Ran out of fuel very early!
Adam80UK
PostPosted: 11:54 - 21 Dec 2012    Post subject: Ran out of fuel very early! Reply with quote
My sh300 ran out at a mere 103 miles today. I have ridden, it the same as I've always done and usually don't look to fill it until I've got to at least 110 and never had a problem.
Are there any other causes for this that anyone knows? Just seems a huge drop in mpg. Tyre pressures are ok too.
Current: '07 Suzuki SV1000 & '07 Honda SH300i (again).
Previously owned: '08 Yamaha R1, '10 Kawasaki Z1000, '07 Honda SH300i, '04 Suzuki SV1000S, '11 Honda CB1000R, '09 Kawasaki ZX-10R, '08 Aprilia Tuono 1000R, '07 Triumph Daytona 675, '95 Honda CBR600F.
PostPosted: 11:57 - 21 Dec 2012    Post subject: Re: Ran out of fuel very early! Reply with quote
Checking fuel lines would be a good first call.
RichieZX6R
PostPosted: 12:03 - 21 Dec 2012    Post subject: Reply with quote
smell of fuel when parked? Maybe some drops of fuel under the bike when parked?
A change in commutes could also account for this? If your doing mostly NSL Work and you change to riding round town this could have an affect also.
HTH
Current: Kawazaki ZX6R 51
Past: Kawazaki ZX6R 96 - Honda CBR 600F4 05 - Dragstar 125 02 - Honda CB 400 SF 94 - Honda NSR 125 51 - Gilera Runner XV125 04
Paulington
PostPosted: 12:06 - 21 Dec 2012    Post subject: Reply with quote
I would consider a ~6% variation in fuel economy well within the margin of error, you could have gone up more hills, colder air = higher density which means the bike needs more power to move through it or some other cumulative cause.
I'd just consider that variation, wouldn't be worrying about it.
Nexus Icon
PostPosted: 12:23 - 21 Dec 2012    Post subject: Reply with quote
A 50 degree swing in temperature (Celcius) can easily show a 30% drop in fuel economy, so 6% would only need a 10 degree drop.
Also tyre pressures will drop too, in colder weather, and also contribute to decreased economy figures.
Nothing to worry about, IMO.
Greetings from Shitsville!
Jefr0
PostPosted: 12:47 - 21 Dec 2012    Post subject: Re: Ran out of fuel very early! Reply with quote
Coxy_UK wrote:
huge drop in mpg
7 Miles difference?!
7 miles is nothing, that could be down to a lot of things like what's been mentioned above and also you may filled it slightly differently, maybe not totally to the top.
Far from a huge drog in MPG, if there was a big gap then I'd be concerned, I wouldn't worry about it.
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
PostPosted: 12:55 - 21 Dec 2012    Post subject: Re: Ran out of fuel very early! Reply with quote
I would presume that he normally doesn't wait until his tank his bone dry to fill up Smile.
J.M.
PostPosted: 13:00 - 21 Dec 2012    Post subject: Re: Ran out of fuel very early! Reply with quote
What he hasn't said is how much is usually left in the tank when he fills up.
When I'm at Uni I usually fill up every week whilst doing my shopping. The trip counter is around 90 miles on average. However my full tank is good for probably 160 in the city and 220 on the motorway. If I ran out at 83 miles that's still only a 7 mile difference, but a lot of unaccounted for fuel Smile
2004 R1 & 2018 XSR900
Shinigami
PostPosted: 13:41 - 21 Dec 2012    Post subject: Reply with quote
i've had a journey that resulted in me running out (main tank) on the 125 at least 30 miles less than i would have normally,
This was entirely down to VERY strong headwind that day (was a long nearly 4 hour ride)
The loss of 7 miles is nothing to worry about with the way conditions are all over the place at the minute
Adam80UK
PostPosted: 15:00 - 21 Dec 2012    Post subject: Reply with quote
Cheers guys, ok exact same boring commute is all its used for and no sign of any leaks. I believe it will do about 125 miles ish on a full tank so this is definitely a loss of 20 miles or so!
c_dug
PostPosted: 15:22 - 21 Dec 2012    Post subject: Reply with quote
This week I got 160 miles to the light when I usually see between 174-180, I removed my top box 20 miles in to the tank so if anything I was expecting more miles not less.
Wouldn't worry about it too much unless it happens a second time.
barrkel
PostPosted: 18:42 - 21 Dec 2012    Post subject: Reply with quote
I reliably get 130 miles city riding on my SH300, then when I fill up, around 8.4 litres goes in. If it ever gets low enough to take 8.7 or more, then the SH300 will have been losing power on strong acceleration at traffic lights. Fuel feed seems to be towards front of tank and slosh from acceleration starves it.
I presume it wasn't sounding any different, e.g. revving higher than normal, or the clutch slipping past 10mph or so? I can imagine worn clutch shoes, worn belt, CVT pulley contamination, etc., could reduce mileage somewhat.
Lowest I've ever gotten on a tank was somewhere around 115 miles, but I was riding like a suicidal teenager at the time. My SH300 kind of encourages it, I don't know about yours.
passifid
PostPosted: 19:17 - 21 Dec 2012    Post subject: Reply with quote
I've seen a drop of 21mpg by riding a 125 more harshly, and this is a 300? maybe you were riding more harshly, also maybe you hit more lights/traffic, more riding in rush hour? less filtering because of vans etc? windy? i moved from kent to brighton and saw getting 20 miles less per tank because of the costal winds. so overall i have dropped by almost 60 miles per tank if i use throttle as on/off and with strong winds.
I fill up from reserve and calculate rough miles covered and therefore mpg with every fill up recently because i wanted to work out my mpg in city.
so a drop of 20 miles isn't too bad, i would fret if i lost 40% or somting.
CBT: 10/2011 | Theory:6/2012 | MOD1: 8/2012
barrkel
PostPosted: 19:40 - 21 Dec 2012    Post subject: Reply with quote
passifid wrote:
I've seen a drop of 21mpg by riding a 125 more harshly, and this is a 300? [...] so a drop of 20 miles isn't too bad, i would fret if i lost 40% or somting.
125 miles per tank would be riding fairly harshly. When ridden on the open road or motorway, I don't have difficulty getting 160 miles between refills, and that's not running out of fuel. Down to 103 from there would be a loss of 40%.
(The SH300 is a 279cc engine because 280cc is the cutoff point for certain emissions requirements.)
Adam80UK
PostPosted: 19:54 - 21 Dec 2012    Post subject: Reply with quote
To be honest I have always ridden it harshly, I don't think I rode any different.
I will just have to see what happens next time, and to be safe I'd like a little fuel container that fits under the seat, maybe a 3L one of they exist. Before anyone harks on about this being dangerous or anything... please don't bother lol.
Reassuring to hear that other people have had large drops occasionally in MPG so thank you for that, I will just have to see how next tank goes Thumbs Up
Ja7
PostPosted: 19:58 - 21 Dec 2012    Post subject: Reply with quote
Maybe the colder weather, with longer warming up times,
Lone-Wolf
PostPosted: 20:00 - 21 Dec 2012    Post subject: Reply with quote
Wotcha.
I carry a one litre fuel container . . . . and that takes up a fair bit of room.
Cheers.
L.W. - www.moonshiners.org.uk
Cunnington
PostPosted: 22:21 - 21 Dec 2012    Post subject: Reply with quote
Assuming it is as wet where you are as it is where I live, you are probably experiencing an increase in the rolling resistance as your tyres push the water out of the way.
I've seen a 10% drop in fuel economy in the cage the last 6-8 weeks, which coincides with colder weather, where it takes longer to clear the screen, and if it hasn't been cold it has been wet.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
Kwakki Si
PostPosted: 11:08 - 22 Dec 2012    Post subject: Reply with quote
The only time I don't get my usual 130miles before fill up is if I use normal unleaded as I seem to get 10miles less to a full tank, so I mainly use super.
MOD1 passed 26/01/12... MOD2 passed 08/02/12
My current ride: ZX6R NINJA G2, The GREEEEN one!
Is it a bird? Is it a plane? No, it's a mother fucking motorbike!
hellkat
PostPosted: 12:17 - 22 Dec 2012    Post subject: Reply with quote
103 seems like not very much to me...
My bike regularly does 150 miles +, although (a) I don't often let it go that far (usually fill up at about 135), and (b) I only commute into town and back, 22 miles a day ... and on occasion up to the Ace Caff, so it rarely leaves London postcodes.
But then, mine is an XJ900, maybe it has a bigger tank? Not sure ... too technical/geeky for me to contemplate.
At least the price of petrol has come down a bit (but still not enough).
I was freaking with all this over-£20-to-fill-a-tank nonsense.
The last post was made 13 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 110.34 Kb
