Chain locks
treeno
PostPosted: 03:21 - 10 Jan 2013    Post subject: Chain locks Reply with quote
Hi all. I need to buy a chain lock for my CG before I go back to uni where I will be keeping it on campus but locked to something or other. What are the best things to look out for when buying a lock? Is the thickness of the chain the most important thing or is it the brand? I could buy an unknown brand 10mm chain + lock for £15 on eBay or I could get a Mammoth 12mm chain + lock for £30.
What do you guys recommend? I am on TPO and am a bit worried about losing it. It also has no steering lock (unless I am blind, no idea where that went!?). However the campus is relatively safe and is also in the middle of nowhere so if anyone was to steal it they would need a van or would need to hot-wire it. Cheers.
PostPosted: 07:53 - 10 Jan 2013    Post subject: Reply with quote
I'm sure someone will be along soon to inform you that anything 12mm or under can be chewed through by a toddler with no teeth in about 20 seconds.
In truth, how much do you want to keep your bike? Your best bet would be spending a lot more on security. Think about it this way. Would you ratherspend £80-£100 on a 16mm Almax or spend £500-1000 on a new bike because your insurance wont cover you if someone takes it away?
Teflon-Mike
tl;dr
PostPosted: 08:27 - 10 Jan 2013    Post subject: Reply with quote
Chain thickness only says how much metal is in the links, don't tell you how good that metal is. Better Brands have hardened steel links.Cheap Chinky Ones have monkey metal pretending to be steel.
Implies you are best going for a reputable brand.
Re comment that some-one would have to have a van, or hot-wire your bike, as campus is in the back of beyond.....
Hot-wiring a CG125 is unfortunately pitifully EASY.... I wont, for obvious reasons explain how or why.... but, it is testimony to the stupidity of the criminal mind that so many scroats display the lack of knowledge they do, attacking the ignition lock on small hondas and honda copies, and leaving stripped wires they have tried touching together, as evidence of thier dumbness.
However, you would be amazed at the perseverance of the stupid.
So... first up, you cant beat hard security and lock-down to something immovable.
So, first thing you need is a chain thats long enough to go round bike AND something immovable. AND if you have some sense, you will put the chain around some more 'fixed' part of the bike, like the front down tube, not merely through an easily removeable wheel.
If you want to get really clever, you get a chain long enough you can thread through the frame and a wheel!
Remember; a chain is only as strong as its weakest link.
So rather pointless having a £90 chain, and a £2 padlock on the end.
Some-one a while ago, suggested, on a tight budget, going to a crane and lifting company; the 'big' lifting chains they use are effoff strong and damned hard to get through; probably as good as a name brand chain.... BUT, crane co's have to 'life' the chain for lifting use; so many hours and they have to scrap it for H&S reasons. Consequently they have lengths of 'old' chain, which if you ask nicely, they may sell you for a small cash donation, rather than weigh it in.
May be worth investigating, if you are in the Sub £50 budget; you'd get more chain and have more left for a good pad-lock to join the ends.
treeno
PostPosted: 12:33 - 10 Jan 2013    Post subject: Reply with quote
How come then a lot of branded chains like Abus are less than 12mm (and are also bloody expensive)? I may be able to get a Kryptonite Fahgettaboudit for around £30, I've used one before and they are pretty beastly, what do you think?
That's a good shout mike, I might try that. But won't their chains be a lot wider than chains for locks? So I wouldn't be able to fit it through anything?
Can I also just add that not only is the campus in the middle of nowhere, but I would also be parking it pretty much directly in front of the 24hr security building which has windows and often guards having a fag out of the front.
PostPosted: 12:53 - 10 Jan 2013    Post subject: Reply with quote
Your bike. your choice.
You wanted advice, you've gotten it. If you feel your bike is only worth a cheap chain then by all means. But I would upgrade your cover to TPFT instead of just TPO. Motorcycles are easy targets for thieves and a 125 can be lifted up by 2 guys and put into any decent sized car.
covent.gardens
World Clap Champion
PostPosted: 12:57 - 10 Jan 2013    Post subject: Reply with quote
treeno wrote:
CI would also be parking it pretty much directly in front of the 24hr security building which has windows and often guards having a fag out of the front.
Meh, don't blindly trust security. Some will have stuff away themselves if they know they can get away with it, they know all the tricks and they know nobody's watching them.
If you buy a big chain you'll need a big lock, that will probably mean a high security padlock which is a bit more expensive but a good idea.
treeno
PostPosted: 13:03 - 10 Jan 2013    Post subject: Reply with quote
This is true. Any advice on the first two points from my last post?
Joncrete Cungle
PostPosted: 13:31 - 10 Jan 2013    Post subject: Reply with quote
Save up and get something proper from Almax or Pragmasis, new or second hand. Abus, Oxford, Kryptonite etc is cheap ass rubbish made in China with their well known and respected quality controls and strignent manufacturing standards and specifications.After Sold Secure get the teaboy to tickle it with a feather duster for 5 mins and it 'resists attack' it gets a gold / silver rating. Then a massive mark up and flogged to mugs. Trust me, I had more than one of the aforementioned manufacturers chains, once.
PostPosted: 13:39 - 10 Jan 2013    Post subject: Reply with quote
If I had a bike that I minded losing, parked up anywhere near scrotes, students or 'security', I'd use a 16mm Almax Series III chain and whatever padlock they want to sell with it. I'd also dig out the alarmed disk lock that's buried in the garage somewhere as well.
You'll keep the chain longer than the bike. Think of it as an investment.
treeno
PostPosted: 14:05 - 10 Jan 2013    Post subject: Reply with quote
I would love to get an Almax chain but I simply can't afford (being a student and all) the £160 they want for a 1.5m chain + lock and I can only find one on eBay and that's in Newcastle. Confused
Is the Kryptonite one I mentioned really no good, even at 15mm? Also, the CG has drum brakes so no disc locks for me. Thumbs Down
Joncrete Cungle
PostPosted: 14:28 - 10 Jan 2013    Post subject: Reply with quote
If you can afford a bike, to get a licence, helmet, boots, jacket, pants and gloves etc. Buy fuel and pay for your insurance imho you can afford to save up for a proper chain and lock, if you really want one.
If you are TPO can you afford your bike being stolen? How much will a new bike cost you compared to £160 ish for a decent chain and padlock? Your gamble at the end of the day.
treeno
PostPosted: 14:47 - 10 Jan 2013    Post subject: Reply with quote
Guys I appreciate the responses and accept that I should probably get an Almax but I can't afford it. I bought the bike and insurance, all my gear was a present from my dad and that still leaves me on a tight budget for security. I am just trying to establish the best type of security for the price range I have mentioned (<£30). I think I will go ahead and pick up a Kryptonite Fahgettaboudit as at 15mm these are quite chunky and would hopefully at least deter any theives and with my secret connection (Laughing) I can get one for £30.
woo
PostPosted: 15:52 - 10 Jan 2013    Post subject: Reply with quote
lol OP asked for advice got it and still is unhappy.
bikes get nicked best you can do is make it hard for them.
almax and the protector chains are the best on market and you pay for what you get you cannot bolt crop the chains, cannot freeze smash them, cannot hacksaw cut them!
all other chains from other makers can be bolt croped, hack saw cut and freeze smashed!
just because oxford, datatool, abus, superman chain, charge £80+ for some of their chains doesnt equally quality!
if you cant afford almax or proctector 16mm linked chains then use the cheap crap ones as its better than nothing, then save up and buy almax or protector!
complacency reeks in your justifications just as complacency set within me, as my security measures became lax hence my bike was stolen in 2010 in a car park with security guards and barriers, dont make the same mistake i made use your common sense and lock up best you can!
Elen sila lummen omentielvo!
Walloper
PostPosted: 16:13 - 10 Jan 2013    Post subject: Reply with quote
And.... They think they can charge then earth because they are Thatcham, Sold Secure and Gold rated (security standard test).
This certification is worthless and all the chains over £100 were simply chopped by a big guy and a 24" bolt cropper.
Almax is the only one that could hope to pass all the tests.
You could buy shite just now as something is better than nothing then save like a madman for the proper one.
treeno
PostPosted: 18:11 - 10 Jan 2013    Post subject: Reply with quote
Does the word "appreciate" in your dictionary mean the same as "unhappy"? I'm not unhappy, I'm just bored of specifying my budget and telling people how I can't, unfortunately, afford Almax.
I'm not being complacent, I'm just trying to do the best I can. If I bought an Almax chain right now, I would not have enough money for beer food. Obviously as soon as I can afford one I will buy one but for now I need something to get me by.
And Walloper, didn't he use 42" croppers?
Ingah
PostPosted: 18:33 - 10 Jan 2013    Post subject: Reply with quote
I feel that an Almax 3 or equivalent is completely pointless if you're not chaining through the frame to an immovable object.
For about £30 you can get Kryptonite Evolution series 4 (a D-lock). It's one of the better D-locks, and short enough to present less space with which to be attacked by a car jack (usual way this kind of thing is attacked), but long enough to go through wheels and shocks.
If you're not going to chain/lock it to something, i believe that is more than good enough, as there's no point chaining a CG to itself as others have pointed out.
It's also highly convenient. Next thing to add, when you have funds, is a cheap alarm, like a Cyclone, and if you self fit (designed to be easy to do so), you're looking at another £25-£30 for reasonable security against ride away theft, while the bike still remains relatively pain-free to use day to day. Obviously you are chancing it, but then i suppose you know that by now.
I did the Almax 3 and TPO-insured CG125 (later followed by CB500) thing. It became too much of a pain in the arse after a few years, but i think it kept my bike safe while i was inexperienced, allowing me to build up the no claims.
-- Ingah
Walloper
PostPosted: 07:01 - 11 Jan 2013    Post subject: Reply with quote
Actually, he used an 85mm depleted Snickers Bar RPG from close range which destroyed the studio and all of the camera and sound recording equipment. What you see in the vid is a photoshopped mock-up of an event that took place during the Batle Of Copenhagen (Before Moscow was such a popular trourista haunt for the Jet Set.
I hope this helps.....
Do you understand Pedant?
I am 'King of Pedant' on this man's/woman's/ghey's forum pal.
treeno
PostPosted: 11:19 - 11 Jan 2013    Post subject: Reply with quote
Well Mr. Pedant, maybe you aren't pedantic enough. If they were 24" droppers then they would be only 1/3 of the blokes height using them in the clip, when they appear to me to be over 1/2 of his height. And a little link to back me up:
https://www.bikeradar.com/news/article/kryptonite-hit-back-after-tv-bike-theft-documentary-11745/
They may be good chains but I detest the way that company go about their business. Using forum accounts to smear the opposition and giving fake reviews rather than promoting their own product. Not to mention creating a video showing all the oppositions chains but not theirs. I know they did another video with their own chain but not including it in the other video is petty.
nowhere.elysium
The Pork Lord
PostPosted: 12:20 - 11 Jan 2013    Post subject: Reply with quote
OP: trying to scrimp your way through security doesn't work. You can argue the toss as petulantly as you like; many of us have had to deal with bikes being stolen, and cheap chains have done nothing to solve the situation.
Also, the steering lock on a CG is usually next to the lower yoke on the right hand side, if my OH's one is anything to go by.
Joncrete Cungle
PostPosted: 12:51 - 11 Jan 2013    Post subject: Reply with quote
"This televised demonstration leads viewers to believe that 42-inch bolt cutters are common tools used by thieves. They are not. The 42 inch bolt cutter, like the one used in the show, retails for approximately £291-360...and replacement jaws retail for approximately £100.
Well yeah those bike thieves who have no problem stealing bikes worth thousands of pounds will really be put off at the prospect of stealing three hundred quids worth of bolt cutters and a hundred quids worth of jaws won't they. Rolling Eyes
"The methods described on this show are not common methods currently in use in the UK or elsewhere. The New York Fahgettaboudit chain is covered by Kryptonite's anti-theft protection offer. In the last two years, in the UK, there have been no claims of property being stolen that was secured with a New York Fahgettaboudit chain. Zero."
I guess the neighbour who saw a pair of scrotes cut my Kryptonite and Oxford chains with a set of large bolt cutters was lucky to witness such a rare method of theft. Rolling Eyes
Now let us take a look at that claim about the Kryptonite's anti-theft protection offer. Merely copying and pasting Kryptonite's anti-theft protection offer in to Google is enough reading for now. The terms and conditions for the USA, can't imagine the UK ones differ much.
https://www.kryptonitelock.com/Documents/TERMS_AND_CONDITIONS.pdf
Kryptonite’s Anti-Theft Protection Offer
Upon proper and timely registration of your product and payment (as applicable), Kryptonite will provide you with a one (1) year Anti-Theft Protection Offer subject to the terms and conditions stated herein. (Note: Not all products are covered in New York City, NY, United States of America.) Please click here for the list of products that are covered in New York City. The Kryptonite Anti-Theft Protection Offer (“Offer”) is not to be construed as bicycle or powersport vehicle insurance. It offers protection against the theft of your bicycle or powersport vehicle caused by lock failure. “Bicycles” include e-bikes; however, this Offer shall not extend any coverage for loss of or damage to the e-bike battery. “Powersport vehicles” are limited to motorcycles, mopeds, scooters, personal watercraft, ATV’s, UTV’s and snowmobiles. If your bicycle or powersport vehicle is stolen because of the malicious or unintended opening or breaking of the Kryptonite lock by force, we will pay you the lesser of one of the following subject to a maximum amount based on the type of lock product identified in the claim: [1] the base cost of your bicycle or powersport vehicle excluding tax and accessories; OR [2] any insurance deductible (Note: Kryptonite requires proof of payment from your insurance company prior to paying your deductible under this Offer). Please click here for the maximum amounts payable under this Offer by Kryptonite per product.
This Offer provides you with an exclusive remedy once you have completed all requirements and only if all required materials are sent to Kryptonite within the specified time frames indicated below. No other offers, express or implied, are made by Kryptonite or any other Ingersoll-Rand Company entity.
Requirements to validate your Anti-Theft Protection Offer:
You must register for this Offer and pay any applicable registration fees within fifteen (15) days of lock purchase, providing all information requested on the registration form. Please click here for a list of applicable registration fees. Failure to provide the requested information will void your registration. You may register one of two ways: [1] Online at www.kryptonitelock.com. Please print and retain a copy of your registration form as your confirmation; or [2] Complete the form that comes inside of your lock product package and mail/fax to: [i] Kryptonite, 437 Turnpike Street, Canton, MA 02021, USA or Fax: (781) 821-4777 for United States and Canada registrations; or [ii] Madison Cycles, Burnell House, 8 Stanmore Hill, Stanmore, Middlesex HA7 3BQ, United Kingdom for United Kingdom registrations. Certified mail, return receipt is recommended, since Kryptonite is not responsible for non-receipt of mail. Written confirmation of registration receipt may be sent upon request. Your one (1) year term will begin upon Kryptonite’s receipt of your proper and timely registration.
NOTE: It is recommended that you keep all lock and bicycle/powersport vehicle bills of sale/receipts and copies of your Anti-Theft registration together should you need to file a theft claim.
Extending the One (1) Year Term
If you wish to extend the length of your Anti-Theft Protection coverage beyond the initial one
(1) year, you may do so by making payment during the online registration process, or by
sending in a check or money order to Kryptonite any time before the one (1) year anniversary
of your initial registration (Note: an international money order in US dollars is required for
Canadian customers). This extension offer is only available for US and Canadian residents. The
cost to extend your one (1) year initial Offer varies based on the product and varies based on
the coverage term chosen. Click here for the costs associated with each product and coverage
term.
Requirements in the event of a theft:
1. Report the theft to the police within 72 hours.
2. Mail or email notice of the theft to Kryptonite within seven (7) days of the theft.
3. Immediately report the theft to your insurance company, if covered by insurance.
4. Mail or email the following to Kryptonite within ninety (90) days: [i] broken lock and/or
broken links– required as proof of product failure (Note: We recommend that you return the
entire lock if available so that we can better understand how the product failed), [ii] at least
one (1) key, [iii] a copy of the official police report, [iv] a copy of your itemized lock bill of sale,
[v] a copy of your bicycle/powersport bill of sale, not including accessories, or a dated and
signed dealer appraisal reflecting the market value of the bicycle/powersport vehicle, not
including accessories, and [vi] evidence you have notified your insurance company, if covered
by insurance. Failure to forward all materials within ninety (90) days will void your claim and
Kryptonite will have no further responsibility under this Offer. Certified mail, return receipt is
recommended since Kryptonite is not responsible for non-receipt of mail.
Email address: [email protected]
NOTE: If your bicycle/powersport vehicle is stolen within fifteen (15) days of the lock purchase
and prior to fulfilling the “Requirements to validate your Anti-Theft Protection Offer” stated
above or prior to Kryptonite receiving your registration information, Kryptonite will accept your
claim for the Anti-Theft Protection Offer provided all of the requirements listed above in the
“Requirements in the event of theft” are met. Any claims filed under this Offer are subject to
the “Limitations” listed below.
Limitations
Please note that the limitations noted herein may be subject to state or local laws, which may
provide you with additional rights or remedies. SEE YOUR LOCAL LAWS FOR YOUR SPECIFIC
RIGHTS AND REMEDIES.
1. Not all products are covered in New York City, NY, United States of America. Please click
2. This Offer expires one (1) year from Kryptonite’s receipt of your proper and timely
registration and applies only to the registered lock owner and bicycle/powersport vehicle
properly registered with Kryptonite. Failure to properly and timely submit your registration will
void this Offer and Kryptonite will have no further obligations to you. Your coverage term may be extended as detailed above in the “Extending the One (1) Year Term” section.
3. Kryptonite is not liable under this Offer if the frame of the bicycle/powersport vehicle or the object to which such vehicle was locked was dismantled or cut, or if the Kryptonite lock was not broken or opened by malicious or unintended means.
4. This Offer applies only to bicycles and powersport vehicles as defined herein.
5. This Offer applies only to the actual theft of the bicycle/powersport vehicle registered with Kryptonite and does not apply to attempted thefts or thefts where the bicycle/powersport vehicle is recovered. This Offer does not apply to theft of any personal property located on the stolen bicycle/powersport vehicle or any theft of an e-bike battery. This Offer does not apply to damage caused by vandalism (e.g., damage that does not result in theft). For purposes of this Offer, the term “theft” means the unauthorized removal of bicycle/powersport vehicles by a person other than the owner of the bicycle/powersport vehicle or his/her agent which results in a legal claim for theft or a claim for theft against a company which insures said bicycle/powersport vehicle.
6. This Offer does not apply to thefts occurring outside the country of lock registration.
7. This Offer is transferable to another bicycle/powersport vehicle if you send in a copy of the bill of sale for the new bicycle/powersport vehicle prior to the expiration of your coverage period.
8. The maximum amount payable by Kryptonite under this Offer to any one registered owner, regardless of the number of locks at issue or bicycle/powersport vehicles registered, shall not exceed the maximum amounts identified by Kryptonite based on the type of lock product identified on the claim and shall not exceed the lesser of (i) the base cost of your bicycle or powersport vehicle excluding tax and accessories; OR (ii) any insurance deductible (Note: Kryptonite requires proof of payment from your insurance company prior to paying your deductible under this Offer). Please click here for the maximum amounts payable under this Offer by Kryptonite per product.
9. IN NO EVENT SHALL KRYPTONITE BE LIABLE TO ANY INDIVIDUAL FOR INCIDENTAL, CONSEQUENTIAL, INDIRECT, SPECIAL, OR PUNITIVE DAMAGES INCLUDING, BUT NOT LIMITED TO, LOSS OF USE OF THE PRODUCTS AND SERVICES, LOSS OF PROFITS, LOSS OF REVENUE, INTEREST, LOST GOODWILL, WORK STOPPAGE, IMPAIRMENT OF OTHER GOODS, LOSS BY REASON OF SHUTDOWN OR NON-OPERATION, INCREASED EXPENSES OF OPERATION, OR CLAIMS OF THE BICYCLE/POWERSPORT VEHICLE OWNER, WHETHER BASED ON CONTRACT, WARRANTY, TORT (INCLUDING, BUT NOT LIMITED TO, STRICT LIABILITY OR NEGLIGENCE) OR OTHERWISE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
10. Your rights under this Offer may not be assigned, subrogated or otherwise transferred to any other parties.
(rev. 12/14/11)
Now
Is that because the chain is so good no thief was able to defeat it, or is it because any claims made fell foul of the numerous get out of jail free clauses in the T&C's?
daverave999
PostPosted: 12:59 - 11 Jan 2013    Post subject: Reply with quote
Can't you borrow some cash off friends or family?
Put that £30 you're trying to spend now towards better security.
I'm NOT saying you are like this, but I work in a University and the number of students I see walking in every morning with a £2.50 shop-bought coffee, smoking real fags rather than rollies and eating a £3 Ginsters sandwich then complaining they are skint astounds me. That adds up to a lot of cash in a month.
I'm suggesting perhaps savings could be made in lots of small places temporarily, without affecting your quality of life too much so you don't risk losing something you really value. Even getting wasted can be done on the cheap!
woo
PostPosted: 13:11 - 11 Jan 2013    Post subject: Reply with quote
dont care if this sounds rude OP sounds like a child and a cry baby, gets real life advice from experienced adults and still winges!
lol
treeno
PostPosted: 13:19 - 11 Jan 2013    Post subject: Reply with quote
Seriously I am not tying to scrimp, I just can't afford any better at the moment. Thanks for that, found it. Can't engage it at the moment as thanks to the L plate brackets on the front fork seals I can't turn the wheel enough to the left to engage it! Will have to fix that, although the lock looks about as strong as a teacup anyway.
Now
That link wasn't to justify the Kryptonite chain mate, just to point out that 42" croppers were used not 24" ones. I agree, most of what that rep said was bollox (although to be fair I think the chain they are talking about is a bicycle chain which people use for motorbikes as well, so in that case you probably wouldn't get many bicycle thieves with 42" croppers? ).
lol
Where have I once winged in this thread? Seriously, test your adult (OAP) eyes. I'm just trying to establish the best security for my budget. My budget is my budget, if you don't like it, don't post. Advising me to get something that I can't afford is hardly helpful is it?
Hate coffee, don't smoke and make pretty much all my own food haha. Trust me, did a lot of saving to afford the bike. I will start saving again for decent security, but I am moving back down in a few days and need something for then. Smile
nowhere.elysium
The Pork Lord
PostPosted: 13:23 - 11 Jan 2013    Post subject: Reply with quote
I think (and this is based purely on some very fuzzy recollections) that the steering lock works in both directions on the CG. Don't quote me on that, though.
treeno
PostPosted: 13:26 - 11 Jan 2013    Post subject: Reply with quote
That's useful to know, thanks! However I have got my L plate in the middle attached to the top of both fork seals in front of the horn. Makes it look a bit less silly than sticking out the side and probably more aerodynamic and easier to filter too.
I will just grind the bracket down a bit, there is some room to play.
The last post was made 13 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.13 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 158.93 Kb
