| joezxr |
 joezxr Nova Slayer
 Posted: 10:55 - 06 Jan 2013 Post subject: Kawasaki ZXR400 Derestriction issue |
hello, i own a 1992 zxr 400L model and im having a few problems with the top speed brick walling at 110mph
iv looked around lots of forums and i know about all the restrictions but my problem doesnt really match any of the restrictions that i have been told it could be.
basically my bike revs to 14k in every gear and absolutely flies to 110mph but then stops and is trying to pull further buy really struggles as if its being held back, i have a yoshimura exhaust silencer with the normal manifold but with no restriction plates on the manifold, i have english mph clocks and an UK blue sticker "M" CDI.
i have replaced and maintained everything on my bike that could be effecting this problem but i cannot figure out what is wrong, i have changed all the spark plugs, checked all the HT leads, cleaned my carbs, sealed my airbox and inlet rubbers, replaced all of my fuel lines and made sure they are all clear and my carbs are set to 2 1/4 turns out each, i balanced them the other day and my airbox snorkel/hole bit currently is half taped over to balance out the mixture of air and fuel.
like i said this current set up runs great, the whole rev range is smooth as anything and the plugs are a lovley coffee brown colour! the confusing part is i have had 130mph out of the bike previoulsy with the same engine but im beggining to believe the clocks were lying and i was just sat at 110mph the whole time! the previous owner of the bike who is a friend of mine also said he had around 140mph out of the SP engine he used to have in the bike but also came across this problem eventually and cant remember how he fixed it.
i would just like some advice on what it could possibly be? i have no more ideas... does anybody know 100% all of the restrictions on a zxr 400, iv heard about some resistor to a pink wire on the ecu or some crap but i have no idea... |
| CaNsA |
 CaNsA Super Spammer
 Posted: 10:59 - 06 Jan 2013 Post subject: |
| joezxr |
 joezxr Nova Slayer
 Posted: 11:12 - 06 Jan 2013 Post subject: |
yes i have tried there a few times but i never get a proper answer, even reading the sticky threads is confusing
the only thing i can think is i dont have a resistor mod but some people say it has to be the pink CDI wire and others say its also on the ignition and i have no experience with resistors so i dont even have a clue how i would wire them in or where to start :/ |
| Bikeless |
 Bikeless World Chat Champion
| Bikeless |
 Posted: 12:26 - 06 Jan 2013 Post subject: |
According to 125ccsportsbike forum,you sorted it last August and had 135mph??????  |
| joezxr |
 joezxr Nova Slayer
| Bikeless |
| Frost |
 Frost World Chat Champion
| joezxr |
 joezxr Nova Slayer
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 16:24 - 06 Jan 2013 Post subject: |
Is it a UK bike, or a parallel import from Japan?
The CDI wouldn't know which gear you're in I wouldn't have thought, so it wouldn't be restricted through that? Usually they're restricted via the clocks, so you fit an MPH converter to your KPH clocks, to get around it.
Why not unplug the speedo drive and go for a run? At least you'll know if it's the clocks causing the issue.
Do a GPS run before and after. ____________________ My Flickr |
| joezxr |
 joezxr Nova Slayer
| Bikeless |
| Wafer_Thin_Ham |
| Bikeless |
| joezxr |
 joezxr Nova Slayer
| Wafer_Thin_Ham |
| Kickstart |
 Kickstart The Oracle
| joezxr |
 joezxr Nova Slayer
| Bikeless |
| joezxr |
 joezxr Nova Slayer
| joezxr |
 joezxr Nova Slayer
| Wafer_Thin_Ham |
| Kickstart |
 Posted: 19:00 - 06 Jan 2013 Post subject: |
Not really suggesting a setup session, just a brief run or 2 after lobbing it on the dyno.
Could be many things but I do tend to agree with Frost that the max speed you are getting is too close to 180kmh (ie, Japanese market restriction) for comfort. But it also needs so much less power than standard that it should be very obvious on a dyno.
| joezxr |
 joezxr Nova Slayer
The last post was made 13 years, 50 days ago. Instead of replying here, would creating a new thread be more useful? |
