Raspberry Pi people...help
Formerly known as
P.
PostPosted: 21:33 - 25 Dec 2012    Post subject: Raspberry Pi people...help Reply with quote
Got my pi today Very Happy
I do not have a HDMI capable monitor, so I've plugged into TV, booted to debian and all is well.
I now want to RDP to it, I need to plug directly into my superhub, but before I bring it into this room I need to set the IP address to something static.
How does one go about that... do I need to do it in terminal Thumbs Up
bladerunner
PostPosted: 21:57 - 25 Dec 2012    Post subject: Reply with quote
Have a look on the pi forum. Probs get a better informed reply if it's not already been asked before!
Formerly known as
P.
PostPosted: 22:26 - 25 Dec 2012    Post subject: Reply with quote
I have Laughing
They just jabber on about using another program, currently.. it has no net connection so I can't apt get anything to allow me to do this. Laughing
el_oso
PostPosted: 22:52 - 25 Dec 2012    Post subject: Reply with quote
not sure of the default notepad application of Pi debian. So not 100% sure if this will work
open terminal
login as root
Code:
su -i
open text editor program, usually something like nano or gedit
Code:
*insert name of text editor here i.e. nano or gedit* /etc/network/interfaces
should then open up a new window with some config options
Code:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inte loopback
#The primary network interface
auto eth0
iface eth0 inet static
address 192.168.0.101
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
gateway 192.168.0.1
here you can change 'address' to static ip of your choosing
Duke 390
Car: Jeep Wrangler 4.0L
Formerly known as
P.
PostPosted: 22:57 - 25 Dec 2012    Post subject: Reply with quote
My Pi refuses to acknowledge that the interfaces folder exists.
I can ls -lh and see the folder listed there... but I can't cd etc/network/interfaces, it just tells me it doesn't exist Brick Wall
Formerly known as
P.
PostPosted: 23:18 - 25 Dec 2012    Post subject: Reply with quote
OK, settings set, I can ping my PC but not my router...nor can I browse Laughing
chrisw
PostPosted: 23:27 - 25 Dec 2012    Post subject: Reply with quote
That's because it's a file not a folder Laughing
Formerly known as
P.
PostPosted: 01:24 - 26 Dec 2012    Post subject: Reply with quote
I know..perhaps it was the nap I took before having a look at the pi that caused me to post that, but yeah.. it wouldn't let me use nano on it. Laughing
Either way, just fresh installed, perfectly fine to access that file, changed stuff, set DNS in the other conf and voila. Net access.
Now its sitting on my network as an FTP/Web server. boom town.
PostPosted: 12:04 - 26 Dec 2012    Post subject: Reply with quote
Quick note that if you're running off of a SD card then you'll want to be sure that it's not doing unnecessary writes. If you're using Raspbian then the root mount should already be noatime, and /var/log, /var/tmp and /tmp (and possibly others) can be mounted as ram drives, unless you've got a passion for keeping logs.
cat /etc/fstab
proc /proc proc defaults 0 0
/dev/mmcblk0p1 /boot vfat defaults 0 2
/dev/mmcblk0p2 / ext4 defaults,noatime 0 1
here on, use dphys-swapfile swap[on|off] for that
tmpfs /var/log tmpfs nodev,nosuid,size=20M 0 0
tmpfs /var/tmp tmpfs nodev,nosuid,size=20M 0 0
tmpfs /tmp tmpfs nodev,nosuid,size=20M 0 0
The last post was made 13 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 60.83 Kb
