cg125 k1 (1980) Engine, Gerabox, Neutral Indicator problem
Rusky
PostPosted: 20:55 - 06 Jan 2013    Post subject: cg125 k1 (1980) Engine, Gerabox, Neutral Indicator problem Reply with quote
Hi, Ive been doing lots of work on my bike and have now run into problems that didnt exist before I started 'fixing' things. Please help!
Ive a cg125 K1, with a type C engine.
Ive just replaced the oil, and took off the right hand cover, replaced gasket and seal and refilled.
Ive also replaced the wiring harness, all lights except head and tail light and speedo lights work (i assume these dont work because the engine is no longer starting).
Ive also just lubed up the chain.
Before doing this, the engine ran fine, in fact ran excellently, the gears seemed fine too, without the engine running they would at first change, but then stop selecting when the engine was not turned on, but would change as usual once the engine was started.
Now it wont start, the gear pedal wont move and the gear neutral light wont light, yet the bike is stuck in neutral.
Ive checked all connections, cleaned them up and they seem fine, the engine problem did occur before the wiring harness was replaced.
Clutch lever pulls with lots of tension, but smooth action with full movement just as it did before I took off and replaced the right hand engine cover.
Thanks for any help as with all this im unsure where to start.
mudcow007
PostPosted: 21:08 - 06 Jan 2013    Post subject: Reply with quote
ive got a BR-E CG from 1984
an had issues selecting gears
the fault with mine is the selector shaft had moved when the engine had been put on its side - if that makes sense
drain oil, remove RH case cover move the selector with your hand, an you will see the selector fork thingy
https://www.ebay.co.uk/itm/Honda-CG-125-Gear-Shaft-Selector-/330834527178
this
on mine, this had slipped out of position, jiggling it around got it back an now all is well
unitynotsocri... This post is not being displayed because the poster is banned. Unhide this post / all posts.
Rusky
PostPosted: 17:15 - 08 Jan 2013    Post subject: Reply with quote
Thanks to you both, you were absolutely right.
As soon as I disassembled the right hand cover I found the gear rod moveable again, when I gotit back into position the connector plate was now touching the switch again, so the gears select again and the neutral indicator is working.
Now my only problem is my spark plug is being wetted insied the engine, either by oil or petrol, this will be for another tpoic though I think.
And yes i was lucky enough to come accross someone who had an old cg125 that didnt work and was given to him, by the manual, all connections and wiring were the same for the K1 model (right for instruments) and the C type generator had the same connections for the K1 diagram, so all connected and all lights work for a minute or so when I clean up my spark plug
So 1 job done, now for the next.
The last post was made 13 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 42.15 Kb
