| J.M. |
 J.M. World Chat Champion
 Posted: 19:58 - 24 Dec 2012 Post subject: Valve clearances question (thinking a buckets issue) |
EDIT: Page 2, near the bottom, longish post, are the new details.
First of all, a photo of the relevant Haynes manual page to my question. Mine's K3 onwards so 5.5b and 5.5c are relevant:
https://i.imgur.com/RUaUB.jpg?2
Essentially there are two marking on the pulse generator coil bit:
- RT
- LT
Both of them have a vertical line which should align up with the metal point on the coil.
Initially, rotating it clockwise with a 19mm spanner, I set it to RT. It sat on the line perfectly:
https://i.imgur.com/j14J0.jpg?1
However when checking the notches, they were both facing outwards, not inwards:
https://i.imgur.com/36Iil.jpg?1
So I turned it another 360 degrees, back to RT. However when turned 360 degrees so that the notches face inwards, it's impossible to get the line to line up properly as before. Instead it looks like below, which is quite far off. It's possible to hold it in the correct position with a spanner, but upon releasing the spanner it will spin back to this position:
https://i.imgur.com/ttF5f.jpg?1
The notches look like so:
https://i.imgur.com/njhdY.jpg?1
My question is... what's up with that? How come it isn't seating properly when facing inwards on RT but it is when facing outwards on RT?
The second question is... is this alright to work with? If I measure/set the valve clearances whilst it's in that position will I set it incorrectly/get the wrong readings?
Any help appreciated  ____________________ 2004 R1 & 2018 XSR900
| Pete. |
 Pete. Super Spammer
 Posted: 20:04 - 24 Dec 2012 Post subject: |
Makes no difference whatsoever. All that matters is that the feeler gauge is used against the base circle of the cams.
Bit odd that the marks line up notches out but not notches in, since out is exactly one full turn from in. Unless the notches are milled off-nentre in the cam. In any case, for the purpose of setting the clearances is matters not at all. ____________________ a.k.a 'Geri'
| J.M. |
 Posted: 20:09 - 24 Dec 2012 Post subject: |
Brilliant, thanks, I'll get those checked tonight then  ____________________ 2004 R1 & 2018 XSR900 |
| J.M. |
 Posted: 22:13 - 24 Dec 2012 Post subject: |
Okay. Clearances measured. Little confused for where to go now.
I've done all I can tonight, I don't have time to measure the shims tonight (apparently my micrometer isn't accurate enough to measure them anyway... I'll bodge something using the feeler gauges to measure them).
Clearances... "ok" range is 0.03 to 0.08.
2 clearances are okay. 1 clearance is a tiny bit out.
1 clearance was either 1.30mm or 1.31mm?! This was the right cylinder front one (front being closest to the headlamp).
Bit confused as to where to go from here. My chart for valve clearances only lists valve clearances in the range of 0.02 to 1.03... 1.30 is way off of the chart.
Would this valve clearance being so far out be the reason for the poor starting and mpg that the bike has been having?
Edit: really far out one is rhs exhaust. Found a diagram saying which each one was!
For anyone interested, I also found a calculator to calculate needed shim sizes:
https://www.stanford.edu/~sanjayd/shim_calculator_GS500.xls
Tomorrow or boxing day I'll measure the current shims so that I can head out and buy the shims that I need  ____________________ 2004 R1 & 2018 XSR900 |
| Pete. |
 Pete. Super Spammer
 Posted: 23:01 - 24 Dec 2012 Post subject: |
That is a long way out. Probably a bent valve. Might be a sticking bucket but doubtful. See if there's any way to measure the height of the stem top and compare it against the others. ____________________ a.k.a 'Geri'
| J.M. |
| Pete. |
 Pete. Super Spammer
 Posted: 23:09 - 24 Dec 2012 Post subject: |
Yes, that would do it, measure the amount of bucket showing above the guide, if it's less than the others then you have a valve which isn't seating properly, probably from a bent head. ____________________ a.k.a 'Geri'
| J.M. |
| J.M. |
 Posted: 23:46 - 24 Dec 2012 Post subject: |
Okay, just been out again.
Full cycle on this engine is 620 degrees. First 360 degrees for rhs intake, exhaust and lhs intake. Second 360 degrees for lhs exhaust.
It seems that the valve clearance for the rhs exhaust varies per 620 degrees? One iteration may be 1.3mm, the next iteration may be 0.53mm... and so on. I gave up measuring after the second iteration but the bucket height was noticeable different on each 620 degree iteration.
What does this mean?
Edit: If it means anything... my right hand side down pipe has a dent in it from my accident in June. ____________________ 2004 R1 & 2018 XSR900 |
| Pete. |
 Pete. Super Spammer
 Posted: 00:47 - 25 Dec 2012 Post subject: |
720
If the valve doesn't seat fully every time you have to find out why. ____________________ a.k.a 'Geri'
| J.M. |
 Posted: 00:56 - 25 Dec 2012 Post subject: |
Yes, 720, that's what I meant! I'm going to fail my maths exam at this rate...
I'm assuming the only real way to find out why is to take the head off?
Could the exhaust value not closing properly be the reason for poor cold starting? Before I started attempting to fix it... it was popping and banging when trying to start... but running fine once started.
Anyway, I hope that the exhaust bolts on the head are nice to me  ____________________ 2004 R1 & 2018 XSR900 |
| EazyDuz |
 EazyDuz World Chat Champion
| J.M. |
| Blau Zedong |
 Blau Zedong Banned
| J.M. |
 Posted: 01:45 - 25 Dec 2012 Post subject: |
I know
Well actually... if I put it back together as it is... it works... just poorly. ____________________ 2004 R1 & 2018 XSR900 |
| P.addy |
 P.addy Red Rocket
 Posted: 08:56 - 25 Dec 2012 Post subject: |
I'll service the Vara for you...  |
| orac |
 orac World Chat Champion
 Posted: 09:05 - 25 Dec 2012 Post subject: |
sounds like you have a screwed valve.
before you go ahead and use the other head, you should leak test it - turn the head upside down and use something like parrafin ine the pistone wells, then leave it. donwt use something that will evaporate as this will make you think that the valve are leaking - dont use water for obvous reason.
mind you dont loose the shim when you upturn the head. and yes valves not seating will cause mega starting issues. a compression test would have shown valve issue.
i got me one of these
https://www.machinemart.co.uk/shop/product/details/clarke-cht693-8-piece-compression-tester-kit?da=1&TC=SRC-compression+tester ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
"with nothing left to lose, there is everything to gain. It's not the size of the dog in the fight, it's the size of the fight in the dog" |
| J.M. |
| orac |
 Posted: 10:57 - 25 Dec 2012 Post subject: |
have you ever done a valve replacemnt? if not, i would check the other head for squareness, leak test it and be done.
if you replace the valve, you should ideally while there do all the seal and re-seat all of them. another problem is you should in theory, not just do the valve stem seal but the valve guide to (differnt wear on the stem and guides), at least for that one valve.
do you have th correct size valve spring compressor too.
how ever today maybe your lucky day - specaily if you just want to swap the heads. i have a GS500 head gasket here, brand spanking new, still in the packet. Part numer: 11141-01D10
i also have valve seals
09289-07002 x4
11143-06b00 x4
you can have the haed gasket for £20 plus what ever delivery you want. i picked them up for doing my leaking stems on mine, then a good engine with alot less miles came up for less than £50 ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
| J.M. |
 Posted: 11:13 - 25 Dec 2012 Post subject: |
| orac wrote: | have you ever done a valve replacemnt? if not, i would check the other head for squareness, leak test it and be done.
09289-07002 x4
11143-06b00 x4
you can have the haed gasket for £20 plus what ever delivery you want. i picked them up for doing my leaking stems on mine, then a good engine with alot less miles came up for less than £50 |
Only concern is I know nothing of the other engine. is from the earlier E models, so black, rather than the silver on my later F model. I think that it's the same head though. Never done a valve replacement before, but I'll have to learn how at some point! Dad's done some on cars and I found a tool for removing valves + a selection of compressors in one of his draws. So all good on that front I believe.
Will definitely take those off of your hands That £20 including the valve seals or do you want a little extra for those? Postage wise, whatever's fastest. I'll PM you my address, you let me know how much you want and what payment method and I'll send over the monies  ____________________ 2004 R1 & 2018 XSR900 |
| orac |
| Pete. |
 Pete. Super Spammer
| J.M. |
 Posted: 15:59 - 25 Dec 2012 Post subject: |
Orac, payment sent
Pete, I haven't taken a proper look at the tools yet, just a quick glance. He seems to have two large C clamps which look extremely similar to the ones I saw in a video of someone working on the GS500 engine.
Here's the one they used in the video to compress the valve springs:
https://cdn.bikechatforums.com/files/valve_spring_compressor_001.png
I'll fire the old laptop up to find the rebuild video I downloaded. ____________________ 2004 R1 & 2018 XSR900 |
| Pete. |
 Pete. Super Spammer
 Posted: 17:04 - 25 Dec 2012 Post subject: |
Yeah that one has the extension on the bottom for reaching inside the well of the head. It's fixed by the bolt that the guy's left thumb is pointed at. ____________________ a.k.a 'Geri'
| J.M. |
 Posted: 17:43 - 25 Dec 2012 Post subject: |
Oh yes, I see it now  ____________________ 2004 R1 & 2018 XSR900 |
The last post was made 13 years, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
