of a soft spot Laughing
haroman666
PostPosted: 23:42 - 24 Dec 2012    Post subject: Reply with quote
I have some 76A cams for sale if you by any chance want them.
Nope.
PostPosted: 23:45 - 24 Dec 2012    Post subject: Reply with quote
The only place that really stocks any parts for them is Robinsons foundry, if you can't find it online give them a call and they're really helpful.
I don't have any atm because its mostly in bits, do you want to buy it? Please please please buy it.
aceofhearts
PostPosted: 01:09 - 25 Dec 2012    Post subject: Reply with quote
Lol what is wrong with it? And how much? Wink
You are not even that far from me Thinking
Nope.
PostPosted: 01:43 - 25 Dec 2012    Post subject: Reply with quote
PM'ed you.
aceofhearts
PostPosted: 23:38 - 28 Dec 2012    Post subject: Reply with quote
Made some progress today and started to clear out the outbuilding and managed to get the bike in. Also pulled off the bodywork to have a look at the mess i had to work with.
https://thumbsnap.com/s/PBUNuogd.jpg
https://thumbsnap.com/s/6qTQzoW4.jpg
Mess of wiring under seat (lots of plugs with nowhere obvious to go)
https://thumbsnap.com/s/net2ksXM.jpg
And the top of the engine (coils loose and no spark plugs)
https://thumbsnap.com/s/7Qv43ROg.jpg
aceofhearts
PostPosted: 23:38 - 29 Dec 2012    Post subject: Reply with quote
Today has been quite productive, have pulled the loom from the bike to work out where all of the wires are supposed to go, and since there seems to be only a Japanese wiring diagram available I have been chasing all the wires through and translating it into English to try and help others that may be in the same position. There are a few bits i am still unsure on, but think it has turned out quite well Smile
I also pulled the subframe off once the loom was free to make a bit of extra room.
Next up is to retape the old loom and tomorrow hopefully get it back in.
https://thumbsnap.com/s/711AvOpg.jpg
https://thumbsnap.com/s/qU9IawPB.jpg
https://thumbsnap.com/s/aHmTF0u8.jpg
https://thumbsnap.com/s/1fCQO5W6.jpg
My tidied up and translated wiring diagram Smile
https://thumbsnap.com/s/nijXDcQI.jpg
If anybody can help me with the unknown components in the diagram (Computid?) I would be very appreciative of some help (I can email over the full size document)
aceofhearts
PostPosted: 02:50 - 30 Dec 2012    Post subject: Reply with quote
Loom fully labelled and tidied up Very Happy
https://thumbsnap.com/s/AFnFVOXD.jpg
aceofhearts
PostPosted: 18:35 - 30 Dec 2012    Post subject: Reply with quote
Progress today:
After plugging back in the loom and hooking up a battery, all of the gauges, warning lights and headlights worked on the bike, so that is a step forward Thumbs Up
I couldn't however get the bike to turn over on the button, but by shorting out the starter relay it turned over lovely which fills me with much more confidence Smile
Next stop is finding out what these unknown plugs are on the loom, getting the carbs cleaned out, refitting the exhaust and try to get it to run.
Anybody with a GK76a able to look at their bike and tell me what these connectors are plugged into on their bikes? It seems my project bike has a few components missing Confused
https://thumbsnap.com/s/opgtzXkb.jpg
https://thumbsnap.com/s/doDBwB0L.jpg
https://thumbsnap.com/s/fvUBwvue.jpg
Nope.
PostPosted: 18:47 - 30 Dec 2012    Post subject: Reply with quote
Any chance you could locate them on the wiring diagram for us or at least point as to which part of the bike they were on?
Also, if you send me over a higher res of the wiring diagram I'll have a look for you.
aceofhearts
PostPosted: 18:58 - 30 Dec 2012    Post subject: Reply with quote
Thanks i will email you one over when I get to work later Thumbs Up
One of them has something to do with the indicators (maybe for an alarm?) and one has something to do with the generator. The last one i have no idea but i can get more info later when at work, so i can be a bit more helpful.
All are around the rear of the bike (CDI / fusebox area) but the loom has been mucked about with in the past so may be wrong.
aceofhearts
PostPosted: 20:01 - 30 Dec 2012    Post subject: Reply with quote
Ok have had a look at the diagram.
First Picture:
On the wiring diagram is next to the generator. Possibly a crank sensor or for the tacho?
Second Picture
Top right of the wiring diagram. Is connected to the indicators so maybe for an alarm?
Third Picture
Between the TPS and OIl pressure switch on the wiring diagram. Looks like a coil or something but cannot figure what it is? Judging by the area on the diagram maybe it plugs to something on the engine?
Whats your email address I will send you over the diagram?
aceofhearts
PostPosted: 20:10 - 30 Dec 2012    Post subject: Reply with quote
Ok i have a development from 400gb
The green connector is possibly for a side stand switch, and might be what is holding off the starter?
On the diagram a few posts above it is on the top right marked up 'Hazard?'
(It was marked hazard as for some reason it was connected to the indicators, but i can now see that they are just sharing an earth Idea )
ETA
Kick stand switch it is (looking at ebay). I have now ordered one up as the bike currently doesnt have one (hence the paddock stand)
1 down 2 to go
TotalGSXR
PostPosted: 20:27 - 30 Dec 2012    Post subject: Reply with quote
Identical wire that I have for my side stand switch of a similar era Suzuki.
aceofhearts
PostPosted: 20:31 - 30 Dec 2012    Post subject: Reply with quote
Thanks i have just discovered it is by looking at pictures on eBay Thumbs Up I have ordered one up and edited my above post
aceofhearts
PostPosted: 20:39 - 30 Dec 2012    Post subject: Reply with quote
Here are the wiring diagram pictures for plugs 1 and 3
https://thumbsnap.com/s/LMHChtp5.jpg
https://thumbsnap.com/s/47ymd0zD.jpg
orac
PostPosted: 19:44 - 01 Jan 2013    Post subject: Reply with quote
the first one is the signal generator, its sends crank position to the cdi to determin when the spark plugs should fire.
the second one could well be a temp sensor. however it maybe worth having a look at the carbs to see if they have heaters fitted
orac
PostPosted: 19:50 - 01 Jan 2013    Post subject: Reply with quote
aceofhearts wrote:
Progress today:
the first one looks like the crank pickup/signal generator wires. (they were the same on my GK75A) there should be a match to it that come from the the engine, maybe the left side (if its the same as the 400 bandit)
second on looks to the side stand switch and an earth, if you earth the green wire it should fool the bike into the side stand being up ie bypass the switch entirely.
third one, no clue look to be a water proof connecrtor of some type, maybe carb heaters of TPS. were abouts is it with the loom correctly fitted to the fram
aceofhearts
PostPosted: 20:08 - 02 Jan 2013    Post subject: Reply with quote
I have had a look on the bike and the other two connectors are definately not there, but now i am pretty happy that the first is the signal generator (i will be pulling off the covers tomorrow to find out where it should be) and the second may be for an airbox sensor, although my airbox doesn't have any sensors on it Confused
orac
PostPosted: 22:56 - 02 Jan 2013    Post subject: Reply with quote
i have just had a look in my manual and found something that look like the second unknown thing on the wiring diagram - it labelled as a a solenoid. i on mine its for operating the variable valve timing.
following the granny image you have provided for the wiring i can just about see that 1 wire goes back to the CDI from this device. did they ever produce a v-valve motor for the GSXR range?
orac
PostPosted: 23:12 - 02 Jan 2013    Post subject: Reply with quote
heres a scan of the wiring diagram for the 97 version of mine.
https://farm9.staticflickr.com/8492/8338867111_54a5b84aba_b.jpg
Wiring by f2268d215cc925918731918f4efa0289, on Flickr
i was just thinking as well, did suzuki play with those butterly valve in the exhaust to help inprove low down performane while still being ablle to keep the top end - think it was called something like exup, not sure tho, that may have been yamaha
orac
PostPosted: 23:16 - 02 Jan 2013    Post subject: Reply with quote
it called SET - suzuki exhaust tuning, cant seem to find any thing about the 400 having it fitted tho.
The last post was made 13 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 133.57 Kb
