| WherEmEweeD |
 WherEmEweeD Borekit Bruiser
| P.addy |
 P.addy Red Rocket
| doggone |
 doggone World Chat Champion
| WherEmEweeD |
| steady eddie |
 steady eddie Nova Slayer
| Noxious89123 |
 Noxious89123 World Chat Champion
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 11:42 - 05 Jan 2013 Post subject: |
One of these should see you right https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_204703_langId_-1_categoryId_255216.
It isn't too expensive, really simplifies the job and gets you 100% working brakes. It has a 1-way valve in the pipe, so you can just leave the bleed nipple open and pump at the leaver until there is no more air coming out - filling at master cylinder obviously!
If you have an airlock in the master cylinder, it can be a bit of a pain to get things flowing. The best tip here is to 'bottom fill' this is where you try and force fuel UP the system, hence forcing the air up and out the master cylinder - which is more natural direction for air to flow! A syringe full of brake fluid connected to the open nipple via a bit of pipe is how you do it.
An alternative is to take the calliper off and push the pistons in, this effectively does the same thing of forcing fluid and air up the system (assuming you have enough fluid in the calliper to start with!). ____________________ The purpose of life is to fight maturity. |
| WherEmEweeD |
 Posted: 12:43 - 05 Jan 2013 Post subject: Cleaned brakes + dot 4 fluid change = Brakes not working xt1 |
| Blue_SV650S wrote: | One of these should see you right https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_204703_langId_-1_categoryId_255216.
An alternative is to take the calliper off and push the pistons in, this effectively does the same thing of forcing fluid and air up the system (assuming you have enough fluid in the calliper to start with!). |
I got myself a pipe and bottle fits very securely.
I have just bleed it fully good 10 times. No bubbles what so ever. Still no pressure in the brake lever.
I don't think the drums are pushing against the disc at all as there is good bit of play in the caliper.
I have just taken caliper off the disc and pads out and there is no movement in the drums at all. I did take the drums out is there something i could have done wrong?
Drums are now stuck fullly into the caliper so i cannot remove them without taking the whole caliper apart ____________________ Yamaha XT125 x '07 (Swapped)
Honda NSR 125 '00 (Sold)
Peugeot Sum-Up 125cc |
| Fisty |
 Fisty Super Spammer
| Blue_SV650S |
| Dave-the-rave |
 Dave-the-rave Scooby Slapper
| WherEmEweeD |
| Robby |
 Robby Dirty Old Man
| Dave-the-rave |
 Posted: 16:30 - 05 Jan 2013 Post subject: |
The last post was made 13 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
