CG125 Running Problem
crazymotorbik...
PostPosted: 19:13 - 21 Dec 2012    Post subject: CG125 Running Problem Reply with quote
Hey,
I'm currently having a problem keeping my cg125 running.
About a month ago i turned the fuel tap to off and ran it out of fuel so that the carb would be empty ready for winter storage. Really i should have drained the bowl via the drain but i was been lazy.
Sip forward a month i thought i'd skip the winter storage and get the bike on the road again. The bike started first kick ran for about 30 seconds and then died. Que me trying to get the bike started for 2 hours!!
When it eventually did run again it would only run with handfuls of throttle but would die fairly quickly.
Its got a good spark and fuel is flowing into the carb. The airbox has only recently been cleaned out and the filter element cleaned and oiled.
I've got the carb off for cleaning but as yet can see no real problems. Anything i should be looking out for?
Cheers,
Shaun R.
Alpha-9
PostPosted: 19:18 - 21 Dec 2012    Post subject: Reply with quote
The plug coked up?
Having the same issue with mine, seems to be down to the choke
Fzr-600 1999
crazymotorbik...
PostPosted: 19:27 - 21 Dec 2012    Post subject: Reply with quote
Hey,
Tried 3 different plugs and still had the same problem Sad
I'm hoping its some muck stuck somewhere it shouldn't be.
Cheers,
Shaun R.
ricklincs45
PostPosted: 20:07 - 21 Dec 2012    Post subject: Reply with quote
Running on handfuls of throttle suggest main jet is ok but slow-running system has a problem.
Most likely a blocked pilot jet or pathway. Remove pilot jet and you should be able to see clearly through it when held up to the light. Minor obstructions can usually be blown out by mouth. If it's really stuck, you may need an airline. If you get really, really stuck, an acupuncture needle can be used if you're careful.
Invest in some proper carb cleaning spray and soak all the insides of the carb and jets to clear any gumming/deposits. Doesn't hurt to soak jets etc overnight in it. Then blow through to remove the carb cleaner.
While you're at it, worth checking the air filter element isn't over-oiled, and also check carb float isn't punctured (try shaking it - if you can hear petrol sloshing in it, it's knackered/punctured - very rare, but can happen).
Author '80 Bikes, and counting...' Currently getting frustrated with an MZ 125 TS.
crazymotorbik...
PostPosted: 21:18 - 21 Dec 2012    Post subject: Reply with quote
Hey,
Thanks for all the info Thumbs Up
Removed the pilot jet and it was blocked with muck so hopefully found the problem.
Carb cleaner will be bought shortly along with a bottle of compressed air Thumbs Up
Cheers,
Shaun R.
Alpha-9
PostPosted: 12:59 - 22 Dec 2012    Post subject: Reply with quote
crazymotorbiker wrote:
Hey,
Cheers,
Shaun R.
Hey do you have to take the carb off to do this?
Fzr-600 1999
ricklincs45
PostPosted: 14:22 - 22 Dec 2012    Post subject: Reply with quote
Technically it is possible to do this without removing the carb, but taking it off makes it a hell of a lot easier.
crazymotorbik...
PostPosted: 16:01 - 22 Dec 2012    Post subject: Reply with quote
Hey,
Takes literally minutes to remove the carb Thumbs Up
Boiled the jets in a pan of water as per a suggestion in a classic bike forum and they came up nice and clean Thumbs Up
Just need to put it back together.
Cheers,
Shaun R.
The last post was made 13 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.32 - MySQL Queries: 13 - Page Size: 56.34 Kb
