| Rob1970 |
 Rob1970 Nova Slayer
| Clive L |
 Clive L Nitrous Nuisance
| Kickstart |
 Kickstart The Oracle
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:07 - 14 Jan 2013 Post subject: |
ABS should pay for itself the first time you need it.
I've added or extended the screen on each of my bikes while I was using them as my main machine, then removed it again as they were relegated to shorter trips. ____________________ Biking is 1/20th as dangerous as horse riding.
| Rob1970 |
 Rob1970 Nova Slayer
| P.addy |
 P.addy Red Rocket
 Posted: 23:27 - 14 Jan 2013 Post subject: |
An opposing question is, do you have a vagina?
I have no ABS.
I am not dead. Forward planning helps  |
| c-m |
 c-m World Chat Champion
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| barrkel |
 barrkel World Chat Champion
 Posted: 00:16 - 15 Jan 2013 Post subject: |
| Andy_Pagin wrote: | There's nothing magical about abs, It's there to save clowns whose obs fail and don't know how to e-stop without locking the brakes. A biker cannot afford to be a clown. |
You make that sound like logic, but it's not logical. What do you know about emergency stops on wet and oily surfaces? There's no easy way of figuring out the available traction in the middle of the emergency stop, unless you have world-class reflexes to react to the front wheel starting to slip. IMO to get good at that, you'd need to practice it, and you can't practice that safely on the roads. You need a bike with monster crash bars on a private track with a team randomizing the ground conditions, very good gear you can afford to throw away, and you're still likely to break a bone in the learning process.
Forward observation won't always save you, unless you want to crawl through every junction at no more than 15mph, in which case get a bicycle, you'll certainly get through London faster. There will be car drivers that make a move at turning across you, and you won't know how many trucks have waited at that junction dripping oil and diesel. There will be young women on a wet Saturday night that run out like Bambi from between oncoming cars - I had one last weekend.
The key thing about ABS is that it measures the point of wheel slip and catches it faster than you are likely able to. In difficult conditions (wet, possibly icy, oily, etc.) you're likely to underbrake in an emergency stop because you'll be worried about available grip.
(My SH300 has convinced me I want ABS on my next big bike.) ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| P.addy |
 P.addy Red Rocket
| haroman666 |
 haroman666 World Chat Champion
| barrkel |
| CarlosCBR |
 CarlosCBR World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| barrkel |
 Posted: 10:15 - 15 Jan 2013 Post subject: |
| CarlosCBR wrote: | On the other hand, if you know you have bought a bike without it, it should be easy for you to recalibrate your brain. |
Yes, it's not too difficult to recalibrate; I have to every time I ride my ER6. Main thing is getting used to a longer stopping distance with much more progressive brake squeeze (just in case the traction isn't there), and that in turn means going slower and leaving bigger margins.
There's little difference on the open road (you can see tight bends / problem development ages away), but in the city, making progress means more assertiveness in going for gaps, and occasionally those gaps don't come off for random reasons beyond your control, needing some occasional heavy braking. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| Matt B |
 Matt B World Chat Champion
| esullivan |
 esullivan Could Be A Chat Bot
 Posted: 11:01 - 15 Jan 2013 Post subject: |
The first time I locked my front wheel I went down like a sack of potatoes. Not pleasant. Subsequent times, I learned to recognize the wheel locking and let up and re-apply ("manual ABS"), but there have been a few times in London traffic with my 125 where I nearly spilled it again.
I think you should learn how to brake without ABS, but all things being equal, I'd have it.
Also, as has been mentioned, you can generally avoid e-stop situations for very long periods by being a good, observant rider. But that can be a problem -- too little practice. A good rule of thumb is to practice a few e-stops (on a quiet road somewhere) about once a season.
I have a naked (except a very tiny screen). It's no problem at all up to about 65mph or so, but even slightly higher speeds become annoying after an hour or so. ____________________ Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125. |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 11:19 - 15 Jan 2013 Post subject: |
Fairings are a thing that I've always been largely ambivalent about.
As a rule, the standard screen that comes with them usually doesn't deflect wind all that well - at least that's my experience of them. The whole "Do I need a screen" debate has got more to do with seating position than whether or not the bike's naked; on my GS, sitting at 90-100 isn't a problem at all for me, thanks to the position that it imposes on the rider. The SV, not so much; I have to tuck in behind the screen as much as I can. The further forward you're leaning, the harder you tend to have to work against the wind, if there's nothing to get behind.
ABS; I've only experienced it in cars, and I don't like it much. I was taught how to brake properly from the get-go, so I find that if ABS is self-invoked, then either I've not been paying attention, or it's doing so inappropriately. I'm not in the habit of getting into the sort of situations that require external intervention by such gizmos. Reading the situation and the road conditions is far more profitable, and more likely to keep you away from the sort of trouble that ABS and the like are designed to scrape you out of at short notice.
Short answer; I'd say spend more time on practising your skills, as opposed to buying kit that does it for you. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| haroman666 |
| chris-red |
| Rob1970 |
 Rob1970 Nova Slayer
| nowhere.elysium |
| chris-red |
| nowhere.elysium |
| kawashima |
 kawashima World Chat Champion
 Posted: 15:06 - 15 Jan 2013 Post subject: |
I am a poor level rider.
Price wise,
If ABS cost +500, you can usually sell it +500 (or less).
So even if you didn't need to use it luckily, it's not expensive.
I was told this from a bike shop when I asked how much I can get if I sell it. "Oh if yours were TDM900A, you can have +***! "
Mine is TDM900. without ABS.
I still can't have confidence in my panic braking on heavy wet surface.
Cons of ABS : ABS unit decreases under seat space.
Regarding screen, I sometimes wonder which has better protection CB500S and CB500 + GIVI screen.
I had W650 with big screen attached(you can see it in my sig link). Its handling becomes interesting at high speed. Frame mount half fairing won't have this problem.
Buying naked bike and attach GIVI screen is interesting cause you can feel the difference. If you buy half fairing bike with good protection as a first bike, you can't know the wind pressure on naked bike unless you borrow someones naked bike. ____________________ own:2020 Serow 250
owned: 2012 YB125SP, 2008 TDM900, 2005 W650, 2002 LS125R, 2002 CB400SF, NS50F, C50 / Trip to UK(2009), Hokkaido touring(2013) |
The last post was made 13 years, 87 days ago. Instead of replying here, would creating a new thread be more useful? |
