Rear brake rebuild?
Yoyo This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Formerly known as
P.
PostPosted: 00:14 - 10 Jan 2013    Post subject: Re: Rear brake rebuild? Reply with quote
Mark Roberts wrote:
Any ideas, what it could be?
The cure to your babbling.
Ride it, now. Wink
PostPosted: 00:15 - 10 Jan 2013    Post subject: Reply with quote
First thing to check is that the pivot for the brake lever is free. Build up of corrosion there could cause a problem like this. Strip it and clean / lube it.
Failing that I would say the most likely cause is the master cylinder. Possibly the return spring in there has corroded away / broken.
PostPosted: 00:25 - 10 Jan 2013    Post subject: Reply with quote
How does the lever pivot? On a bolt? Is there a bush between the bolt and the lever? Would expect that the powder coating wouldn't have been on a surface on which it was pivoting.
Beyond that you would need to strip the master cylinder. Never seen a diagram of a Hyosung master cylinder, but normally you will have a rubber outer boot and under that you will find a circlip. Remove the circlip and the piston should come out.
The last post was made 13 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 49.5 Kb
