strange coil fault
uberkron
PostPosted: 02:04 - 02 Jan 2013    Post subject: strange coil fault Reply with quote
im not looking for advice as problem is sorted now but my ped started limiting at 4000rpm. After checking basics i put a timing light on and revved it on the centre stand and i was surprised it was losing spark repeatedly once revs got high enough and then spark would return once engine speed reduced.
On this machine the cdi control and coil are one unit, replacement was $70 nz.
Initially i thought it was a carb or fuel valve issue. I had wanted to simply pull the carb and dismantle it, but i adhered to my rule of always starting with the basics.
In summary just remember to start with the basics when you have an issue, once you start chasing items you suspect to be faulty you can influence other factors and possibly do needless work.
And im no ped boi, this is a nice commuting money saver, de restricted it does 40 mph. I rode it restricted for the first 5000km, so i could run it in well, then ditched the catalyst exhaust and fitted the "high speed" variator washer.
Share with me your bizarre faults.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
The last post was made 13 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 32.91 Kb
