Nhs sickness
Marcg868
PostPosted: 01:22 - 05 Jan 2013    Post subject: Nhs sickness Reply with quote
Basically I suffered a second degree scald burn on my hand at work this was over two weeks ago. Now I was sent straight down to A&E and had my hand dressed and it developed blisters.
Now I had the dressing off three days later, and my finger although very tender felt ok and the epidermis layer was starting to flake off. Now a week later this layer has peeled off and the skin underneath has started to blister and its like I've reburnt one of my fingers.
Now I called in sick last week and had it redressed by the nurse at our local urgent care. And district nurses every other day. Now I rung work to say I'd be back Friday possibly, but I have had it dressed again yesterday afternoon. And its due to be changed Sunday. Now do I ring them this morning and say I may possibly be in Monday or wait till Sunday evening.
I think you can self certify sickness for up to 7 days and then after Sunday I need to provide a sick note. Now I can't get a doctor's appointment till next Thursday at the earliest.
I can't tolerate any gloves or the handwashing during patient intervention and due to having a dressing on for infection control purposes.
Just worried about the blemish on my record as I have only been in this job for twomonths. Hoping not to be sacked after a work sustained accident. But my fingers just aren't healing quickly enough.
JACK, MISS YOU LOADS YOU LEGEND.
Joenitro
PostPosted: 10:17 - 05 Jan 2013    Post subject: Reply with quote
Phone work as soon as you can. I don't think any employer is going to think bad of genuine sickness and your injury sounds quite nasty.
It's not like you've been off with a cold is it?
Don't worry mate.
Llama-Farmer
PostPosted: 10:41 - 05 Jan 2013    Post subject: Reply with quote
Can self-certify for 7 days... need a FIT* note from the 8th day.
GPs can charge for issuing a note before the 8th day.
Ring your work ASAP... that way they can look into getting cover staff without having to do so at the last minute.
Most employers are very reasonable when it comes to genuine illness/ailment causing you to not work... and don't worry, you won't lose your job over this. I don't know your exact T&Cs in your contract and what's in the employment handbook, but they have to go through certain internal procedures such as investigation, meeting with management, disciplinary etc before they can fire you... this won't happen as a result of one genuine sickness period, it'd have to be regular continuous and "suspicious" absences.
Again depending on the T&Cs, you may not be entitled to company (full/partial) sick pay, but all workers ARE entitled to Statutory Sick Pay (SSP) which is approx £85/week for full time employees, and worked pro-rata for part time workers.
* (Fit note has replaced a sick note, and states if you are fit or not fit to work, and allows doctors to make recommendations as to which duties you may or may not be able to do, such as no heavy lifting if you've got a "slipped" disc etc)
Aff
PostPosted: 12:44 - 05 Jan 2013    Post subject: Reply with quote
What did you burn yourself on? Heat, Chemical? Chemical take a bit longer to heal IIRC because your not suppose to use any creams with them.
Electric Bike Project
Marcg868
PostPosted: 17:47 - 05 Jan 2013    Post subject: Reply with quote
1st degree in some parts now fine and two fingers and thumb second degree and one finger the blisters opened into a wound. Doused in boiling hot water from a water geyser.
PostPosted: 18:13 - 05 Jan 2013    Post subject: Reply with quote
They will be sat there shitting their pants either waiting for you to sue them or get the HSE involved.
If they give you any difficulties, nonchalantly enquire if they submitted a RIDDOR report yet.
J4mes
PostPosted: 18:33 - 05 Jan 2013    Post subject: Reply with quote
You should just be grateful that it was not an 8ft geyser of boiling shit you got drowned in. We've had one of those on here before!
hellkat
PostPosted: 18:58 - 05 Jan 2013    Post subject: Reply with quote
The NHS (is that who you work for?) has started taking a proactive interest in sick leave and tend to instigate a policy of a certain number of strikes within a certain period.
What they then do is notify you that you have "gone over" their statutory number of incidents of illness.
So with this hand injury, you would be better off giving yourself the whole time off till it is properly healed, and its just one incident of illness, whereas if you go to work in between, they count it as separate incidents. But obviously as a new employee you want to go to work, not be seen as a slacker from early on. So you do have a bit of a dilemma there.
They then deal with the "sickness" depending on whether you have been off sick for the same thing or for different things. If you keep being off sick with the same thing, then they will attempt to find a solution to your illness. Say like if you had a dodgy back and kept taking time off because of it, they would send you to a specialist or a physio.
But if you have different illnesses, then usually they just put you on notification for 3 (or perhaps its 6) months, and your record clears after that (til the next time Laughing ) .
As this is a work-related/industrial injury, and as Stinkwheel pointed out, probably should have gone into the Incident Book ... so ask your line manager whether this can be considered one incident of illness on your record.
PostPosted: 19:10 - 05 Jan 2013    Post subject: Reply with quote
Any lost time injury that means more than 2 days off is reportable. HSE should already have been informed.
OP could try manning-up and get back to work though. Try 900 degrees oxy-cutting torch for a burn that smarts. No time off except and hour to have it dressed.
PostPosted: 19:12 - 05 Jan 2013    Post subject: Reply with quote
And funnily enough I just got back from A&E today after getting clumsy with my battery-powered circular saw. Microsurgery tomorrow to re-join the nerves and tendon in my little finger.
pepperami
PostPosted: 19:26 - 05 Jan 2013    Post subject: Reply with quote
Could you not go back to work on "light duties" ? if you`re concerned about your attendance record?
Marcg868
PostPosted: 20:16 - 05 Jan 2013    Post subject: Reply with quote
I'm not bothered about the pain. But I can't touch sterile wounds with a dressing on myself or have a open wound due to infection control. I'm sure my patients don't want me touching their post op wound with a filthy dressing coz I can't wash my hands.
PostPosted: 20:27 - 05 Jan 2013    Post subject: Reply with quote
Makes a lot of sense. I was only pulling your leg anyway.
Can't see them being able to chastise you for taking time off for a work-related injury though, unless you've has specific training about the hot water or they had a warning sign up.
keggyhander
PostPosted: 21:02 - 05 Jan 2013    Post subject: Reply with quote
The VILE EVIL WANK that is known as the BRADFORD FACTOR
PostPosted: 18:23 - 06 Jan 2013    Post subject: Reply with quote
Jesus Pete Laughing
hellkat
PostPosted: 22:24 - 06 Jan 2013    Post subject: Reply with quote
keggyhander wrote:
Ugh, that looks vaguely familiar.
I've fallen foul of it once so far Rolling Eyes
But now my copybook has been unblotted for most of the year.
Jeez, Pete Puke
PostPosted: 22:29 - 06 Jan 2013    Post subject: Reply with quote
Place I work gives a bonus is you don't take a day off sick (split up into 6 month periods). Some day someone with a disability won't get the bonus and will take them to court and win.
Marcg868
PostPosted: 20:43 - 08 Jan 2013    Post subject: Reply with quote
Got a letter from matron asking to ring and if they can offer any support. I have been told just to come back once I've seen the go Thursday as then they''ll use my fit for work note to sort out sick pay. And look forward to seeing me back.
The last post was made 13 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 102.98 Kb
