Changing oil the easy way
flat eric
PostPosted: 19:15 - 21 Dec 2012    Post subject: Changing oil the easy way Reply with quote
The days of replacing your sump plug washer and getting dirty are over with this little beauty.
Simply put the removal pipe into the engine and touch the bottom of the sump, then use the pump to remove the air from the vessel and create a vacuum. And go and make a cup of tea.
20 - 30 mins later, the oil has been extracted to the vessel and you can replace the filter. Fill the engine with new oil and that's it done.
They are £36 from ebay. No need to pay more than than for it.
Type in: Pela6000
You can also find it on Youtube
Can be used on cars as well. Just did my car with it.
[/u]
There is always someone worse off than you !
salty21
PostPosted: 19:23 - 21 Dec 2012    Post subject: Reply with quote
i'd rather just undo 1 bolt and re-use the crush washer, as i have always done Laughing
even if you did want to use new crush washers every time(un-necassary but some people are anal like that), they only cost about 25p each so it would take more than a lifetime to recoup the cost of this pointless contraption Laughing
kestrel
PostPosted: 19:44 - 21 Dec 2012    Post subject: Reply with quote
I'll stick to draining oil the old way, I like to see if there is anything on the magnetic sump plug. I think it would just be another piece of junk cluttering up the garage.
Isle of Man.........Road Racing Capital Of The World
Derivative
PostPosted: 19:45 - 21 Dec 2012    Post subject: Reply with quote
36 quid?
That's six hours wages for me.
If I valued my time more, I'd likely just take it to the garage and let them sort it out.
I wouldn't pay 36GBP for a remote control that would instantly change my oil (unless I could sell the service to others, Wink)
barrkel
PostPosted: 19:48 - 21 Dec 2012    Post subject: Reply with quote
If it saved me crawling around on my hands and knees (I don't have anywhere to put a bike lift), I'd consider it an improvement. But the oil filter still needs changing, and a drain pan will still need to go underneath it to catch what comes out, so IMO it's not really saving that much work.
Marmalade
PostPosted: 19:54 - 21 Dec 2012    Post subject: Reply with quote
I like the draining out of oil, it feels better than sucking it out the filler hole, all the nasties go out the drain hole.
I know of garages that use this method as it saves issues with threads stripped in alloy sumps but if a vehicle is regularly serviced then there should be no problems.
Frost
PostPosted: 20:00 - 21 Dec 2012    Post subject: Reply with quote
So you're filthy dirty and you have a bath. You the plug out of the bottom letting the filth run down the plug hole.
Why would you use a small pipe to syphon the water out from the top leaving the filth at the bottom?
covent.gardens
World Clap Champion
PostPosted: 20:09 - 21 Dec 2012    Post subject: Reply with quote
These have been around years and they might be easier but they don't get the old oil out as well. A few cars don't even come with sump plugs now 'cos the expected method to change the oil is via the dipstick tube with one of these things. But meh, the old way is the best.
keggyhander
PostPosted: 21:32 - 21 Dec 2012    Post subject: Reply with quote
On most bikes there is not a direct path to the bottom of the sump.
All you'll end up doing is diluting bad oil with good, rather than exchanging it.
.Chris.
PostPosted: 21:47 - 21 Dec 2012    Post subject: Reply with quote
These are commonly used for cars - the tube is fed down the dipstick hole and the oil sucked out. As Keggy says though, on most bikes there's something in the way. On my GN, the clutch is directly below the oil filler.
Chris
1985 Kawasaki Z550F
kernow24
PostPosted: 22:11 - 21 Dec 2012    Post subject: Reply with quote
hmmmm, so whats so dirty and awkward about doing an oil change the conventional way?
pair of latex gloves on, wrench, a couple of turns, oil spills out, fish the plug, filter, spring etc out with gloved hands, then replace, put new oil in, and the jobs a goodun Neutral
Maybe im simple, but I don't the problem that would require an extra gadget to clog up the corner.
That, and gravity would dictate that the best way to drain something is by unplugging it from it lowest point, a reason baths have plugs and not a pump on the side..
Frost
PostPosted: 22:45 - 21 Dec 2012    Post subject: Reply with quote
Don't drop the plug in the oil and you don't have to fish it out Wink
Undo the last bit by hand and whip it away.
Mondeo Man
PostPosted: 10:27 - 22 Dec 2012    Post subject: Reply with quote
These things aren't a god send.
Some cars (eg Mondeo) you can't feed the pipe into the oil to drain it anyway.
Frankly, I don't see the point of a siphon for a motorcycle - haven't known a bike where it's a problem getting to the sump bolt.
nowhere.elysium
The Pork Lord
PostPosted: 11:00 - 22 Dec 2012    Post subject: Reply with quote
'The easy way'? What's so hard about undoing a bolt and a filler cap? This just looks like a solution that's seeking a problem, to me.
Kwakki Si
PostPosted: 11:12 - 22 Dec 2012    Post subject: Reply with quote
Didn't know changing oil was hard?! I have never touched a motorbike or had any kind of mechanical knowledge but I managed to do it all 1st time in about 10mins with minimum effort! I changed the sump plug gasket which cost me about 50p aswel lol, looks like this contraption will be more junk to trip over in the shed!
MOD1 passed 26/01/12... MOD2 passed 08/02/12
My current ride: ZX6R NINJA G2, The GREEEEN one!
Is it a bird? Is it a plane? No, it's a mother fucking motorbike!
i.p.phrealy
PostPosted: 11:23 - 22 Dec 2012    Post subject: Reply with quote
aaah, so I'm not the only clumsy one then! Smile
it helps if you wait for the oil in the tray to cool down a bit before going fishing too. Thumbs Up
0l0dom0l0
PostPosted: 12:31 - 22 Dec 2012    Post subject: Reply with quote
Stupid idea
Bikes are made with a sump plug for a reason.
Plus, they're hard enough to undo after a year. £36 will soon turn into £250 for a new sump when you destroy it because the bolts seized.
Torque Wrench
PostPosted: 14:35 - 22 Dec 2012    Post subject: Reply with quote
I purchased a low profile container to fit under the motorcycle, I think having a sealed container to dispose of the used oil is a must.
If you change the oil filter, is the syphon now redundant at this point?, is it worth the money?
stevo as b4
PostPosted: 14:59 - 22 Dec 2012    Post subject: Reply with quote
A siphon as such is a waste of money at that price, and as said is not the best method for draining out the old oil. But something like a large siringe with a thin tube would be useful for those times when you overfill an engine with oil or a cooling system etc, and don't want to undo a drain plug or remove a hose twice just to ket a bit of excess fluid out.
PostPosted: 15:24 - 22 Dec 2012    Post subject: Reply with quote
Both my bikes have magnetic sump plugs so when it's oil change time I get the opportunity to see if the swarf/sludge has increased. Another thing when draining from the sump plug is the ability to tilt the bike to get the very last drop of old oil out(almost).
stevo as b4
PostPosted: 12:17 - 23 Dec 2012    Post subject: Reply with quote
Vincent wrote:
I've got a similar one for the car but wouldn't bother with using it on the bike. It actually works well on the car - it saves me removing the sump guard which can be a pain and on my particular car get's the last bit out. Most of the rubbish that ends up in oil stays at the bottom of the sump anyway.
Very good point, as sump plugs are rarely at the very lowest point on many car's these days, and as you say whichever way you remove the oil, theres plenty of ridges, baffles and uneven surfaces in most cast alloy sumps for sediment to collect.
For a car using the siphon method may be easier for some newer car's, more regular than needed oil changes no matter how they are done is still loads better for the engine than worrying about how the oil is changed. You can always use an engine oil flushing solution or fill with the cheapest diesel engine oil and run it for 100miles or so to clean out the engine before you put some good stuff in it anyway.
On a newlypurchased old car or bike that's done very high miles, had loads of owners and or has not much service history it's probably a better idea to order yourself a new sump gasket when you first do an oil change, and then drop the sump off completely to clean it out and clean any debris out of the oil strainer/pick up anyway.
kestrel
PostPosted: 14:17 - 23 Dec 2012    Post subject: Reply with quote
I use a square plastic 5 gallon container split vertically as a drain pan. I have another 5 gallon container that I dump the old oil into along with old petrol, thinners, brake fluid, coolant etc, even the old oil from the deep fat fryer goes in. Once it's full I take it to the recycling centre and get another container.
Killer Rat
PostPosted: 14:39 - 23 Dec 2012    Post subject: Reply with quote
I have one of those cheap magnetizers from the land of pound, you have just shown me a decent use for it instead of magnetizing my darts for the pub, sump plug is getting the magnet treatment.
£36 would buy 4 litres of oil for my particular bike, i see no real need for a siphon when i make a comparison like that.
No! No more talk! We go in! We kill! Kill! We kill 'em! They kill us, we kill them! Kill 'em! Kill 'em! Kill! Kill!
_______________________________________________________
cbf125 09', cbt passed 4/6/2010 - 28k miles - 1 major breakdown (stator)
The last post was made 13 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 129.95 Kb
