Wiring in additional items
PostPosted: 14:47 - 31 Dec 2012    Post subject: Wiring in additional items Reply with quote
Hey,
Planning to disappear to Spain next year, I fancy wiring in some power outlets on the CBR... (might pack a spare reg/rec too.)
Ideally I want to make it as per the diagram attached.
I need a charger for my GoPro/sat nav, phone and tablet/camera, all of which have different connectors (phone = small plug, sat nav = USB, tablet small transformer)
Is there any disadvantages doing it this way/would it work. I only intend to have one thing on charge at a time whilst riding.
The big red switch on the side is to turn the entire thing off... just incase.
Thanks!
weasley
PostPosted: 14:53 - 31 Dec 2012    Post subject: Reply with quote
Would they not all charge off of a generic USB charger outlet with the appropriate cable for each? You could wire in a simple 'cigarette lighter' type socket then get a USB power adaptor and just take the cables you need.
PostPosted: 15:01 - 31 Dec 2012    Post subject: Reply with quote
Only the GoPro is USB, I cannot find USB for the rest, otherwise yes, I would do that.
Also...the rear of the switches...would this work?
Just thought... probably put switch on the negative side and stick a fuse on the + side?
PostPosted: 15:37 - 31 Dec 2012    Post subject: Re: Wiring in additional items Reply with quote
Fuse and switch on the positive side I'd have thought.
Also have it directly connected to the battery, but with a relay connected to something that's only on when the engine's running - no drained battery.
Me, I cut all the cigarette lighter bits off and used much smaller automotive style plugs, so everything took up less space. Wired in 3 sockets front and 3 back on my KTM.
As I was doing off-road, also took a pump which can be plugged in to the same.
PostPosted: 15:39 - 31 Dec 2012    Post subject: Reply with quote
Was intending to relay to the rear light.. I have access to all the wires currently so its a bonus Thumbs Up
PostPosted: 16:15 - 31 Dec 2012    Post subject: Reply with quote
Presuming your lights are wired on all the time? Otherwise it'll only work when the lights are on.
I'd personally go for the rear brake switch to trigger the relay. Then if it all goes tits-up you only lose one brake light switch and not your tail light.
PostPosted: 16:18 - 31 Dec 2012    Post subject: Reply with quote
Very good point.
Yeah, lights always on, 03 CBR Thumbs Up
I assume I just need to turn the bike on, find the 12v feed to the rear brake switch, wire in a relay to that, earth and my device?
PostPosted: 16:22 - 31 Dec 2012    Post subject: Reply with quote
How to wire in an electrical device using a relay
But this image sums it up:
https://i48.photobucket.com/albums/f216/stinkwheel/drumbrake/relay.png
PostPosted: 16:30 - 31 Dec 2012    Post subject: Reply with quote
Boss Thumbs Up
raesewell
PostPosted: 18:43 - 31 Dec 2012    Post subject: Reply with quote
Why not try this. I can plug my phone and sat nav in without having all the plugs hanging around. Fairly easy install. You would need to get some cheapo car chargers and cut the cigar lighter bit off and wire it to the 5V convertor
Marmalade
PostPosted: 18:49 - 31 Dec 2012    Post subject: Reply with quote
I always make sure I have one cigi socket wired direct (via fuse) to the battery for leaving a phone/camera/? On charge when off the bike.
I also use it connected to a 5metre cigi extension lead i made so I can have phone on charge overnight in my tent and run anything else I need to.
Yoyo This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
The last post was made 13 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 73.09 Kb
