Upgrading headlight lamp and wiring/heated grips question.
ginny
PostPosted: 14:30 - 20 Dec 2012    Post subject: Upgrading headlight lamp and wiring/heated grips question. Reply with quote
So, Having managed to disassemble the hornets fairing etc, I am going to fit a better main bulb (probably an osram night racer plus)
Since I have all the wiring etc exposed, I was considering re-doing the heated grips. Currently they are wired to the battery directly, so I have to remember to turn them off. Instead I thought attaching directly to headlight wiring would be good as there is always power to it (there is an in-line fuse in the grips wiring already)
However- will this reduce the power available to the lamp, and therefore reduce the effectiveness of main headlight?
I could wire to rear break light but that cable is further away to wire, not so obvious, and not so easily-open-to-manipulation/bodging.
TL;DR- Will wiring heated grips to headlight reduce headlight brightness?
Thoughts appreciated.
bikenut
PostPosted: 15:07 - 20 Dec 2012    Post subject: Reply with quote
dont do it!!
dedicated wiring for dedicated circuits, along with fuses.........unless of course you want the lights to just go out at night? or the wiring catch fire......interesting if your riding it at the time..........merry xmas and dont involve me in your accident.
MarkJ
PostPosted: 15:08 - 20 Dec 2012    Post subject: Reply with quote
I wouldn't run it in parallel from the front headlight, it could pop the fuse and you wouldn't be able to run the grips with the lights off.
I know you don't want to but using a relay from the rear brake wiring really is the best way. You could use a relay from the front headlight which shouldn't pop any fuses, but again you could only have them on with the headlight on.
ginny
PostPosted: 15:20 - 20 Dec 2012    Post subject: Reply with quote
Haha fair enough! A relay is just more effort, but if necessary I can do it... I say me but I know nothing about wiring, I would have been asking the father in-law for advice, so hopefully he knows about relays as well as basic wiring/splicing etc.
I should add that I ride with the headlight always on all the time anyway... lots of filtering.
Edit: Hows this?
https://www.amazon.co.uk/LD-12P-Automotive-Pin-Relay-12V/dp/B004UA61T0/ref=sr_1_1?ie=UTF8&qid=1356017598&sr=8-1
orac
PostPosted: 16:38 - 20 Dec 2012    Post subject: Reply with quote
if it was me i would take a feed of from the ignition (something like brake ligh feed should be fine), through the switch to a relay (coil side). the switch side of the relay takes a feed from the battery to the grips through a fuse of the correct rating
that relay yo linked to should be fine, woudln't think the grips would draw more than about 3amp
PostPosted: 17:04 - 20 Dec 2012    Post subject: Reply with quote
Edit: Hows this?
That will work fine and you will have a redundant pin (87a).
All you actually need is a 4-pin NO (normally open) relay.
My relay howto
ginny
PostPosted: 15:20 - 21 Dec 2012    Post subject: Reply with quote
Thought I had replied to this... anyway.
Stinkwheel, that how-to looks brilliant. Complicated, but brilliant. I should be able to scrounge the wire up from the in-laws garage- trying to keep costs low and don't need 3 spools of wire sitting unused! had a recce today and he seems to have all the bleedin' connectors etc I could imagine!
Probably a bit above my level but nevertheless I shall have a crack at it.
Out of interest how do you know which are the ignition wires? Assuming you are looking at the big fusebox/plug where all the cables seem to go (under the seat on my hornet) that is.
I guess rear break lights are easier to identify, are they as suitable?
PostPosted: 15:39 - 21 Dec 2012    Post subject: Reply with quote
It's not complicated, just very detailed.
A feed to a brake light switch is very suitable because if something screws up, the worst that would happen is that the brake light would stop coming on with that brake.
Since you have a Honda, certain aspects of the wiring are predictable due to standardisation of wire colours. For these purposes, switched live wires are black on Honda motorcycles. Use a black wire to trigger your relay. Earths are dark green.
ginny
PostPosted: 15:53 - 22 Dec 2012    Post subject: Reply with quote
One final question Smile
The 2 devices I want to attach via relay have in-line fuses already. Grips and Cigarette lighter/12V socket for phone charging. I might just connect the socket to the battery as it will only be powered when I actually plug my phone into it.
Do I still need to insert the 2 separate fuses, as you have in your walkthrough? Or can I just have a direct feed from Positive terminal to relay?
Edit: scrap that- I have just realised that i can just insert the relay in between device and its in-line fuse serve the relay as a whole rather than just the device. The supplied cable for the grips is plenty to stretch from relay mounting position to h'bars. If that makes sense. At all.
The last post was made 13 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 64.02 Kb
