| Dean-J |
 Dean-J Crazy Courier
 Posted: 23:00 - 24 Dec 2012 Post subject: Nitro X fuel commanders.... |
These:
https://www.ebay.co.uk/itm/NITRO-X-FUEL-COMMANDER-POWER-CHIP-FOR-FZ6-FZ6N-S2-FAZER-600-04-now-/390515473379?pt=UK_Motorcycle_Parts&hash=item5aec893be3
I know i know, resistors in a box jobby, but what i was wondering is if they are a changeable combination of resistors in order to select between the 15 "maps", then could one actually be used to modify the fuelling enough to obtain a correct AF ratio?
I mean the car ones are basically a single resistor ( or 2 smaller ones if they want to look flashy!) which give the ecu a super low temp reading and so add a heap of fuel into the mix - in most cases too much and so negating the possible benefits by the risk of long term damage.
But if with these you can actually select from 15 differing levels of resistance and therefore fuel increase, is it actually possible that you could get ( or get as close to as possible) the right increase for your bike/mods etc?
I KNOW a power commander is a much better tool for the job, am just curious as to how plausible one of these would be as a budget alternative if it was fitted and set on a rolling road?
And no, i dont want an electric supercharger thanks!  |
| uberkron |
 uberkron Crazy Courier
| Dean-J |
 Posted: 11:17 - 25 Dec 2012 Post subject: |
ok, now i could and probably am wrong here, but surely cold = denser/more air, so fuelling increased to meet the amount of air entering the engine, ign timing adjusted to match the amount of air+ fuel?
Im not looking for a power gain, just wanting the bike to run correctly. Ie not lean. I have removed the Cat, link pipe and factory backbox,baffles etc so my bike is now rather lean, all im after is getting that extra fuel back into the mix as simply as possible as a temporary measure.
I will be looking to replace the entire injection system (batch inj) with a later sequential injection system in the future, and then running a Bazzazz fuel unit with quickshifter,TC etc, but that needs a bit more research yet to determine if its even possible, so really i just wanted a cheap quick fix solution... |
| Rowey |
 Rowey World Chat Champion
| Dean-J |
| Dean-J |
The last post was made 13 years, 293 days ago. Instead of replying here, would creating a new thread be more useful? |
