Outside pir lights problem.
Marmalade
PostPosted: 17:28 - 02 Jan 2013    Post subject: Outside pir lights problem. Reply with quote
I've got 3 pir lights out the back.
The one at the furthest part of the garden on the side of a shed keeps coming on and staying on, usually all night. Simple solution, buy a complete new light and pir unit and replace it.
2 days ago I fit the new light and hey presto it's exactly the bloody same.
The light was first fitted by me about 3 years ago when I connected the shed to the mains. It's only been a pain in the arse for a few weeks but every night I look out the back and its on again. Turn off the power, wait 5 mins and turn it back on and all lights come on, go off and some time later look out and this one light is on again.
Any suggestions?
doggone
PostPosted: 17:42 - 02 Jan 2013    Post subject: Reply with quote
Would the cable run be far enough to affect the voltage?
Might depend what else is drawing current nearby.
Marmalade
PostPosted: 18:08 - 02 Jan 2013    Post subject: Reply with quote
I was wondering this but nothing has changed. The only things on are 2x optimate chargers using next to bog all and a low wattage tube heater to keep the shed from dropping below 10c. The same as the last few years.
I was thinking maybe a dirty connection but surely the light would flicker or be dim rather than stay on permanently.
andy_uk
PostPosted: 18:47 - 02 Jan 2013    Post subject: Reply with quote
1st thing to try would be to cover the offending PIR and see if it still triggers.
Could be RF interference from a new local signal source.
Or...
Is there an energy saving bulb on an adjacent circuit? (they can be 'noisy' and cause false triggers)
//edited to add:
Try disconnecting the optimates & the tube heater in turn just in case one of those has developed a fault.
drzsta
PostPosted: 19:31 - 02 Jan 2013    Post subject: Reply with quote
Some have manual override - switch off for 2-5 secs then back on.
oldpink
PostPosted: 19:38 - 02 Jan 2013    Post subject: Reply with quote
have you tried changing the sensitivity level (most have an adjuster) that could be set wrong
Raffles
PostPosted: 19:56 - 02 Jan 2013    Post subject: Reply with quote
I reckon that you could have a poor connection to the final light that is causing an intermittent interuption in the supply to the fitment. If the supply is momentarily disconnected and then immediately restored, the light will illuminate and remain so until daylight when it will extinguish and reset itself awaiting it's next command or false trigger.
ZebraDriver
PostPosted: 20:28 - 02 Jan 2013    Post subject: Reply with quote
PIR lamps can be triggered by things like plants moving in a breeze against a background with a different "heat signature". Its more usual for something like a brick wall thats been heated by the sun to be the background (little chance in the UK I know) but it could be your heated shed....
ZD
doggone
PostPosted: 20:43 - 02 Jan 2013    Post subject: Reply with quote
I know ours used to stay on if it was running on generator during power cuts - spiky(er) voltage maybe, compared to mains.
uberkron
PostPosted: 16:53 - 03 Jan 2013    Post subject: Reply with quote
I find most pir lights are cheap crap, ive only ever had two that worked right out of the box as they should. Due to the cheap and recycled nature of the electronics within, a new one doesnt rule out much.
Your shed heater isnt very powerful is it?
Aim the eye at the sky and monitor it.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
The last post was made 13 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 69.6 Kb
