Is my battery knackered or? (Fixed)
JiveBunny This post is not being displayed because the poster is banned. Unhide this post / all posts.
mudcow007
PostPosted: 20:22 - 06 Jan 2013    Post subject: Reply with quote
why don't you just buy a new battery?
if the battery is really that dead the plates will be damaged inside it
_mjs_
PostPosted: 20:28 - 06 Jan 2013    Post subject: Reply with quote
Whereabouts do you live? I just bought another battery and now it turns out my starter motor was fucked.
Probably. But would be good to know if it is actually charging the battery. If you have access to a voltmeter then connect that to the battery terminals with the engine running. Check the voltage and that it goes up as you rev the engine. If the voltage does go up check that it maxes out around 14.5~15 volts.
A new battery is not likely to be expensive.
PostPosted: 20:49 - 06 Jan 2013    Post subject: Reply with quote
You should be able to pick up a cheap multimeter for about £5, and that is all you need to check the voltage.
Cranking it over on the starter motor does use a lot of battery power. Easy enough to flatten the battery doing that. But I would expect it to charge up fairly rapidly with use unless you are just doing short journies.
_mjs_
PostPosted: 20:59 - 06 Jan 2013    Post subject: Reply with quote
JiveBunny wrote:
Yorkshire? Razz
Anywhere near Leeds?
_mjs_
PostPosted: 21:09 - 06 Jan 2013    Post subject: Reply with quote
JiveBunny wrote:
I live more toward the Wakefield area.
Well it's up to you, I got a spare battery if you want to come get it Thumbs Up
PostPosted: 21:26 - 06 Jan 2013    Post subject: Reply with quote
JiveBunny wrote:
Just to confirm will it be pointless me buying a charger / because I need a new battery?
A charger is always useful. And a new battery might want charging (for best life).
_mjs_
PostPosted: 21:44 - 06 Jan 2013    Post subject: Reply with quote
PM sent Thumbs Up
Dave-the-rave
PostPosted: 21:58 - 06 Jan 2013    Post subject: Reply with quote
Maplin sells multi meters.
Shinigami
PostPosted: 22:11 - 06 Jan 2013    Post subject: Reply with quote
You should always have a charger. Also there's no real excuse to not get a multimeter as they're so cheap and damn useful for diagnosis
mudcow007
PostPosted: 13:18 - 07 Jan 2013    Post subject: Reply with quote
glad you got it going
any idea how old the battery is?
tis the season (cold weather) for batteries to die/ not hold a charge....
JustinParker
PostPosted: 17:02 - 07 Jan 2013    Post subject: Reply with quote
Battery on mine went pop last week too. I'd suggest same as others get a multimeter and check the voltage of the battery it'll need about 12.5Volts in order to get the bike started.
Get a cheap battery charger if you think the battery is worth trying to save. However a cheap battery may only last 12 months so worth spending a bit more on a quality item.
The last post was made 13 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 131.5 Kb
