Following on from Scorps' light fitting thread...
hellkat
PostPosted: 21:10 - 30 Dec 2012    Post subject: Following on from Scorps' light fitting thread... Reply with quote
... I'm about to instruct my bloke to put spotlights up in my bathroom and kitchen instead of these STUPID fluorescent lights.
Bathroom has one of those stupid round fluorescent lights, which has given up the ghost and flickers annoyingly. The last time it did that (some 18 months ago, possibly less) I got annoyed and bought a whole new bulb for it, but now I am annoyed at having to shell out for the same sort of bulb already-so-soon and want spotlights instead Shocked
The kitchen has a fairly standard long-style one, which gave up the ghost almost a year ago, I tried to replace it, and even tried some of those "starter" things but everything blew, so I have been "managing" with a tap-on tap-off dimmable bedside lamp Brick Wall for FAR too long.
I just want a single three-spot (adjustable) lamp in each room.
Any good hints, much appreciated.
oldpink
PostPosted: 21:18 - 30 Dec 2012    Post subject: Reply with quote
local B&Q Thumbs Up
fitting should be simple Thumbs Up
fatpies
PostPosted: 21:25 - 30 Dec 2012    Post subject: Reply with quote
Wiring in a new light isn't difficult.
A friendly leccy told me they flicker like that when something called the ballast goes.
Which meant a trip down B&Q, £20 over the counter and it was replaced with a whole new unit. Which I think was three wires.
Gypos even stole the old light fitting when I put it round the back so I didn't have to go to the tip.
Poseidon
PostPosted: 21:36 - 30 Dec 2012    Post subject: Reply with quote
Fluorescent tubes > Spot lights.
Well, in my opinion anyway. We have a three bulb spot lamp thingy in the kitchen and it constantly causes a shadow. I've tried pointing them every which way and nothing cures it. The little halogen bulbs blow fairly regularly causing even more shadowing. Just spent 15quid getting a pack of new bulbs. Wonder how long these ones will last. All my previous houses have had a fluorescent tube and there was no shadowing etc and I've only had to replace a tube once.
Just replaced spot lamps in the bathroom with a "ball" type light and it immediately feels lighter and brighter in there. Less shadowy etc. Took me less than 5 minutes... One minute to remove the old light and disconnect it. One minute to place the new fitting correctly, even managing to make use of the previous holes. about 90seconds to fiddle the wires into place and secure them correctly and about 60 seconds to get the whole lot screwed up into place. This is the kiddy:
https://homebase.scene7.com/is/image/homebase/292127_R_Z001?$TMB$&wid=312&hei=312
£7.79 from homebase.
Obviously remember to isolate the mains before doing this sort of work. I had a jolt from the mains when I was around 10years old and I trembled for 3days!
1977 Honda CG125
PostPosted: 21:55 - 30 Dec 2012    Post subject: Reply with quote
They are easy enough to change as long as you remember where all the wires go and put them back in the same place as they were.
All the actual light fittings have two wires plus an earth. There can be a variable number of wires sticing out from the ceiling to connect them to but as long as you leave them all connected up the way they were, you're laughing.
The important thing to remember with lighting is just because the switch is off, doesn't mean the wires aren't live. Turn the lighting off at the fusebox.
Re flourescent tubes. As has been said, flickering like that probably means the ballast coil is dead and you need to replace the whole light unit.
You could just replace it. They are cheap. That said, splash out a little more for one with electronic ballast and it'll last longer. In my experience, those three way spots are ok in a bathroom but not so good by themself in a kitchen without some other additional lighting too.
I'd be more inclined to go for 12v halogen track lighting in a kitchen. Although this does mean you have to hide a transformer for it somehwere up in the ceiling. You can clip as many lights to the track as you like (within reason).
drzsta
PostPosted: 22:02 - 30 Dec 2012    Post subject: Reply with quote
A flo is SOmuch less hassle than changing GU10's every 5 mins. Fuck me your gonna have a shock if your making a meal of buying one bulb for your 2D bulkhead.
Unless your going LED ofcourse, which even they are up for debate. (Spot or ambient)
HTH Thumbs Up
hellkat
PostPosted: 23:23 - 30 Dec 2012    Post subject: Reply with quote
HTH Thumbs Up
I have no idea what I am doing.
I just pick something and say "Stick that up, it looks okay" - not the most patient of householders. Hate when things don't work, just make the goddam thing work, thankyouverymuch, LOL.
But yeah, I am a bit leery about the price of GU10s, as I checked the price when I was in Wickes-the-dickheads today.
I thought those "2D bulkhead" lights (seeing as you are being technical about it) were supposed to last "forever". The last one I had was in there when I moved in and didn't blow for over 4 years. This one has gone in 12-18 months.
Getting a bit tired of this flat, TBH, its as if its been jinxed and everything is "going", let alone what never got done properly before (damp!), despite much footstamping on my part. My housing association are right in the middle of tenders for the maintenance contracts (I was on the resident panel, meh, haha, yeh right, big input, not) and so the outgoing contractors are not wearing themselves out doing too much work before they go.
But thank you (everybody) for your useful advice.
I kinda like the idea of those big round things that Poseidon mentioned, but now I have bought the spots. Oh well, Christmas bonuses are for frittering away on pointless items, after all.
At the very least, I'll remember to nag HWMBO about turning off the electric at the fuse box. Cool Thumbs Up Karma
doggone
PostPosted: 23:40 - 30 Dec 2012    Post subject: Reply with quote
I'd be looking at LEDs, but go for the warm tone.
https://www.ebay.co.uk/itm/3-Way-GU10-Halogen-LED-Lamps-Chrom-Ceiling-Spot-Light-Fitting-Kitchen-6W-Bulbs-/230824016262
dgo1212
PostPosted: 01:14 - 31 Dec 2012    Post subject: Reply with quote
HTH Thumbs Up
^^^This^^^
You will, like most people regret buying spotlights, my downstairs is covered in them, if you go through with it don't buy cheap bulbs, I've bought them in the past and one blew after 3 days, last time I bought bulbs I paid £30 for 10 but worth the extra expense, I've also found fitting dimmer switches and only turning them right up when it's needed has extended the buld life massively. The problem with a 3 bulb fitting is when 1 bulb blows it's immediately noticable, amazing how much light you lose from just one of the bulbs, also be carefull when replacing them as they get red hot when in use and take a while to cool down. Fortunately I only have 15 GU10's in this house, my last house had ceiling fitted spots throughout, over 40 of them!
PostPosted: 01:31 - 31 Dec 2012    Post subject: Reply with quote
Trouble is, it's still a very cold light compared to a filament bulb.
LED bulbs are not -contrary to what the manufacturers would have you believe- infallable. I splurged on LED bulbs for my kitchen spots and one of then failed within 6 months. It was an expensive, named brand one too (osram as I recall). Replaced it with a standard halogen one and immediately noticed how much more pleasant the light was so I switched them all back to halogen. Buy in bulk and they are cheap enough.
Considering trying SMD bulbs rather than the usual domed LED ones, I'd be interested to hear how the light quality compares.
@ hellkat. Not sure if it's relevant but standard fluorescent tubes do not like the cold. If your kitchen gets very cold in the winter, they won't last as long. Electronic ballast isn't as badly effected.
I was disappointed in my 3-way spots but I will be keeping them. I just might add some additional rail lighting to deal with the ambient light. Then I can put a spot each onto the worktop, cooker and sink.
Cunnington
PostPosted: 19:33 - 01 Jan 2013    Post subject: Reply with quote
@Stinkwheel
I got some warm white 60 SMD GU10 bulbs off fleabay at around £14 for 4 about 4 or 5 months ago. They are the closest I've come to halogen, in terms a useable output with a decent beam spread and reasonable luminescence, but they still fall short of the luminescence of a 50W halogen bulb. I found that the 3x1W bulbs had a reasonable output, but too focussed, which the spread of the SMD ones has managed to overcome. 4x4W bulbs in the kitchen is much easier on the wallet than 4x50W halogen.
One has failed, but at that price, I'm not overly bothered - they are cheep enough to carry a spare.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
Ichy
PostPosted: 20:03 - 01 Jan 2013    Post subject: Reply with quote
I have three 4w SMD bulbs in the kitchen and another three outside.
They are bright enough and very white but that is fine by me. I brought them as two packs of four from China for about £11 per pack. I've had one go in three months. I emailed the seller and he offered me either £5 back or another four for a fiver.
I usually prefer 12v simply because I believe that the transformer helps smooth out the supply to the bulb. I fitted three spotlights on a cable with MR16 bulbs when we moved in here 9 years ago and the first one blew last week. About £7 for 10 off screwfix.
The last post was made 13 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 86.15 Kb
