Can u remove the air box on a gilera dna125
Warrenr
PostPosted: 00:44 - 05 Jan 2013    Post subject: Can u remove the air box on a gilera dna125 Reply with quote
I want to remove the large black air box can I change it to a cone or will it need something else mechanically done
LockyUK
PostPosted: 00:49 - 05 Jan 2013    Post subject: Re: Can u remove the air box on a gilera dna125 Reply with quote
you could use a conical air filter, it would be much louder but if the bike is carb'd i assume it would need a rejet because of the greater air flow
Supermoto_Fan
PostPosted: 01:07 - 05 Jan 2013    Post subject: Reply with quote
Don't. Even. Bother
Waste of massive effort and time trying to set it up for no real gain.
They come with a airbox and not a cone filter for a reason
joshuaconroy
PostPosted: 01:17 - 05 Jan 2013    Post subject: Reply with quote
Should be as simple a removing clip that holds it onto the carb try go to halfords and try look through it to see how to
lukamon
PostPosted: 03:33 - 05 Jan 2013    Post subject: Reply with quote
i have HAD one of these
and yes, i know the airbox looks like someone took a big black plastic dump on the side of the engine, but a cone filter will fuck up the engine in no time. dont do it.
and it will NOT make it more powerful
killa wrote: Im an ass man myself
temeluchus
PostPosted: 07:57 - 05 Jan 2013    Post subject: Reply with quote
Set up properly a cone will work OK.
It will need rejetting, at least a few jet sizes bigger.
Downsides are mainly:
-The cone can get plastered with shite and rain and whatnot and make the thing run like shit until it dries out and/or you clean it. Its in an exposed position on a ped type motor.
-Engine is more sensitive to temperature changes. Can be harder to get running in winter and more issues with carb icing.
-cones can fall off.
If it is set up properly it wont.
lukamon wrote:
[b]
and it will [b]NOT make it more powerful
Probably not, no.
lukamon
PostPosted: 10:18 - 05 Jan 2013    Post subject: Reply with quote
Temeluchus wrote:
set up properly
exactly
The last post was made 13 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 51.91 Kb
