| scorps |
 scorps World Chat Champion
| pinkyfloyd |
 pinkyfloyd Super Spammer
 Posted: 22:36 - 27 Dec 2012 Post subject: |
When it comes to wiring a plug I'd be able to tell you how its done.
When it comes to house wiring its a whole different ball game and if you are not sure then the best thing to do is:
https://2.bp.blogspot.com/--IkemBas1R4/TrJrc0MnwDI/AAAAAAAAAOI/y3jSXf09TGY/s1600/electrician.jpeg
Would hate to have that avatar of yours change to "things I said!" ____________________ illuminateTHEmind wrote: I am just more evolved than most of you guys... this allows me to pick of things quickly which would have normally taken the common man years to master
Teflon-Mike:I think I agree with just about all Pinky has said. |
| scorps |
| gfrancisdev |
 gfrancisdev Nova Slayer
| stinkwheel |
 Posted: 23:35 - 27 Dec 2012 Post subject: Re: Wiring a new light fitting. |
Remember that with lighting, switch off does not necessarily mean it isn't live. Always isolate at the consumer unit. A black can be live.
All earths go together.
One red, two black seems a tad odd. You are missing cables because three core + earth is usually two red and one black. I'd have a pull on them and see what tangled nighmares descend from the plaster (or if it's upstairs, pop up into the loft and have a look).
I would expect either one twin and earth cable coming down into the ceiling rose from a junction box above the ceiling OR I'd expect three twin and earth cables coming into the rose (loop in, loop out and switch).
In the former case, I'd put brown to red and blue to black. In the latter case, I'd put all the reds together. The loop in and loop out blacks and the blue together and the switch black to the brown.
Anyway. Attached is my diagram of what SHOULD* be happening from where I put new lights into my bedroom recently. Doesn't all have to be happening in the same junction box/rose though. Ignore the switches, it's a double switch setup but the wiring into the rose is the same.
*Should and is are two different things. It's red and black, it's been up there a long time and any Tom, Dick or Harry could have been "at" it.
EDIT: Tom, Dick, Harry or gfrancisdev.
https://www.bikechatforums.com/download.php?id=87211 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| scorps |
| oldpink |
 oldpink World Chat Champion
 Posted: 23:56 - 27 Dec 2012 Post subject: |
older house wiring can be a nightmare and sometimes not what you expect
bit late now but recently I've taken to using my mobile phone camera to take pictures
if I'm removing old fittings and replacing them as the colour codes arn't always what they should be
also I always have a test meter with me to check circuits or for live wires
not exactly a blonde moment, thats an issue most people would struggle with  ____________________ I have become comfortably numb
Theory & hazard 24-may 2016, CBT 8th June 2016, MOD 1 2nd Aug 2016 Mod 2 2nd-Nov 2016 - Current bike CBR 600 RR |
| stinkwheel |
| oldpink |
| pike |
 pike Nova Slayer
 Posted: 07:07 - 28 Dec 2012 Post subject: |
Did you sort this out?
In theory.....
Ordinarily you would have 2 x twin and earth. The two red wires would be a live loop (coupled together). One black wire would be the neutral, the other black wire would be the return live from the Switch (line). All earths together in a block.
New light fitting:
Connect all earths together (green and yellow)
Connect switch line black live return to the brown. (place red sleeving over the black switch line cable)
Other black cable is the neutral which connects to the blue.
Edit: Image added
https://www.flameport.com/electric/lighting_circuits/ceiling_rose_end_oldcolours_T.png
| scorps |
| drzsta |
 drzsta World Chat Champion
 Posted: 10:51 - 28 Dec 2012 Post subject: |
Connector block both reds they are the loop in/out
One black is neutral - other is Sw Live.
Depending on what sort of light it is most will run fine with reverse polarity though
You don't need a tester, if the two don't work one way - then swap them round!
If that dosnt work it's a faulty fitting. |
| cimbian |
 cimbian World Chat Champion
 Posted: 10:53 - 28 Dec 2012 Post subject: |
One of the blacks is switched-live and generally has a piece of red tape on it to indicate so. The other red and black are the loop-in system.
If you are unsure then pay someone to do it for you. ____________________ 22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker |
| drzsta |
| scorps |
 Posted: 18:25 - 28 Dec 2012 Post subject: , |
sorted it all, the light is faulty so Ive just put the original back. As my grand daughter managed to smash one of the glass pieces to the horrendous chandelier I have told my daughter she can have a bloody lamp shade like everyone else. oh and I have tagged the switch wire. ____________________ Do not presume that I am male. |
| cimbian |
 Posted: 19:39 - 28 Dec 2012 Post subject: Re: , |
| syl |
 syl World Chat Champion
 Posted: 23:53 - 28 Dec 2012 Post subject: |
What colour cables are in the lightswitch?
If red, likely that the red wire in the light is the switched live and the two blacks are the neutral loop in/out.
If black, it's wired up weird. ____________________ Current bike: Kawasaki Z750S |
| calum17 |
 calum17 Brolly Dolly
| cimbian |
| pike |
 pike Nova Slayer
| cimbian |
| scorps |
| J4mes |
 J4mes World Chat Champion
| drzsta |
| scorps |
 Posted: 22:53 - 29 Dec 2012 Post subject: , |
I know James which is why Im particularly vigilant, I dont however believe in paying for a professional to do something that Ive always managed to do before all this health and safety stuff came in. I would have phoned one of my electrical colleagues had it not been the Christmas break. I will not touch gas though. I think this house is RCD but it hasnt had the latest refurbs that our company deal with so not all the wiring has been upgraded yet. Try explaining this upgrade to a tenant whos moaning that their cooker worked perfectly fine for 30 years, when youve gone from B to D  ____________________ Do not presume that I am male. |
The last post was made 13 years, 325 days ago. Instead of replying here, would creating a new thread be more useful? |
