Seized caliper pistons - going nuts!!
GrumpyGuts
PostPosted: 17:14 - 05 Jan 2013    Post subject: Seized caliper pistons - going nuts!! Reply with quote
Hi,
I've spent all day trying to get these bastards out:
https://i46.tinypic.com/352kyvc.jpg
But I'm about to give up. I used a G clamp to push them down so I could break the seal that was keeping them frozen, then force them out with compressed air. That idea didn't work as too much air was leaking around the nozzle...so I hooked up the calipers (front calipers btw) and tried to use hydraulic pressure. No dice, the fluid was being forced back into the MS.
I'm totally stuck, literally. This caliper was bought off ebay to replace the caliper that had the snapped bleed nipple!
Anybody got any ideas?
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
Pigeon
PostPosted: 18:01 - 05 Jan 2013    Post subject: Reply with quote
Would a release agent be of use on this? Doubtful.
What about hot+cold?
Apply some heat to the outer casing and dump a few ice cubes inside the pistons.
Still needs the compressed air to work though.
I have no idea what I'm talking about though.
SWID This post is not being displayed because the poster is banned. Unhide this post / all posts.
mr jamez
PostPosted: 18:40 - 05 Jan 2013    Post subject: Reply with quote
You can buy rubber tips to go on the air blower. I think I've got some elctrical tape wrapped around the end of mine for this job as its tapered. Does the trick, with a loud pop Smile
PostPosted: 18:58 - 05 Jan 2013    Post subject: Reply with quote
Clean the caliper first to make sure none of that crud gets in the hole the pistons come out of.
Fill the master cylinder, remove the pipe banjo at the master cylinder and pump the level with your finger over the hole to prime the piston. Try not to spray fluid all over the paintwork. Now quickly fit up the brake line and do the same by pinching over the banjo at the pipe end. Hook the caliper back up to the brake line and bleed it normally.
Now put a flat bar/spanner across the gap where the disc runs in the caliper and pump out both pistons until they both touch the bar. Clean both pistons with rag wetted with brake fluid, press them back in a ways and pump them out again. Whichever moves the easiest, try to hold that back with something and pump the other one all the way out with the bar removed, then pull out the other piston.
GrumpyGuts
PostPosted: 19:31 - 05 Jan 2013    Post subject: Reply with quote
In the meantime what can i soak the caliper in to help loosen it up?
PostPosted: 20:44 - 05 Jan 2013    Post subject: Reply with quote
Suspect nothing you soak it in will help, and some things will hinder (anything that reacts with the seals and makes them expand). Normal problem is a build up of corrosion between the seals and the caliper.
Fully agree with Pete on bleeding them through and carefully pumping the pistons out.
GrumpyGuts
PostPosted: 20:52 - 05 Jan 2013    Post subject: Reply with quote
Would it be easier to use the brake hose from my CG to connect it to the MC on the Hornet and then the other end on the caliper?
It's a pain in the arse pumping fluid into two calipers - so in effect all the pressure will go into one caliper as these pistons are frozen solid? (dust deals were actually wedging the piston)
PostPosted: 20:57 - 05 Jan 2013    Post subject: Reply with quote
Yes, pretty much any hose and master cylinder will do it. Short hose probably makes it easier. You don't even need to use brake fluid, and water would do the job fine (not like you are using the brakes like that so no heat for the water to cause a problem, and you will have cleaned out any trace of the water when you clean the calipers up)
GrumpyGuts
PostPosted: 21:09 - 05 Jan 2013    Post subject: Reply with quote
Thanks for the advice lads...
OK to use water? (Sorry I am still learning) I'm running out of brake fluid and have no new copper washers left!
When I tried to use hydraulic pressure before, it was extremely difficult and I was not getting anywhere, however I shall try again.
Thanks again and I will let you know what happens!
PostPosted: 21:14 - 05 Jan 2013    Post subject: Reply with quote
For THIS it is fine. Just make sure there is no water in the caliper / hose / master cylinder after you have cleaned everything up and are reassembling it.
At this stage all you need is something that will transfer pressure and water is just as capable of doing that as brake fluid.
Where water causes problems in brakes is that it boils at a relatively low temperature compared to brake fluid. Hence as braking from speed is converting forward motion to heat you don't want water in the brakes in normal use.
Triumph1300
PostPosted: 08:52 - 06 Jan 2013    Post subject: Reply with quote
DON'T use water.
1 drop left behind in a hose or whatever will cause problems.
Just get some cheap brake fluid
BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit Smile
dansp1
PostPosted: 09:42 - 06 Jan 2013    Post subject: Reply with quote
What are you draining the brake fluid into? just recycle it in order to get the pistons out, you really don't want to be introducing water into the system.
PostPosted: 13:02 - 06 Jan 2013    Post subject: Reply with quote
The water is irrelevant. It isn't going to contaminate the system (ie, using a spare hose), and if you clean the calipers out you will likely use far more dodgy stuff. The water isn't going to react with the hoses, seals or anything else, and unlike brake fluid it isn't going to strip paint off things it gets onto (important consideration when you are using it to pump out the piston when fluid will inevitably pee out all over the place)
You aren't using the water as brake fluid, merely a temp fluid to push the pistons out. Then you are stripping and rebuilding the caliper, cleaning out and flushing out any debris. Then thoroughly drying it of any residue, whether that is water, brake fluid, brake cleaner or anything else.
And yes I have done this quite a few times. Prior to putting the caliper body under the tap and cleaning with the water and then drying it thoroughly (air line).
GrumpyGuts
PostPosted: 14:10 - 06 Jan 2013    Post subject: Reply with quote
I'm borrowing the hose from the CG so not really a spare, but to be honest that needs new fluid anyway. I can stick the air compressor nozzle down the pipe and flush it before I bleed that caliper.
mospeed
PostPosted: 17:35 - 06 Jan 2013    Post subject: Reply with quote
Send em back to the person on ebay, if youve been trying this long to get the pistons out with no joy.
PostPosted: 18:12 - 06 Jan 2013    Post subject: Reply with quote
You won't clear the hose out like that. You need to remove all the water and a hose has too many hidden corners (master cylinder and calipers are easy enough to clean out when stripped down to rebuild).
However you should be able to find a spare hose easy enough. Doesn't matter what it is from really; any length (although shorter will probably make it easier to bleed), or even to any great extent what condition it is in. Anyone local to you fitted braided hoses recently who has the old ones going spare? If you are local to me then I have a fair few old hoses (and some spare master cylinders).
SWID wrote:
Kickstart knows no better. This bloke/twat once claimed that drilling a hole in a bar makes it stronger Exclamation
When?
Old Git Racing
PostPosted: 18:36 - 06 Jan 2013    Post subject: Reply with quote
You'll be ok using water as a temporary fluid to get pistons out, done it many times myself, just flush it through properly after. As said recycle the real fluid.
OGR
carvell
Scuttler
PostPosted: 18:37 - 06 Jan 2013    Post subject: Reply with quote
SWID wrote:
Please DO NOT put water into a motorcycle braking system. EVER
Keith, is this how you get your 'Kicks'? Do you spout out this kind of gobshite & then sit back waiting for an "I had a big off today" post?
Why don't you just pop round the chaps house & whack him with a bat?
Christ, we get what you're trying to say. We got it the first time, we definitely got it the THIRD TIME. Calling Kickstart a 'twat' and a 'gobshite' is hardly making any advice you have to give look relevant.
Yamaha TDM 850
I will take that as you just admitting your accusation about drilling holes making bars stronger was something you just made up.
I am not telling him anything for kicks. Just giving him the info to make a choice himself. Once it is apart the caliper can easily be thoroughly cleaned up to remove any trace of water. Brake fluid is pretty useless to clean out the system (beyond absorbing water).
Sure if not being completely stripped down water wouldn't be a good idea. But that caliper is seized up and needs a full strip down.
The last post was made 13 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 137.14 Kb
