slow puncture - what to do?
open
PostPosted: 15:20 - 06 Jan 2013    Post subject: slow puncture - what to do? Reply with quote
Like I said, I have a slow puncture on my front wheel,.
I came back from holiday and it was quit e low, so pumped it up and was good for a day or two then needsinflating again.
Should i just use slime or whatever brand, replace tyre immideatly, or just pup pump it everyday?
I also have breakdown cover with Carole Nash, which I know nothing about can they help, or will I still have to pay for the new tyre if they are called out?[/code]
"Calamity - A more than commonly plain & unmistakable reminder that the affairs of this life are not of our own ordering."
[s]Baotian BT49qt-9 --> Honda CG125 (4 speed) '51 plate ----- 03/11/2012 Mod 2 PASSED! --> Cb500s[/s] Revoked Sad
Moo.
PostPosted: 15:31 - 06 Jan 2013    Post subject: Reply with quote
Depends where the leak is from? Around the valve or a small hole in the tread.
I've used slime before.. Although not sure how much it can be trusted as a permanent fix. Could be the wheel just needs the valve replacing.
Carole nash offer some very good breakdown cover, i've used it before and they've always been veru helpful.
If you found you had got a puncture, you could call them out too help you Very Happy
A2 Passed 18/6/10
open
PostPosted: 15:47 - 06 Jan 2013    Post subject: Reply with quote
Two things;
How would i find out where the leak is from?
And
With the call out would i have to pay anything extra.
Changing a valve is simple enough. Had to replace the valve on my old ped when the top quality Chinese valve decided to go for a wander and popped off on a dual carriageway!
yen_powell
PostPosted: 16:46 - 06 Jan 2013    Post subject: Reply with quote
Pump it up. Remove the valve cap and spit on the valve opening to see if it bubbles. If it does remove the valve core, clean it and replace it again.
If it doesn't bubble at the valve, take the wheel off and rotate it through a bowl of water till you see bubbles.
XT1200Z and a DR350 in bits
Matt B
PostPosted: 16:54 - 06 Jan 2013    Post subject: Reply with quote
Can't you put a tube in it?
Walloper
PostPosted: 17:09 - 06 Jan 2013    Post subject: Reply with quote
Easier way.
Blow the tyre up to about 50PSI
Spray the tyre, rim and valve with a plant sprayer full of washing detergent and water (soapy water)
If it is leaking it will bubble BIG massoove bubbles.
Probably from a nail.
Slime works fine and will let you run to the wire.
I have done this safely and sucessfully twice. Smile
Add slime according to the directions on the bottle.
It may wobble for a bit until you run it the recomanded bedding in distance (5 miles) No hooning till it till then.
PostPosted: 17:12 - 06 Jan 2013    Post subject: Reply with quote
Take it to a shop and they'll be able to plug it for about £10.
woo
PostPosted: 17:16 - 06 Jan 2013    Post subject: Reply with quote
or put some puncture seal inside can be found on ebay
Elen sila lummen omentielvo!
BigDan1190
PostPosted: 18:16 - 06 Jan 2013    Post subject: Reply with quote
Wafer_Thin_Ham wrote:
Take it to a shope and they'll be able to plug it for about £10.
This.
If the OP needs to ask what to do, the safest thing would be to take the wheel off and take it to a bike tyre shop who can advise if it needs plugging or a new tyre/valve e.t.c.
They would also be best to ask any questions to, such as further advice for the future.
Dan
The last post was made 13 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 61.57 Kb
