Fixing the clutch
mr jamez
PostPosted: 19:49 - 09 Nov 2004    Post subject: Fixing the clutch Reply with quote
I am kind of stuck Confused
It needs new clutch plates, I have taken out the lifter plate and springs, however I do not have a tool to undo the locknut. Can you get these things anywhere or is it going to be a "ring up honda and get charged loads of money" affair? Doh!
I think I can fabricate a centre holder easily enough for when I tighten it up if I need one.
Picture of the locknut and the tool that I think I need to get it off with below, I could probably use a screwdriver and hammer to get it off, but I need to tighten it back up again and don't really want to bugger anything up.
Razz
alains
PostPosted: 20:27 - 09 Nov 2004    Post subject: Reply with quote
pick a wide piece of steel . drill 4 holes diameter 5 or 6 at the exact position of the grips . fit 4 bolts or solder them . then with a file adjust the ends going in the grips , that will be enough
mr jamez
PostPosted: 20:35 - 09 Nov 2004    Post subject: Reply with quote
Might give that a go but I wanted to avoid doing that. I was hoping someone here would be kind enough to lend me the tool, they post it to me then I post it back; everyones happy Laughing
Guest
PostPosted: 21:08 - 09 Nov 2004    Post subject: Reply with quote
What bike is it? Normally you don't need to undo the centre nut, just remove the springs and pressure plate and pull the plates out.
STUNTMAN2000
PostPosted: 21:16 - 09 Nov 2004    Post subject: Reply with quote
Are you just changing the plates or are you going to take out the basket too ?
A pair of grips allways works for me if they will grab the outside, if not a gentle tap with a hammer and screwdriver allways works, (A Blunt screwdriver does better) so it does not cut into it.
mr jamez
PostPosted: 21:54 - 09 Nov 2004    Post subject: Reply with quote
It is an NSR, the plates will not come out without taking this lock nut off.
STUNTMAN2000
PostPosted: 23:33 - 09 Nov 2004    Post subject: Reply with quote
Ahhhh yes I see what you mean.
Well if you can't borrow the proper tool then be carefull with the hammer and screwdriver, if you hit that basket it will shatter to bits.
I know I have done it many years ago Embarassed
What area are you in maybe I can help you out ?
STUNTMAN2000
PostPosted: 23:36 - 09 Nov 2004    Post subject: Reply with quote
In fact would a small adjustable wrench not slip into two of them slots and then you could turn it with a bar through the back off the wrench ?
mr jamez
PostPosted: 23:39 - 09 Nov 2004    Post subject: Reply with quote
Ah ha! now that is a plan! I think I have one kicking about somewhere, will give that a go tommorow morning.
ZaphodBeeble
PostPosted: 00:44 - 10 Nov 2004    Post subject: Reply with quote
Ah the joys of basket clutches. Thumbs Up I've used a hammer and screwdriver in the past for these, and for alternators Shocked
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
mr jamez
PostPosted: 13:32 - 10 Nov 2004    Post subject: Reply with quote
The idea of using the adjustable spanner was good, but it snapped, I could modify a combination spanner but I don't want to wreck mine. Have managed to bend a fair few bits of metal this morning Razz
Am now attacking it with a hammer and screwdriver, though it just seems to be burring the edge of the locknut over rather than undoing it Rolling Eyes
mr jamez
PostPosted: 15:43 - 10 Nov 2004    Post subject: Reply with quote
Well it all ended badly. Have been attacking it all morning, I made a tool from some meaty box section but the tabs just bent or sheared off. Made another tool seemed like it would do the job but then one of the stand offs on the clutch basket that I was using to hold it still sheared off. Nice.
Confused
mr jamez
PostPosted: 17:46 - 10 Nov 2004    Post subject: Reply with quote
Finaly got the bastid thing off Mad Not sure at what cost but meh, used a club hammer and huge chisel for concrete. Not good. Hope I haven't damaged the shaft thingy ma bob, because I was hitting that nut pretty hard for ages!
neon
PostPosted: 19:54 - 10 Nov 2004    Post subject: Reply with quote
can't you use a spanner (not the ring type spanner obviously, the open ended type) to slot in the 2 grooves, use a slighly bigger one tho and wedge a bit of thin cardboard in so its nice and tight and wont damage it when doing it back up?
STUNTMAN2000
PostPosted: 11:38 - 11 Nov 2004    Post subject: Reply with quote
Did try and warn you they break easy
The last post was made 21 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 82.08 Kb
