Car air blower dial snapped
nathandenniso...
PostPosted: 18:45 - 31 Dec 2012    Post subject: Car air blower dial snapped Reply with quote
The dial that you alter the speed of the air blowing from 0-4 was getting stiff, it eventually snapped and is now just spinning. It's stuck on 2 or 3 which isn't a problem as I can turn the temperature to neutral so it's not to cold or hot, if it needs to be fixed I'll fix it but does it need fixing or will it not effect the battery too much? That's the nay side effect I can see from not being able to turn it off? Car is a 54 plate fiat punto
djr
PostPosted: 19:16 - 31 Dec 2012    Post subject: Re: Car air blower dial snapped Reply with quote
Pull the nob off and use pliers, the hot/colds failed on my car, it's just the plastic "nob" that's split.
carvell
Scuttler
PostPosted: 19:18 - 31 Dec 2012    Post subject: Re: Car air blower dial snapped Reply with quote
Why are you worried about the battery?
Assuming you don't make a habit of sitting in your car for hours with the engine off, it won't affect the battery in any meaningful way - it's fine from that point of view.
Yamaha TDM 850
nathandenniso...
PostPosted: 20:00 - 31 Dec 2012    Post subject: Reply with quote
I have no idea how much it would effect the battery if it was on constantly for a while until I fix it but if it's not a problem I won't rush
The last post was made 13 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 40.47 Kb
