tomos tx50 oil
alex2013
PostPosted: 18:02 - 01 Jan 2013    Post subject: tomos tx50 oil Reply with quote
hi there i got this little motorcross bike for pennys, it starts,goes etc(just)
my problem is when i started to drain the oil it was like black and it stunk of petrol, came out as if it was water..am i right in saying it should be transmission fluid?
i beleive they never sold this little bike in the UK either
thanks for any help
mospeed
PostPosted: 18:53 - 01 Jan 2013    Post subject: oil Reply with quote
I think the engine in this bike is the A35 type.
you need to refill it with 10w30 oil, 3ccm is quoted, but please check this out first.
hope this helps
alex2013
PostPosted: 21:05 - 01 Jan 2013    Post subject: Reply with quote
Yeah I read that, it's stamped A5 which means A35 apparently
What would u say is that cause for the petrol smelling oil?
Thanks
mospeed
PostPosted: 00:06 - 02 Jan 2013    Post subject: Reply with quote
Sounds like fuel from the crankcase has seeped in. May be a seal gone. I would change the oil and run it for a while, but keep an eye on it. If you still have a problem, either I or someone else will be sure to advise.
Dave-the-rave
PostPosted: 00:19 - 02 Jan 2013    Post subject: Reply with quote
I'd change the filter as well.
alex2013
PostPosted: 02:33 - 02 Jan 2013    Post subject: Reply with quote
ahh, i was afraid someone would say that, i will change the oil and see how it goes, is there a way of knowing if the seal has definately went? i.e leaking etc, as the oil was as low as it could possibly get. i only just got this in exchage for a case of beers so dont know much history Sad
PostPosted: 13:40 - 02 Jan 2013    Post subject: Reply with quote
If a gearbox side crank seal has gone it usually draws oil in through it resulting in blue smoke and sooty plugs.
If the other side has gone you can get a loss of vacuum resulting in poor starting and sometimes blowpast onto the alternator.
alex2013
PostPosted: 14:49 - 02 Jan 2013    Post subject: Reply with quote
hi
im not sure what side it is,just when i drained the oil out it was like black petrol with very little oil in it.yes it was smokey but running premix i would sort of expect that??
thanks
petrolhead69
PostPosted: 17:44 - 02 Jan 2013    Post subject: Reply with quote
check its not got a sticking carb float if its been sat for a while maybe the crankcase filled with petrol at some point.
evoboy
PostPosted: 23:09 - 02 Jan 2013    Post subject: Reply with quote
This would be where i would first look.
APT Motorcycles
alex2013
PostPosted: 22:15 - 03 Jan 2013    Post subject: Reply with quote
I think that may the issue, I've filled it back up with gear oil, seems ok not leaking etc, though its quite smokey I may of went overboard with the 2 stroke, and there's black oil coming from exhaust pipe is this quite normal for a bike that's lay for a while ?
Thanks
The last post was made 13 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 65.72 Kb
