My Christmas tinkering left me with this
ian505050
PostPosted: 20:18 - 12 Jan 2013    Post subject: My Christmas tinkering left me with this Reply with quote
Bought a bike in November last year to tinker with over Christmas as my GF works evenings so i have 6 hours each evening to fill and i am not prepared to let my mind rot watching the drivel on TV.
It was sold as a runner but it had been sat for 10 years. It did start when i went to collect it but cut out after 2 minutes and would not start again. I bought it anyway.
First job was to remove the side fairings and have a look at the condition, this is after a bit of cleaning
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2409.jpg
I then removed the other side and gave it a clean
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2407.jpg
Then removed the rear fairings to give it a clean and check over
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2404.jpg
Popped the fairings into a safe place
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2263.jpg
Then had a look in the tank, it had 16 liters of fuel but i recon it must have been the fuel from 2003 the last time it was used.
I also noticed it had the letter 'H' in the tank. Its not from the bike so no idea how it got there
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2266-1.jpg
Then decided to remove the front fairing to have a nosey, just plenty of cobwebs
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2403.jpg
Then decided to remove the tank and drain the 16 liters of crap fuel
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/DSC00545.jpg
Then next i removed the air filter which was a little dirty and had become quite thin and frail
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/DSC00539.jpg
Then i decided to spray some easy start in the carb and this got it running again after fully re-chargeing the battery.
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/DSC00530.jpg
It ran for 2 minutes and cut out again and would not start, i put some more easy start and it struggled to start but got it running again. I decided to run some redex directly into the carb, 50mm in each intake and after repeating this a few times the bike started to run a lot better.
Next i decided to do a full service now it was at least running.
I replaced:-
Engine oil, oil filter, air filter, fuel filter, engine coolant, spark plugs, brake fluid, brake pads front and rear, brake piston seals, brake levers(spazzo).
Before and after
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/DSC00551.jpg
I then decided to re grease all the bearings and moving parts that require grease which was easy enough. I then went all the way round the frame and checked for corrosion and found none.
Now the bike was running sweet so i decided to start on the cosmetics, from what i could tell the bike had never been down the road so it was just a case of cleaning and polishing the bodywork and metal components
I gave these bits a taste of autosol, they were orange with rust before i started
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/DSC00558.jpg
Then i noticed that one of the down pipes was not heating up, and found that one of the spark plugs leads was not correctly connected. After plugging it in correctly all down pipes seemed to reach the same temperature when running.
Then got the autosol out on the end can
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2410.jpg
Then studdied a few youtube videos to work out how to set the suspension up correctly for my 12.5 stone ass.
Cable ties came in handy for taking measurements
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2413.jpg
Finally i was happy with the bike and put all the bodywork back on. When i put the bodywork back on i gave it a misting of wd40 and left the bike for a week. The wd40 seems to clean all the crap off the bodywork better that anything else i have tried.
I then washed it off with warm water and let the bike dry off. Next i gave it 3 layers of different polish and sat back and admired.
Then decided i needed to insure it, MOT it and Tax it.
Went to the MOT station today and Very Happy it passed. with advisory on low brake fluid level and slightly pitted front disc which i knew about anyway. He also noticed on the machine that test brakes that the tyres had slight flat spots due to being sat 10 years, they will get replaced in time.
Decided to take a few snaps on the was home Very Happy Such a good feeling when all the hard work comes together and i now have a bike that should run all summer issue free.
R/H side
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2444.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2446.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2447.jpg
Chain and sprocket nice and clean
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2451.jpg
blue bleed nipples because i am a sad cunt
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2458.jpg
spazzo levers £17 a set!!!!!!!
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2456.jpg
Tank view(awaiting racing fuel cap)
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2462.jpg
L/H side
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2450.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2455.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2464.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2443.jpg
wilz1234
PostPosted: 20:26 - 12 Jan 2013    Post subject: Reply with quote
Very nice! Very Happy
That fork dust seal doesn't look seated properly xD
RS50 - ZXR400 - ZXR 400 - ZX7R - Bandit 600 - NTV 650
PostPosted: 20:27 - 12 Jan 2013    Post subject: Reply with quote
I miss my Thundertwat. Sad
Very nice mate Thumbs Up
ian505050
PostPosted: 20:32 - 12 Jan 2013    Post subject: Reply with quote
meh, MOT tester missed it anyway and thats all that matters, hahah.
Its only the dust seal anyway Thumbs Up
Rigga
PostPosted: 20:33 - 12 Jan 2013    Post subject: Reply with quote
Gorgeous although i think those wheels would look better in gold!
ian505050
PostPosted: 20:37 - 12 Jan 2013    Post subject: Reply with quote
nar..... Gold would look crap, the only other colors i might consider are white
or
rear red and front yellow to match the redbull logo.
UnspeedySam
PostPosted: 20:48 - 12 Jan 2013    Post subject: Reply with quote
I'm really getting quite fond of these bikes. Looks like a very nice example too Smile
I would have thought the flat spots would sort themselves out after a few miles. Could be wrong...
ian505050
PostPosted: 20:50 - 12 Jan 2013    Post subject: Reply with quote
like your thinking,
'officer, i was only doing 150 for safety reasons as i was hoping centrifugal force would fix my flat spots, flat spots are dangerous'
ian505050
PostPosted: 20:52 - 12 Jan 2013    Post subject: Reply with quote
I like them too, thats why i bought this redbull one to replace my purple one
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/380102_10151234724114414_881300903_n.jpg
Supermoto_Fan
PostPosted: 20:54 - 12 Jan 2013    Post subject: Reply with quote
That looks like a real nice quality paintjob, makes a change.
Lovely bike, jealous Evil or Very Mad
ian505050
PostPosted: 21:00 - 12 Jan 2013    Post subject: Reply with quote
the scheme is good, but the actual quality of the paint is brilliant, very thick paint and bright colour.
Ben_m
PostPosted: 22:54 - 12 Jan 2013    Post subject: Reply with quote
Looks very nice mate, good find. How much did you give for it if you don't mind me asking? I'm after a little project myself now that I've finished my house.
Yamaha Fazer FZS600 2003 ¦ Peugeot 206 GTI 180BHP 2003 ¦ BMW 323i SE
i.p.phrealy
PostPosted: 23:03 - 12 Jan 2013    Post subject: Reply with quote
ian505050 wrote:
they're flogging one of them at Bike Bits in Cov.
ian505050
PostPosted: 23:17 - 12 Jan 2013    Post subject: Reply with quote
£1000 but i had to put at least 20h work into it to get it how it is and may end up spending £150 on tyres, £100 on chain and sprocket and £175 on downpipes.
But................ the above 3 items are fine as they are at the moment but changing these 3 things would make the bike like new.
£25 MOT + £55 Tax as well so it does add up but the bike only got just over 10,000 miles on the clock so it was worth it in my eyes.
keggyhander
PostPosted: 23:26 - 12 Jan 2013    Post subject: Reply with quote
Lovely bike.
Only thing I'd do is get the seat upholstered to match.
Supermoto_Fan
PostPosted: 23:36 - 12 Jan 2013    Post subject: Reply with quote
Can't stop looking at this bike!
Proper jealous knowing you picked it up for a grand and it has only 10000 miles! The paintjob probably cost near that! Haha
kelvyn
PostPosted: 00:48 - 13 Jan 2013    Post subject: Reply with quote
Looks awesome but on 2nd visit to the thread, I've spotted the Michelin stickers are different on each side Neutral
Edit- the two sides are totally different red bull logo and lettering too.
PostPosted: 00:51 - 13 Jan 2013    Post subject: Reply with quote
Thinking indeed... that would piss me off no end.
MarkJ
PostPosted: 01:55 - 13 Jan 2013    Post subject: Reply with quote
You won't be saying that when the oil seal corrodes to the slider and you can't split the forks Laughing
Awesome bike Thumbs Up
cyberglass
PostPosted: 02:23 - 13 Jan 2013    Post subject: Reply with quote
ian where you live and when can i bring the R1 round for a clean shes not been done in the 2 years ive had her hahaha
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
Noxious89123
PostPosted: 03:01 - 13 Jan 2013    Post subject: Reply with quote
For the sake of a few minutes work, I'd seat that dust seal properly, it'll be beneficial in the long run. You can do it just using something soft against the sal and knock it into place.
I did mine with my bare hands + brute force, although it did take a few months for the resulting bruised nerve in my thumb to heal and restore feeling to my thumb tip. Rolling Eyes
weasley
PostPosted: 09:10 - 13 Jan 2013    Post subject: Reply with quote
Nice bike!
Sadly, when I saw the first photo I identified it.... I have spent many a happy hour on my arse looking at these views.
ian505050
PostPosted: 10:27 - 13 Jan 2013    Post subject: Reply with quote
Prety sure its impossible to spot now the bodywork is fitted to the bike Middle Finger
ian505050
PostPosted: 10:30 - 13 Jan 2013    Post subject: Reply with quote
I tried bare hand followed by a metal pole along side the fork and a mallet but this did not work. Maybe a bit of plastic wrapped round the fork leg and a few knocks. Would WD40 help? I would have thought that i should keep wd40 away from the fork seals.
Flatbadger
PostPosted: 10:43 - 13 Jan 2013    Post subject: Reply with quote
Get Red Bull to chip in - lovely bike but why all the stickers?
You're in ISIS
The last post was made 13 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 138.27 Kb
