| Benno |
 Benno World Chat Champion
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| Benno |
| Nexus Icon |
 Nexus Icon World Chat Champion
| Benno |
| Chalky. |
 Chalky. World Chat Champion
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 21:34 - 28 Dec 2012 Post subject: |
think the fiats are flimsyer,freinds newish panda had front right cross member\Engine mount pop of clean,eight spot welds popped when pottering along,not sure if seat engineering has a lot of volkswagon in it. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Benno |
| Shaft |
 Shaft World Chat Champion
 Posted: 22:23 - 28 Dec 2012 Post subject: |
Forget the FIAT, sounds like it could be suffering, or starting to suffer, from the gasket failure that is a common affliction; it can be fixed, but there's no knowing how long it will last and, by the sound of it, you aren't in a position to fix it yourself, so it's going to cost you.
The Ibiza is a pretty solid car, just check on when it last had a timing belt and water pump (you should change them together) as it should have had at least one change by now, probably in the last 10K.
If it hasn't been done, budget for doing it, as failure will be terminal. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Misc |
 Misc World Chat Champion
| 0l0dom0l0 |
 Posted: 22:34 - 28 Dec 2012 Post subject: |
Go for the seat and check the timing belt as stated
They share most of the components with VW, just are assembled in a different place ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| jimspeed |
 jimspeed World Chat Champion
| andyscooter |
 andyscooter World Chat Champion
| Benno |
 Posted: 23:37 - 28 Dec 2012 Post subject: |
Good advice, thanks
Hopefully will be able to test drive the Seat tomorrow, depends on whether the guy is in at the garage, will definitely ask about timing belt and how much it could cost to replace. Hopefully he'd do it as part of the service before I take it home. ____________________ I'm autistic. That means I'm smarter than you. |
| 0l0dom0l0 |
 Posted: 23:42 - 28 Dec 2012 Post subject: |
| Benno wrote: | Good advice, thanks
Hopefully will be able to test drive the Seat tomorrow, depends on whether the guy is in at the garage, will definitely ask about timing belt and how much it could cost to replace. Hopefully he'd do it as part of the service before I take it home. |
It's about £300 ish fitted to give you an idea. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| yaigi |
 yaigi World Chat Champion
 Posted: 01:29 - 29 Dec 2012 Post subject: |
FIAT - Fix It Again Tomorrow, as I believe they are known in the motor trade  ____________________ What would you do in life, if you knew you could not fail?
Currently own - Fazer 600, 2000, Red. (But no riding as baby on board atm) |
| Shaft |
 Posted: 01:43 - 29 Dec 2012 Post subject: |
Originally, Fix It Again Toni, with reference to Italian mechanics, every FIAT dealer seemed to have one.
Right up there with Fix Or Repair Daily, which was OK when you could buy a cheap part for a Ford in very street corner spares shop, not so good now, when they are still just as prone to breaking, but the cost of parts has gone up considerably.
Pattern thermostat for a 2ltr Mondeo, 120 quid?
In the words of Eddie Murphy, getthefuckouttahere! ____________________ Things get better with age; I'm close to being magnificent........
| D O G |
 D O G World Chat Champion
| Shaft |
 Posted: 02:00 - 29 Dec 2012 Post subject: |
Trouble is, when I needed one, Euros didn't have it, so it was Ford (£140) or another supplier for 20 quid less.
Bottom line is, modern Fords drive very well, but fuck em if they go wrong, you'd be better off with a BMW or Merc. ____________________ Things get better with age; I'm close to being magnificent........
| stinkwheel |
| ocatoro |
 ocatoro World Chat Champion
 Posted: 02:46 - 29 Dec 2012 Post subject: |
i have one of those ibizas with that engine. parts specific to this engine seem to be expensive for some reason. spark plugs for this model are £45 for a set whereas the better 16v engine in the skoda fabia and some polos are like £4 each. i've just changed the shocks too, which were also more than 4 times the price of a pair for my t4 van, EACH....
so that's something to consider.
but hey, it IS a VW polo, it's not "quite a bit vw"... the only difference are the badges, styling and dashboard design. and even then, if you pull the seat badge off, it has a VW and audi badge on the back of it.
very reliable and built to last, if that's what youre into, less prone to rust than the older vw's, but not immune like the fiat should be (i believe they started galvanising their cars in the late 90s?)
oh, and another thing, the ibiza is crap on fuel. the fiat will knock it for 6 in that regard too.
despite the seat probably being a better, and more reliable car... i'd go for the fiat in your situation... or find something else. ____________________ CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None but shed project H100 (first bike )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600 |
| haroman666 |
 haroman666 World Chat Champion
| Frost |
 Frost World Chat Champion
| st3v3 |
 st3v3 Super Spammer
| Nexus Icon |
The last post was made 13 years, 196 days ago. Instead of replying here, would creating a new thread be more useful? |
