| iCraig |
 iCraig World Chat Champion
| Git |
 Git Brolly Dolly
| mr.z |
 mr.z World Chat Champion
 Posted: 15:30 - 02 Nov 2004 Post subject: |
Maybe the camchain needs attention? try reving the bike and leting off sharply (while its still) any clunky noises should be investigated...
Or it could be your tappets/valves
Did you change the bush with the downpipe? refiting the old one will leave a tiny gap which could be doing strange things to your fueling.. however when its warm the pipe expands that ittle bit to close the gap... dunno just a thought...
Another thing, have you checked you oil recently? amazeing how much difference there is from min to max oil in terms of noise... ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Kickstart |
 Kickstart The Oracle
 Posted: 18:55 - 02 Nov 2004 Post subject: |
Could be 101 things, and the suggestions above are both quite likely. Also worth checking if the carbs are balanced, as if they are out then they can make the engine sound very rattly. If they were balanced with a blowing exhaust then they will be out.
The GPZ engine is quite often rattly, both from the cam chain and from the primary drive chain.
| stinkwheel |
 Posted: 19:56 - 02 Nov 2004 Post subject: |
I would suggest a tiny gas leak at the header pipe where it bolts onto the engine. You may be able to hear this if you squat down next to the bike and blip the throttle, or you may feel a jet of exhaust gas blowing out if you put your hand near (careful, hot!) although it can be a very small leak.
The compression gasket under the header needs tightening down after about 100miles post-fitting because, as the name suggests, it compresses. If you didn't fit a new gasket washer, it will almost certainly not seal properly. The copper in the gasket expands through heat and so seals better as it gets warm.
I would tighten up the nuts at the header (carefully, you DO NOT want to shear them) and if that doesn't work, replace the gasket.
Mine is doing exactly the same thing at the moment, a genuine Kawasaki copper compression washer costs three quid. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| iCraig |
 Posted: 16:16 - 06 Nov 2004 Post subject: |
Well guys I have the bike booked in for a service, and they are going to do the valves for me at the same time too.
But I have just taken a video of the bike with sound and the engine is doing said sound the video too.
Tell me what you think you can hear.
https://homepage.mac.com/craiggiles2/GPZ.MOV
You'll need Quicktime installed to play it. |
| TheShaggyDA |
 TheShaggyDA Repost Police
| iCraig |
| stinkwheel |
 Posted: 16:00 - 07 Nov 2004 Post subject: |
Try the stuff I PMed you about, but rereading your original post, a leaky header gasket is still your best bet. It is very suspicious that it is making this noise shortly after replacing the header pipe. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Guest |
 Guest Brolly Dolly
 Posted: 16:21 - 07 Nov 2004 Post subject: |
Nice idea posting a movie
Does sound like the down-pipe blowing, did whoever fitted it use new gaskets? |
| iCraig |
The last post was made 21 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
