| jay12329 |
 jay12329 Dr. Evil
| Robby |
 Robby Dirty Old Man
| neon |
 neon Nitrous Nuisance
 Posted: 21:31 - 08 Nov 2004 Post subject: |
pick the bike up and give it a good ol' shake  |
| Claud 14.7 to 1 |
 Claud 14.7 to 1 World Chat Champion
| STUNTMAN2000 |
 STUNTMAN2000 Two Stroke Sniffer
 Posted: 22:19 - 08 Nov 2004 Post subject: |
Do NOT TRY JUMP STARTING IT !!!
If you bike runs a CDI system, if you use jump leads say from a car then you are gona fry your CDI, the car batt runs around 500ma this will fry your CDI coz bike batt's don't carry anything Like a car one.
Thing you can try is Bump Starting it, if your batt is low and you start it off the button it will turn the engine but may not produce enough of a good spark to light the fuel, this will then cover your plugs in fuel and cause it to "FLOOD".
The best thing you can do is, take the batt off give it a good charge overnight and try it again.
If it don't work pull off a plug lead and stick a spare plug into it rest it against the side of the engine and turn it over, see if it sparks a good "White" Spark, If te spark is blue then it is a little bit weak but should still run fine, if the spark is orange then it is too weak to run when in the engine and is probably breaking down under load.
If you get a white or blue spark, then get a can of WD40 Spray and get someone to spray a good squirt of it into the air intake or up the exaust while you turn the bike over.
WD40 burns more easy and faster than anything, this WILL start your engine if you are getting a spark.
If this works and then stops again when you stop spraying the WD40 then you have a fuel problem.
Get beck to me and I'll tell you how to fix that
Good Luck, and let us know how you get on. |
| Claud 14.7 to 1 |
 Posted: 00:26 - 09 Nov 2004 Post subject: |
Oh cak sorry I meant push start it. Push start it .
Although I have jumped mine off a car, and its fine. A few times now.
Always get them mixed up because you have to run with the bike then jump on it, then release the clutch.
Yeah push start is safer. And very effective in my experience. |
| STUNTMAN2000 |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
| Wave2k |
 Wave2k G's Stalker
| Demonic69 |
 Demonic69 The Pink Rhino
| jay12329 |
 jay12329 Dr. Evil
| Big Pete |
 Big Pete Spanner Monkey
| map |
 map Mr Calendar
 Posted: 16:29 - 09 Nov 2004 Post subject: |
Glad you got it started
Just wanted to add a check for the future - make sure your kill switch hasn't been knocked.
It can be easily done manoeuvering a bike around.
It also can be very embarrassing  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Robby |
 Robby Dirty Old Man
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 00:50 - 10 Nov 2004 Post subject: |
I've jumped a few bikes off cars and car batteries. An electronic or electrical device will only draw the power/amps that it needs. As long as the voltage is right then the amps make no diff.  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| Fortuna |
 Fortuna World Chat Champion
 Posted: 02:58 - 10 Nov 2004 Post subject: |
| STUNTMAN2000 wrote: | Do NOT TRY JUMP STARTING IT !!!
Sorry but a car battery would not fry your bike if it's a 12V system.
Current is drawn as required by any electronic device if the voltage is the same. The higher Amps/Hour mean if you jump it from a car battery it will last longer. I have a high amperage car battery in my shed for those cold mornings when the bikes being a bitch. Jump a car from a bike battery though and it will melt.
Current is pulled and not pushed. |
| stryker |
 stryker Brolly Dolly
| STUNTMAN2000 |
 Posted: 11:46 - 11 Nov 2004 Post subject: |
Hmmm.....Maybe I am wrong then, I am only talking from past experiance and trying to stop someone else from breaking theirs.
So if you have a 12v batt on your bike and you jump it off your car 12v... So you now have 24v going into your bike why not just have a 24v batt on the bike in the first place.
Also if your jumping off your car while the engine is running and it's alternator is kicking out (17 for example) so not only are you running double the volts it's supposed to be but the power from your car's alt is also pouring straight into your bike and not even going through your regulator / rectifier (That limits your return voltage to the batt)
But instead you are sending the whole lot into your CDI unit ?
Does not seem a good plan to me.
I am not trying to cause an argument here as I am new to the site, but I would like to find out more on this so can we some more opinions please (for and against)
Cheers Guys  |
| Demonic69 |
| Big Pete |
 Posted: 17:15 - 11 Nov 2004 Post subject: |
| STUNTMAN2000 wrote: | Hmmm.....Maybe I am wrong then, I am only talking from past experiance and trying to stop someone else from breaking theirs.
You dont have 24v you have 12v still if you have used the jump cable correctly , the batteries are connected in parrallel (making one larger battery) not series (which would make a higher voltage battery)
| Quote: |
The car alternator reg/rec will limit the alternator output voltage to 14.5 - 16 volts, if your bike battery is dead the voltage will be pulled down as it charges, when it is fully charged the voltage will stabilize at whatever the reg/rec setting is. Dont forget this is still a parrallel conection not a series one.
The bike reg/rec doesnt control the output of the battery, it controls the output from the alternator. ____________________ Trust me, I`m an engineer
GarageOfPower.co.uk |
| Fortuna |
| Fortuna |
| kasandrich |
 kasandrich Trackday Trickster
 Posted: 16:52 - 12 Nov 2004 Post subject: |
I'm afraid the others are right Stuntman2000
!2v is 12v, and as long as you connect up jump leads right (neg to neg, pos to pos) then 12v is all you have, you should not need to run the car to jump a bike. ____________________ Richard
CBR1000FM |
| Ninja |
 Ninja Caption Abuser
| Fortuna |
The last post was made 21 years, 351 days ago. Instead of replying here, would creating a new thread be more useful? |
