red light camera
krarkol
PostPosted: 03:38 - 02 Jan 2013    Post subject: red light camera Reply with quote
Was on penwortham way today near preston and was on an NSL and was actually sticking to the speed limit!
Light was green and the roads where dead, so I was pretty much sat at 60, give or take a few mph.
Probably less than 50m away, the lights went orange and changed to red pretty much instantly and then I saw the grey box of doom waiting at the side of the road. I couldn't stop in time so I thought fuck it and gave it a bit of throttle just in case of any traffic coming out (ended up being nobody else at any of the other roads anyway!)
Is there any way of contesting it? The amber seemed way to short and I couldn't slam on the anchors due to the roads being slightly greasy anyway Confused
I know I should be riding to the "conditions" but I had perfect visibility and there were no hazards anywhere around that could jump out and cause me to emergency brake.
Bandit 600 - deaded
Andrew_
PostPosted: 03:43 - 02 Jan 2013    Post subject: Reply with quote
Crying or Very sad your fault, people will most likely say when the traffic lights has been set to green for a long period be prepared to stop. Which you failed to do, there was even a junction ahead as well so you should of slowed down a tad bit for that as well.
krarkol
PostPosted: 03:48 - 02 Jan 2013    Post subject: Reply with quote
They hadn't been on that long, I saw them change to green while I was further down the road about 400-500m away
Bandit 600 - deaded
covent.gardens
World Clap Champion
PostPosted: 03:59 - 02 Jan 2013    Post subject: Reply with quote
Amber timing is standard across all traffic lights, it was probably on longer than you'd like to think. They usually give you a grace period too, so you have probably gone through it more than a second after it changed if you've actually been done. Did you see it flash?
https://pepipoo.com/ as always, they might do something stupid like send the NIP out too late etc.
krarkol
PostPosted: 04:09 - 02 Jan 2013    Post subject: Reply with quote
I didn't see the flash, but I've been doing some research due to the fact if I get an NIP it's bye bye licence!
Typical stopping distance is 73m in dry conditions, highway code states its double in wet. The distance that I was from the lights when it changed to amber, I had 3 seconds to stop from 60mph and there was no way it could be done.
I was roughly inline with the camera as it went to red so if I'm extremely lucky I may have gone way past the line during the 1-2 second grace period, especially as I gave it a handful after I'd come off the throttle before realising there was no way I'd be able to stop
Bandit 600 - deaded
covent.gardens
World Clap Champion
PostPosted: 04:45 - 02 Jan 2013    Post subject: Reply with quote
You've just basically admitted rider error, by admitting you hesitated (came off throttle). If you had just kept going to begin with you'd have cleared it on amber, since you only just went through on red, no? Wink
I doubt you will hear any more about it tbh. Doesn't sound like you would have triggered it.
st3v3
PostPosted: 04:45 - 02 Jan 2013    Post subject: Re: red light camera Reply with quote
You were speeding, simple as.
You didn't know for certain there were no hazards that could have affected your ability to stop in safety in this incident.
Greasy roads and short ambers are no excuse for you failing to accept you were going too fast. Thumbs Up
krarkol
PostPosted: 05:09 - 02 Jan 2013    Post subject: Reply with quote
There was probably a split second or so in my hesitation as I rolled off the throttle to grab the brake, realised I wasn't going to stop anyway and rolled back on. I'd probably slowed down to 55mph at best. Probably got to around 65-70 by the time I was half way across the junction.
I could also see the sideroads clearly and didn't see any traffic, which is why I didn't think the light would change due to the fact I was on a major road.
st3v3, I was on a long straight with no one around and doing 60mph. The road conditions meant my braking distance would be longer but there was no way anything could dive out and cause me to emergency stop.
How bright is the flash? I don't recall there being one Laughing
Bandit 600 - deaded
st3v3
PostPosted: 09:03 - 02 Jan 2013    Post subject: Reply with quote
So you can guarantee there was nothing coming from another direction, heading towards you that was also amber gambling?
AlexW
PostPosted: 09:22 - 02 Jan 2013    Post subject: Reply with quote
This is why coming up to traffic lights you're supposed to slow down slighlty and be ready for them to change.
krarkol
PostPosted: 09:47 - 02 Jan 2013    Post subject: Reply with quote
I can guarantee that nothing was coming from any direction Laughing and I usually do roll off the throttle a bit but as I saw nothing around I didn't think they'd change. Just gutted it's like the 2nd set of lights that I've seen in my whole life that had a red light camera!
Bandit 600 - deaded
Joncrete Cungle
PostPosted: 09:52 - 02 Jan 2013    Post subject: Reply with quote
Hopefully all the red light cameras in Preston are still not working. Wink
https://www.lep.co.uk/news/local/city-s-traffic-light-cameras-do-not-work-1-95637
None of the cameras set up to catch motorists jumping red lights in Preston actually work, it has been revealed.
One of Lancashire's top highways officials admitted that due to "maintenance problems" not one of the seven cameras has ever been operational.
Stephen Whitehouse, project manager at the Lancashire Partnership for Road Safety (LPFRS), said painting the boxes attached to signals in "high visibility colours" was one option it is considering.
However, he came under fire from councillors investigating the use of cameras in Lancashire for focusing attentions on speed cameras and not the red light cameras.
Mr Whitehouse was quizzed by Coun Christine Abram, who represents Lea on Preston Council, over why motorists were able to jump the light at the junction of Lea Road and Blackpool Road.
He replied that the junction was fitted with a red light camera but it did not work – and never had.
The project manager added: "All these cameras were put in place by LPFRS but they have never been operational.There is no film in the red light cameras owing to maintenance problems. We are currently reviewing that situation."
and now for some weasel words
Speaking after the meeting, Mr Whitehouse refused to comment on whether the cameras were operational.
He said in a statement: "The use of red light cameras in Lancashire is currently under review as part of our current strategy and the options available will be taken forward for consideration by all partners prior to any decision being made."
krarkol
PostPosted: 10:04 - 02 Jan 2013    Post subject: Reply with quote
Nice find! Thumbs Up Nothing came up when I googled it Laughing
Fingers crossed then! I lose the bike then I lose my weekend job which is vital for me to survive while at uni Crying or Very sad
Bandit 600 - deaded
grant965
PostPosted: 11:08 - 02 Jan 2013    Post subject: Reply with quote
Wooo Penwortham. Your talking about the lights on the whitestake junction, coming from kingsfold towards leyland and the recycling centre? If so dont worry, ive heard of a few people jumping them and hearing nothing. Dont think the box has been working for years.
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
daemonoid
PostPosted: 11:26 - 02 Jan 2013    Post subject: Reply with quote
It may be 73m if you're riding a wartime Enfield on wartime rubber, but with your modern bike on modern tyres I think 73m would be ridiculous.
current: ducati monster 750
pork6156
PostPosted: 11:27 - 02 Jan 2013    Post subject: Reply with quote
You cannot think that or believe that, that will cause you an accident, it is called 'being complacent'.
I was riding home in the early hours one morning along a duel carriageway, there was not another car on the road or another junction for ages, it was well lit and residential. So you would think nothing could go wrong, until the fox shot out in front me, I managed to avoid an accident with the fox because I was not being complacent and did not think "I can guarantee nothing was coming."
PostPosted: 12:02 - 02 Jan 2013    Post subject: Re: red light camera Reply with quote
Go back to the junction and video the timings, if you believe they are dangerous?
Should be able to stop from 60mph in around 3 seconds on an ok bike, providing you've got ok grip.
I doubt it'd look good on the camera that your speed may now be over the speed limit, as you say you accelerated.
woo
PostPosted: 12:29 - 02 Jan 2013    Post subject: Reply with quote
the highwat code will tell you that amber means stop just as red means stop and green means proceed if its safe to do so, last time i read the highway code
Elen sila lummen omentielvo!
Joncrete Cungle
PostPosted: 12:43 - 02 Jan 2013    Post subject: Reply with quote
The cross roads junction at Penwortham bypass / Coote Lane / Chain House Lane is not one to go tonking through imho, even on green. Impatient myopic cagers waiting to turn right or left manage to pull out in front of other cagers. The case of the taxi driver killing the biker one night a couple of years ago at that junction drifts in to my mind from time to time as I pass there. Sad
Ariel Badger
PostPosted: 12:44 - 02 Jan 2013    Post subject: Reply with quote
Read my sig
krarkol
PostPosted: 05:58 - 03 Jan 2013    Post subject: Reply with quote
Glad the box aint working then Laughing it's the old grey double lense gatso thing
G, thats the thing, it had been that horrible shitty light rain about an hour before so the roads where greasy as hell Laughing
pork, I know there are potential for animals running out, but if I took that into account on every single road I'd be trundling around. Chances are low and my chances might be even lower seeing as I've already hit a bird a few week ago Laughing
Ariel, I'm a nice guy, already got 115 on my licence as my organs aren't much used to me when I'm gone Wink
I know speeding up wouldn't have helped me if there was any other traffic, but due to the fact no one was around I was probably at much lower risk of hitting traffic and beating the lights rather than braking and having a higher risk of coming off due to the slimy surface grip
Bandit 600 - deaded
andym
PostPosted: 06:50 - 03 Jan 2013    Post subject: Reply with quote
Just wanted to post a little comment about the amber lights thing here... I don't know if they have sorted it yet but at Lawrence Hill Roundabout in Bristol there is one of the juntions there that one set of lights change to amber to stop the traffic and at exactly the same time the other set is amber to let the traffic go.... It had been that way for a couple of years too
krarkol
PostPosted: 07:34 - 03 Jan 2013    Post subject: Reply with quote
We have lights here also in Blackburn near the ice rink where one side streets set of lights are green just before the main road goes red. It keeps traffic down as the traffic is just merging onto the main road at the same time the main road traffic has just stopped. It is bad if you skip a red light though!
I don't know these preston lights very well, but I risked shooting through the red as it was just turning rather than risking coming off and sliding across the junction just so I'd make it in time
Bandit 600 - deaded
The last post was made 13 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 123.14 Kb
