A question for the chain gang.
Uncle fester
PostPosted: 21:51 - 01 Jan 2013    Post subject: A question for the chain gang. Reply with quote
Hi I'm still new to all of this and I would like to know what's the best chain cleaner and lube . I've bought a 2005 varadero 125 which had a new chain and sprocket a few months ago but it looks dirty and clogged up to me so I want to vive it a clean . Is acf 50 any good for it?
Tomorrows another day .just as we'll at my age
PostPosted: 21:56 - 01 Jan 2013    Post subject: Reply with quote
Personally on the odd occasions I clean the chain I use old engine oil and a toothbrush.
PostPosted: 21:59 - 01 Jan 2013    Post subject: Reply with quote
Cheap and very effective de-greaser is Paraffin. Old nail brushes, cotton rags...let your imagination go wild.
Cheapo car shampoo to wash off the Paraffin, some use furniture polish on the plastics but I use auto glym a few times a year.
Acf50 is best used before the bad weather sets in (road salt, mud etc)
Keep it off discs and tyres. Best applied to a clean bike with a cotton rag...goes further and you can use the soaked rag over and over...stash in a plastic freezer bag)
Uncle fester
PostPosted: 22:21 - 01 Jan 2013    Post subject: Reply with quote
That's great thanks .ive just ordered a litre of acf50 so I will get busy with a brush cheers Thumbs Up
P.
PostPosted: 22:40 - 01 Jan 2013    Post subject: Reply with quote
Wouldn't use ACF50 on the chain, just the bike, swing arm and visibly frame areas and the front fork area would be nice...
I just use old used engine oil and a toothbrush on the chain.
PostPosted: 22:49 - 01 Jan 2013    Post subject: Reply with quote
As HT said. Parafin is great for removing the crud off the old chain and then wiping with a rag. Make sure you give it a good clean and let it all dry out before adding more oil.
In truth though I never clean my chain in winter. The grease build up helps keep the salt away from the chain. Seems to work anyways.
Andrew_
PostPosted: 22:55 - 01 Jan 2013    Post subject: Reply with quote
Wouldn't acf-50 attract more dirt?
haroman666
PostPosted: 23:15 - 01 Jan 2013    Post subject: Reply with quote
I use White Spirit to clean off and I scrub it with a brush and then wipe it with kitchen roll/blue roll tissue.
I then wipe on car gearbox oil with a paint brush. I never used to use this but upon reading on here and other forums that a lot of people use it, i thought i'd give it a try. It flings off so easily and the chain is dry within 50 miles... So I might go back to using the aerosol tacky wet lube that I used to use.
WetAndCold
PostPosted: 00:32 - 02 Jan 2013    Post subject: Reply with quote
I just spray on degreaser, give it a brush and a rinse. Then spray on some muc-off chain lube.
Once a month if it's lucky Embarassed
Honda CBR600f sport
Cage: 2008 Honda Civic type-R
esullivan
PostPosted: 07:22 - 02 Jan 2013    Post subject: Reply with quote
I do mine once a week lately because I'm commuting every day and it gets dirty quickly with the rain and road spray. I use a (relatively) expensive method, compared with the people doing this with a paint brush and old engine oil.
1. Spray on chain cleaner. Usually Muc Off or similar. Let sit for five minutes.
2. Go over the chain with a brush, lightly, to loosen any dirt and grime. I use a brush designed for this. Search for chain cleaning brush on Amazon. They're cheap. But I'm sure an old, soft toothbrush would be fine too.
3.Wipe chain with an old rag (this is when it starts to *look* clean) and then let sit for 5-10 minutes to make sure the chain cleaner has dried/evaporated away.
4. Spray dry chain lube (again, usual Muc Off, or whatever the local Halfords has this week) on the inside bottom of the chain. I probably put too much on, but I spray liberally, with my left hand, while moving my wheel with the right. I'll go twice around one direction, wait two minutes, and then go twice around the other direction.
5. Leave the bike to sit for at least 30 minutes, but more like an hour or two, before riding again, to let the lube set.
Hope that helps.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
Ribenapigeon
PostPosted: 11:11 - 02 Jan 2013    Post subject: Reply with quote
I wouldent use ACF50 on the chain. Also better just spraying lube on the chain and wait till spring to give it a clean.
trevor saxe-coburg-gotha
PostPosted: 11:47 - 02 Jan 2013    Post subject: Re: A question for the chain gang. Reply with quote
Cheap and cheerful option for cleaner is diesel (apply via old tooth brush) - easier to find than paraffin? At leat ime. As for lube, a good one is the high performance chain lube by Wurth. Not cheap, as such - but is aerosol and seems to have minimal fling. I goes on runny but kind of sets waxy - not sure.
P.
PostPosted: 11:51 - 02 Jan 2013    Post subject: Re: A question for the chain gang. Reply with quote
At nearly 140.9p a litre, old engine oil is far cheaper Laughing
PostPosted: 13:54 - 02 Jan 2013    Post subject: Reply with quote
Yeah - I just found it didn't work as well. I think diesel - despite having a somewhat oily consistency - does have a solvent in it, and that seems to leave the chain much cleaner than old oil. But yeah - the latter is cheaper. Wink
P.
PostPosted: 14:00 - 02 Jan 2013    Post subject: Reply with quote
Chains aren't meant to be clean. Lubricated IMO is far better than just a clean chain.
I've used engine oil since getting a bike and I've got a sports bike chain to 27k and it wasn't all the way back to the adjusters yet Laughing
PostPosted: 14:27 - 02 Jan 2013    Post subject: Reply with quote
Wow that's some going. Fwiw I clean my chain about once every 6 weeks, when grit and shit have clogged it and you can hear/feel the crud grating when you lift it up and down for a tension check. That's when I get busy with the diesel, then give it generous squirts of clean oil after. Yeah that can mean fuck loads of fling, but shit - riding it after that sounds so awesome. Even gear changes are better. It's surprising how much difference it makes tbh.
Rowey
PostPosted: 14:30 - 02 Jan 2013    Post subject: Reply with quote
You need to clean chains periodically as dirt and what ever lube you use combine into a sort of grinding paste.
I tend to just use a non fling waxy type lube once a week or so after a ride while the chain is warm. Stuff like Wurths dry lube is very good. Although I get whatever from the nearest bike shop or Halfrauds if I can't find it. The problem with used oil is it can be acidic and damage the ring seals. It also flicks everywhere.
To give the chain a quick clean I just use some Muc-Off water soluble chain cleaner, stiff brush and hose. If I want to give it a deep clean then I use paraffin first, then Muc-Off ect.
I wouldn't use ACF-50 on the chain. It's not really a lube. It's an anti corrosion treatment. Not to say you've wasted your money, that stuff is great at looking after your bike through winter.
ZX6R C6F.
Alpha-9
PostPosted: 14:40 - 02 Jan 2013    Post subject: Reply with quote
I'd keep ACF50 well away from the chain, i'd be surprised if it DOESNT devour o-rings like no man's business
I use hot soapy water, dry it off and lube
Wurth stuff is good Thumbs Up
ACF50 is pretty dear too
Wurth dry chain lube ftw, also Wurth brake cleaner is fucking excellent, cleaned my drums up nicely
Fzr-600 1999
Rowey
PostPosted: 19:04 - 03 Jan 2013    Post subject: Reply with quote
Alpha-9 wrote:
I'd keep ACF50 well away from the chain, I'd be surprised if it DOESNT devour o-rings like no man's business
I use hot soapy water.
ACF50 claims not to damage rubber or plastics. I've been using it for years now and haven't seen any damage. WD40 causes rubber to swell, but not ACF50.
Hot soapy water, such as fairy liquid contains salt which can cause rubber to crack and your chain to rust.
ZX6R C6F.
sidewinder
PostPosted: 21:40 - 03 Jan 2013    Post subject: Reply with quote
Heating oil cleans chains well Very Happy
The last post was made 13 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.32 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 108.1 Kb
