KOSO DB01R speedo wiring help... Speed sensor colours?
Dean-J
PostPosted: 11:32 - 10 Jan 2013    Post subject: KOSO DB01R speedo wiring help... Speed sensor colours? Reply with quote
Hi all,
Does anyone have a Db01R speedo who could possibly do me a favour?
Problem i have is my Koso loom has been chopped prior to the Speed sensor plug, so i dont know what colour the wires are that run from the plug at back of clocks to the speed sensor plug...
If someone could check this for me it would be MASSIVELY appreciated!
Cheers all Smile
anthony_r6
PostPosted: 19:37 - 10 Jan 2013    Post subject: Reply with quote
Hi, if you're referring to what I think you are the wires are :
White/Black
Blue/Purple
White/Blue ( I THINK)
Dean-J
PostPosted: 20:22 - 10 Jan 2013    Post subject: Reply with quote
I dont know what wiring your talking about, but its not on a Koso Db01r.... theres no wires with that colour combo Laughing
Thanks for trying though!
If anyone else happens across this thread with a similar issue, The Koso ( DB01R) speed sensor wires from back of the clock to the plug are:
Red/white - +5v
Green/white - Earth
Brown/white - Signal wire.
Rest of the wiring ( just because i may as well!)
Red - Ignition +12v
Black - Earth
Brown - RPM
Yellow - High beam indicator
Orange - Indicators
Blue - Indicators
Green - Fuel guage
White - Neutral light
Grey - Oil sensor
As for the speed sensor, if your bike has a 3 wire speedo sensor you can wire direct to it, rather than having ugly magnets on a disc and wires trailing round your bike. What you have to do is to wire the speed sensor direct to the Koso, the OE wires must be removed as if you put 12v through the koso speed sensor wiring you will fry the speedo.
Before you disconnect the factory wring, Use a multimeter and determine which wire is earth, and which is power, the other is obviously the signal wire. Connect as per the above wiring list and set the wheel circumference and speedo sensor points per revolution.
Hope that helps someone!
mospeed
PostPosted: 00:03 - 11 Jan 2013    Post subject: Reply with quote
Hi mate, just read this, guess you have got it sorted now. I have the booklet that comes with it if you need any more info, let me know
Dean-J
PostPosted: 09:47 - 11 Jan 2013    Post subject: Reply with quote
Cheers fella but yeah am all sorted. Saw the instructions online, but the speedo sensor is just described as a black and white wire with a plug on, when its actually 3 wires running inside a sheath to a plug.
Quite why they dont include instructions to wiring to an OE speed sensor i dont know, as it makes for a far more tidy install!
Admittedly it has its problems if like my bike, the OE sensor has more pickup points than the Speedo can handle, but a bit of maths later and i have accounted for that, at the expense of my odo underreading by 20% but i can live with that!
anthony_r6
PostPosted: 10:37 - 11 Jan 2013    Post subject: Reply with quote
It's the three wires I told you about - I've got one. I took a picture but to be honest, it was dark and crap.
Dean-J
PostPosted: 12:08 - 11 Jan 2013    Post subject: Reply with quote
I think your getting confused about what i asked fella. i asked about the 3 wires from the speedo to the speed sensor PLUG, not the speed sensor. The wires must be a different colour from the plug to the sensor ( although KOSO states those wires as red white and black?)
The DB01R Speedo itself does not have those colour wires anywhere, just the 12 wires i listed above.
Maybe a dark crappy pic would clarify exactly what you mean?
anthony_r6
PostPosted: 14:56 - 11 Jan 2013    Post subject: Reply with quote
If you wait until I get home, I'll retake a clearer one. Are you asking for the speed sensor wire colours, rather than the colour of the wires that connect to the clock?
I use a universal speedo cable (Haven't managed to get it working yet, mind)
Dean-J
PostPosted: 15:19 - 11 Jan 2013    Post subject: Reply with quote
Well im not asking for anything now, Im all sorted, wired up and working Smile
But my post was asking for the colour of the 3 wires which go from the clocks, to the plug for the speed sensor. Not the wiring of the speed sensor itself.
Smile
anthony_r6
PostPosted: 16:36 - 11 Jan 2013    Post subject: Reply with quote
https://i1100.photobucket.com/albums/g401/theeanfone/IMAG02451_zpsdecb1f1b.jpg
These are the wires that go into the connector for the speed sensor/universal speedo cable adapter.
Dean-J
PostPosted: 16:56 - 11 Jan 2013    Post subject: Reply with quote
They are indeed, but they are not the wires from the plug to the speedo.... those are the 3 inside that black sheath! Wink
The last post was made 13 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 67.88 Kb
