| Doobrey |
 Doobrey Nova Slayer
| Ian (GPX) |
 Ian (GPX) Brolly Dolly
| wantser |
 wantser Trackday Trickster
 Posted: 14:54 - 10 Nov 2004 Post subject: |
think you're missing "wheelie" between the signal and lifesaver part.
Dont think either of those a wrong. It cant hurt to "over check" to make sure its safe to turn. No examiner should fail you for that.
Look behind me
Signal
Look behind me
Life Saver
Manouver
This sounds about right tho.
OSM is a bit confusing because a lot can change between O and M. Best to OSOM me thinks......
 ____________________ An expert is a person who has made all the mistakes that can be made in a very narrow field |
| stryker |
 stryker Brolly Dolly
| instigator |
 instigator Super Spammer
 Posted: 17:54 - 10 Nov 2004 Post subject: |
I'd do
Mirrors
signal
shoulder check
position your self over to the right
mirrors
alter speed (if lights are green)
Lifesaver about 2 car lengths before junction IF light is green and tehre is no obstructions then make the turn.
THEN cancel the feckin indicator!!! My only problem is cancelling to early! |
| map |
 map Mr Calendar
 Posted: 21:04 - 10 Nov 2004 Post subject: |
I can only repeat what my instructor told me.
Before any indication or change in road position a half turn of the head. This is also before any braking. Apparently the turn of the head is supposed to be an indication to dozy car drivers something may happen (like we know how that works ). Then before any turn, left or right, a full lifesaver look on the side you're turning.
So it'd be:
Mirrors - check if there is anything behind.
Look - checks blind spot and indication to anyone behind.
Signal
Look - check that blind spot again
manoeuver - take up centre line position.
- remember you may have to brake/stop for oncoming traffic
Lifesaver
Turn
- and then accelerate and as said cancel indicator.
Don't think this totally true for any advanced test as the examiners look for different things and don't like you looking like a nodding dog.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| mrchips |
 mrchips World Chat Champion
| Doobrey |
 Doobrey Nova Slayer
| wantser |
 Posted: 11:59 - 11 Nov 2004 Post subject: |
sounds a bit more like it. Still forgetting the wheelie but tho!  ____________________ An expert is a person who has made all the mistakes that can be made in a very narrow field |
| 8316 |
 8316 Could Be A Chat Bot
| stryker |
 Posted: 14:53 - 11 Nov 2004 Post subject: |
You forgot the bit where you flip the birdie to the oncoming cager flashing his lights.  ____________________ Now what? |
| Rollins |
 Rollins Trackday Trickster
| Doobrey |
 Doobrey Nova Slayer
| Frost |
 Frost World Chat Champion
 Posted: 18:25 - 12 Nov 2004 Post subject: |
If you intend to turn off a main road to the right onto another road the correct proceedure is:
Check both mirrors
Slow down
right shouldder check (NOT a lifesaver, lookj to your right, not hehind and to your right)
Indicate
Move to the right
Continue to break, get the right gear, check its clear to cross the flow of traffic
Lifesaver (this lifesaver should consist of checking both mirrors and behind and yo your right in once quick movement)
Turn.
You will also need to do the above when turning left (only look left instead of right obviously ) if there is a chance you could be undertaken, such as in heavy traffic or if there is a cycle lane to your left. |
The last post was made 21 years, 226 days ago. Instead of replying here, would creating a new thread be more useful? |
