CBR600F (1999) Stutters in 1st, engine cut out, wont start
issey9090
PostPosted: 21:14 - 14 Jan 2013    Post subject: CBR600F (1999) Stutters in 1st, engine cut out, wont start Reply with quote
Hi - hoping someone can tell me what might be wrong with my 99 cbr 600f - the symptoms are quite specific...
1st noticed it was stuttering in 1st gear when pulling away. Got it home when it promptly cut out and then wouldnt start again. It'd turn over once then nothing.
Pushed it to the garage, where they fitted a new, charged battery. Ran like a dream that day. Then the next day, exactly the same symptoms, t cutting out while moving in 1st. When trying to start it again, turned over once then gave up. Left it an hour and it starts up 1st time, but still sluggish in 1st.
Any ideas? much appreciated
Ichy
PostPosted: 21:36 - 14 Jan 2013    Post subject: Reply with quote
I don't know if it matches the symptoms but they are known to have problems with the rectifier? Does the headlight brightness change when you rev it?
issey9090
PostPosted: 21:59 - 14 Jan 2013    Post subject: Reply with quote
Yep, headlight grows brighter when revs are increased from idle - this is as should be, no?
I didn't know rectifier's were a known problems with these models, but will investigate, thanks. All i had heard was cam chain tensioner often needs replacing
Resurrection
Ballast Boy
PostPosted: 00:36 - 15 Jan 2013    Post subject: Reply with quote
Sounds right. Mine ate two batteries before I realised. Reg recs are cheap enough to see if it fixes it.
ZX9r
issey9090
PostPosted: 09:03 - 15 Jan 2013    Post subject: Reply with quote
Google search seems to confirm - thanks
Have ordered a new r/r and hope I haven't fried the new battery
Resurrection
Ballast Boy
PostPosted: 17:47 - 15 Jan 2013    Post subject: Reply with quote
When you fit it, take the bike for a decent blast. Hopefully battery will be alright.
ZX9r
issey9090
PostPosted: 23:27 - 30 Jan 2013    Post subject: Reply with quote
Thought i'd post an update, as always useful for anyone else searching with a similar problem
Fitted the R/R off ebay (very easy even for me on cbr 600f). Bought an optimate and recharged the battery. Have been commuting for 2 days and bike is running smoothly. So the culprit does seem to have been th Regulator rectifier, which appears to be a common issue on cbr's my age.
Thanks for all the help you guys gave in pointing me in the right direction Karma
Ichy
PostPosted: 07:45 - 31 Jan 2013    Post subject: Reply with quote
You're welcome, it's good to get one right once in a while Wink
The last post was made 13 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 56.76 Kb
