yamaha r6 5eb
mbigdav
PostPosted: 17:31 - 18 Dec 2012    Post subject: yamaha r6 5eb Reply with quote
hi this is my first real bike !! was hoping for some help ? i have adjusted the drive chain and oiled the chain also but for some reason when at low speeds like in traffic there seems to a knocking noise like something s hitting. i have now put the bike on paddock stands. has anyone got any ideas Very Happy
Islander
PostPosted: 17:39 - 18 Dec 2012    Post subject: Re: yamaha r6 5eb Reply with quote
How did you check the slack and how much slack did you leave?
Did you adjust both sides of the rear axle equally?
As an example, on my Hornet and my OH's Zephyr the normal slack is about 30mm. It should be measured in the middle of the lower run of the chain at the tightest part of the chain (spin the rear wheel and check continually to find this).
mbigdav
PostPosted: 17:47 - 18 Dec 2012    Post subject: Reply with quote
basicy i sat on the bike and learned over to check slackness off chain and then adjusted it from the weight off me sitting on bike if that makes sense as i off my mates suggested that this was the way to do it . have i over adjusted the drive chain ??
Islander
PostPosted: 17:58 - 18 Dec 2012    Post subject: Reply with quote
Your mates were wrong unfortunately.
Put the bike on a paddock stand so that you can rotate the rear wheel, check the slack in the middle of the bottom run, find the tightest spot and adjust the slack at that point by loosening the spindle nut and adjusting both sides of the spindle equally until it's correct. Use the markers on each side of the swing arm to check that you've got the wheel straight. Don't forget to retighten the spindle nut.
If you're unsure about that then measure the distance from the centre of the swingarm pivot to the centre of the rear spindle. It should be the same distance on both sides.
The last post was made 13 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.44 - MySQL Queries: 13 - Page Size: 39.96 Kb
