GSXR 750 K4
TheDonUK
PostPosted: 21:33 - 15 Jan 2013    Post subject: GSXR 750 K4 Reply with quote
Going to look at one this weekend with a view to buy if its in good nic.
First GSXR, not first suzuki (i know about their finish), anything specific to look out for with these models?
Gearboxes? Brakes?
Any info appreciated.
Azonicben
PostPosted: 00:49 - 16 Jan 2013    Post subject: Reply with quote
Check for bubble/scorching in the headlamp lens, it can melt if the wrong bulb is in there, not a massive problem but could be a not so cheap fix dependent if it bothers you. I've just left mine as it is. There were two or three like it when I was looking for mine.
h00dwink
PostPosted: 02:07 - 16 Jan 2013    Post subject: Reply with quote
Yea mine has done that bubbling thing. Though it was like it before I took ownership. Aside from that i have owned mine for 5 years now (I think) and have had zero issues with it.
Mines the k5 600 model but it's all the same. Really struggling to think of things to look out for on it.
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
t121anf
PostPosted: 12:40 - 16 Jan 2013    Post subject: Reply with quote
No real problems with mine, had a little leak from a seal near the front sprocket but that's about as bad as it has been.
Front right fork leg has had a leak from the join with the black part (where the calliper mounts) and the stanchion, though this appears to be a rare thing.
Noisy cam chain tensioners to.
nowhere.elysium
The Pork Lord
PostPosted: 12:41 - 16 Jan 2013    Post subject: Reply with quote
Just make sure that it's not Paddy's former one, and you should be OK Laughing
PostPosted: 12:46 - 16 Jan 2013    Post subject: Reply with quote
Prepare for clunge to throw itself at you Cool
I had an older GSXR, so not really much I can add, but get yourself clued up on the FI error codes here https://www.gsxr.com/showthread.php?t=1234
Connector needs shorting by a paperclip or equivalent.
Fairly nippy little buggers though, found mine had the handling and flickable nature of the 600 with a little more low down go go juice.
garth
PostPosted: 12:51 - 16 Jan 2013    Post subject: Reply with quote
GSXR finish is generally better than any other Suzuki I've owned or ridden.
Suzuki make excellent gearboxes.
Usual sportsbike things - Fork seals, etc.
The last post was made 13 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 52.75 Kb
