| dransy |
 dransy World Chat Champion
| TUG |
 TUG World Chat Champion
| Going |
 Going Nearly there...
| L3G3ND_MTX |
 L3G3ND_MTX Spanner Monkey
| Seb |
 Seb World Chat Champion
| dransy |
| Jayy |
 Jayy Mr. Ponzi
| prawny1 |
 prawny1 World Chat Champion
 Posted: 11:53 - 09 Jan 2013 Post subject: |
what you have to watch with some of the faster high end cards is physical size (and power requirements) and your pc form factor will also determine what choice you have in the way of graphics cards, higher end sff card demand a price premiem over standard size cards and choice is very limited.
Do you have any pcie 6 or 8 pin plugs on your psu? how many watts is it rated for and how many amps on the 12v rail?
If you have a branded pc that came with descrete graphics then i'm assuming you have around a 400-450w psu, in that case I would recommend an ati radeon hd7750 or hd7770, both are very capable cards upto around 1080p and are dx11 and play very well with aa, af, etc and run very cool and quiet.
The hd7770 does require an external power connection but if you have any free molex plugs you can buy an adaptor for a few £'s the 7770 can be had new for around £70-90 but the hd 7750 is power directly from the pcie slot and can be found anything from £60-80.
The7770 comes clocked at 1ghz but the 7750 comes in two clock speeds 800mhz and 900mhz, the higher one does need an external connection for some reason even though it is sub 75W power consumption (75W is pcie slot maximum) worth keeping that in mind if you decide on one of those.
this chart apparently shows total gpu power consumption under full (synthetic + gaming) load, proving that some cards can work on much lower rated psu then the vendor recommends (providing the psu is good quality/efficiency and can produce what it is rated at)
https://forums.atomicmpc.com.au/index.php?showtopic=264 ____________________ hellkat wrote:
Some people are only alive cos its against the law to kill them. |
| Jayy |
 Jayy Mr. Ponzi
The last post was made 13 years, 285 days ago. Instead of replying here, would creating a new thread be more useful? |
