yamaha thundercat headlight adjustment + what anti-freeze
el_oso
PostPosted: 10:41 - 02 Jan 2013    Post subject: yamaha thundercat headlight adjustment + what anti-freeze Reply with quote
what type of anti-freeze goes into a '97 thundercat? The manual was far from helpful. It's an aluminium engine/radiator so I believe I need an OAT anti-freeze
Also, the headlight is displayed as a European standard. The pattern goes flat and then to the right. Is there a way to change the pattern so that the pattern goes flat and to the left? or should I just use a beam adjuster kit from halfords to make a flat beam?
Duke 390
Car: Jeep Wrangler 4.0L
weasley
PostPosted: 15:08 - 02 Jan 2013    Post subject: Reply with quote
Regular inhibited ethylene glycol coolant is fine.
You can't adjust the beam pattern other than for height and direction; if you want a RHD light pattern you'll need to replace the headlight. They go for £40 or so on eBay. A beam adjuster will make you 'legal' but given the dreadful headlight on the Thundercat as it is, anything designed to reduce light output further can't be a good thing.
The last post was made 13 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 31.62 Kb
