Urgent! Brake like switch
GrumpyGuts
PostPosted: 12:41 - 08 Jan 2013    Post subject: Urgent! Brake like switch Reply with quote
When pulling the master cylinder off the handlebars, I had to remove the brake light switch connectors (duh) but one of them decide to come apart.
I went out and bought a new spade connector and this is how it looks now:
https://i45.tinypic.com/29z4dva.jpg
However the polarity is reversed (or what ever) - the brake light is illuminated and when I press the switch, it goes out. Obviously the wrong way, but this is a major problem as this bike has its MOT on Friday and I've still got still loads to do to it.
How do I fix this? I have no idea!!
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
PostPosted: 12:46 - 08 Jan 2013    Post subject: Re: Urgent! Brake like switch Reply with quote
Erm, that sounds like the correct way?
When the switch is being pressed, the brake lever will be released in an "unbraking" position on any bike I've seen.
As you pull the brake in, it releases the switch.
Rear brakes often do work the opposite way, however tend to use a sprung mechanism and an adjuster to account for adjusting the lever.
GrumpyGuts
PostPosted: 13:23 - 08 Jan 2013    Post subject: Reply with quote
Oh for fuck's sake.
Put the brake lever on and it worked as it should.
DERP
weasley
PostPosted: 14:49 - 08 Jan 2013    Post subject: Re: Urgent! Brake like switch Reply with quote
This. It is supposed to work this way.
Besides, even if you switched the polarity of the connectors, it would still work this way.
GrumpyGuts
PostPosted: 17:23 - 08 Jan 2013    Post subject: Reply with quote
Nevermind - just panicking. Friday is the MOT and I hope it passes!
The last post was made 13 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 43.71 Kb
