| Alpha-9 |
 Alpha-9 Super Spammer
 Posted: 14:47 - 24 Dec 2012 Post subject: CG Bogger |
Hi Hi
Me again
Trying to get this random CG going nice while I sort my YBR out
It's been sat for a year and the battery is dead, no problem as it's a CG you can take the battery out and it'll be fine, my housemates is equally dead and his is running nice and smooth
I can start it and get it idling just about after some fingering of the choke (which i'm very much not used to, touchy things)
Once it's warmed up I can give it throttle and it shits out a load of smoke, but otherwise a tiny amount of throttle kills the engine, depending on the choke, only seems to work on half choke
The problem is with any load on it giving it any throttle bogs it until it stalls, if you use a tiny bit you can just about keep going, I had it stop as I was testing it out and bump started it a few times, surprised how well bump starting works, nothing like my ybr!
I'm thinking the carb needs to come off and the pilot jet needs cleaning...but I don't know wtf that is
The guys had the rocker off at some point as it's got bright orange gasket seal crap around it, it sounds quite 'clicky' so i'm eager to do the clearances again on it, as long as the bolts don't snap and shit, already took the gear lever off to look at the front sprocket and snapped the bolt holding gear lever on.. I have discovered if bolts are brown and rusty they are a cunt to get off, if they are white, they're gonna snap!!
ACF50 grease is awesome by the way
Anyway, it's interesting to me as i've not had a carbed bike and I like attempting to fix stuffs
I've changed the spark, changed oil and checked fuses etc and played with idle times and choke, not done fuel mix yet though but not sure if that's the problem
Purely a carb issue? ____________________ Fzr-600 1999 |
 ..... Quote Me Happy
| Alpha-9 |
| Alpha-9 |
| monkeyman |
 monkeyman Scooby Slapper
| N cee thirty |
 N cee thirty Banned
| Alpha-9 |
| N cee thirty |
 N cee thirty Banned
| paddlesat16 |
 paddlesat16 Crazy Courier
| Alpha-9 |
| kestrel |
 kestrel Nearly there...
| multijoy |
 multijoy World Chat Champion
| Alpha-9 |
| multijoy |
 Posted: 21:48 - 24 Dec 2012 Post subject: |
Mine (a '98) was down for off (as in no choke action), middle for half, up for full.
This any use? ____________________ '11 CBF1000A, '99 C90, '98 CB500
| Alpha-9 |
| crazymotorbik... |
 crazymotorbik... Nearly there...
 Posted: 22:05 - 24 Dec 2012 Post subject: |
Hey,
Here's a quick diagram of the carb i found on google:
Your carb may differ slightly (like mine did) but the layout is the same.
https://i49.tinypic.com/dg302q.jpg
Carefully unscrew the pilot jet and main jet. Next boil a pan of water and drop them in for 10 minutes. A rolling boil is best as they will be bounced about. You'll be quite surprised how much crap this loosens.
This will not damage the jets.
Remove them from the water and blow the jets through with compressed air. This will remove most of the water and any crap that's left. If you want them squeaky clean squirt some carb cleaner through and then blow through again with compressed air.
My CG125 is finally running lovely again. Starting even from cold is much easier with no hesitation when pulling away.
Hope this helps,
Shaun. |
| Alpha-9 |
 Posted: 14:48 - 26 Dec 2012 Post subject: |
Isn't there a way to clean it without taking it off?
I'd rather not as I can see myself losing all the bits and not being able to put it back together again!
Did valve clearances today and took the air filter out and eyed it all up, seemed fine, put it back together better than it was
Valve clearances were way out and that seems to have sorted it's ticking
Took it round the industrial estate and still bogging though
It reminds me of my YBR when the battery was dead and spark fucked, that low down struggling grunt ____________________ Fzr-600 1999 |
| J.M. |
 J.M. World Chat Champion
| kestrel |
| Alpha-9 |
 Posted: 15:42 - 26 Dec 2012 Post subject: |
I went out to eye it up and to play around with the fuel mix...annnd it's raining
And yes JM that's what I said
Yeppers, will just man up and go for it then! ____________________ Fzr-600 1999 |
| kestrel |
| Alpha-9 |
| N cee thirty |
 N cee thirty Banned
| crazymotorbik... |
 Posted: 20:09 - 26 Dec 2012 Post subject: |
If you get stuck I'll send you some more scans and instructions from *erhem* Google
To be honest it really is easy. I had the carb off in minutes. Only thing i really needed to know was how to setup the accelerator pump. However even that's a piece of p*ss.
Cheers,
Shaun. |
The last post was made 13 years, 302 days ago. Instead of replying here, would creating a new thread be more useful? |
