rs 125 engine rebuild???
arronb
PostPosted: 17:27 - 16 Jan 2013    Post subject: rs 125 engine rebuild??? Reply with quote
I have rebuilt my rs 125 engine as it over heated, I fitted new crank with new bearings, but while I was stripping it I cracked the left side engine casing so I bought a new one, fitted it and put it all back together and now its in my bike but when trying to start it its rotating real slow as if they aint enough power in the battery so I power the battery up with a very powerful booster and its still struggling to rotate round, but before I built my topend onto my bike I could spin it freely with my hand... does anyone know the problem?
thanks
PostPosted: 17:34 - 16 Jan 2013    Post subject: Reply with quote
Remove the starter and plug it directly to a battery, does it spin freely?
arronb
PostPosted: 17:49 - 16 Jan 2013    Post subject: Reply with quote
I took the plug out and its spinning a abit faster as it dosnt sound like its struggling as much but still not fast
PostPosted: 17:50 - 16 Jan 2013    Post subject: Reply with quote
Drop some petrol down the spark plug hole and pop a new spark plug on there.
arronb
PostPosted: 17:53 - 16 Jan 2013    Post subject: Reply with quote
but if its only turning over slowly so that wouldn't make it spark enough to fire it up
PostPosted: 18:04 - 16 Jan 2013    Post subject: Reply with quote
If it turns too slow either your battery is toast or you have rebuilt something incorrectly Thumbs Down
Charge the battery
arronb
PostPosted: 18:06 - 16 Jan 2013    Post subject: Reply with quote
ive charged the battery, could it be my starter motor? it could of weakened by pushing it with pressure quite a lot? plus with a new battery?
PostPosted: 18:08 - 16 Jan 2013    Post subject: Reply with quote
Take it off and see if it spins faster Thumbs Up
PostPosted: 18:19 - 16 Jan 2013    Post subject: Reply with quote
You said you used a booster have you actually charged the battery up?
Leave it on charge over night then get a multimeter reading of the battery it should be 12.5v+
Have you tried bumping it? my mates Mito was ridiculously easy to bump.
arronb
PostPosted: 18:28 - 16 Jan 2013    Post subject: Reply with quote
the battery is fully charged mate and ive tried turning the flywheel and its quite tight to turn, and I cant bump it as its thick snow :/
PostPosted: 18:29 - 16 Jan 2013    Post subject: Reply with quote
You sure you built it correctly? Set the correct squish etc? What base gasket did you use?
spaz
PostPosted: 18:34 - 16 Jan 2013    Post subject: Reply with quote
Did you fit new crank seals?
If so, it sounds like you've fitted them so they are butting up against the main bearings. There needs to be a clearance between the seals and the main bearing otherwise it will inhibit the free rotation of the crank shaft.
"If it's got tits or an engine, it'll be trouble"
arronb
PostPosted: 18:52 - 16 Jan 2013    Post subject: Reply with quote
Yeah im sure i built itpropperly and i bought a full gasket kit of ebay for 28 quid& yeah i fitted new seals
PostPosted: 18:54 - 16 Jan 2013    Post subject: Reply with quote
A full gasket kit should give you various base gaskets.
spaz
PostPosted: 19:38 - 16 Jan 2013    Post subject: Reply with quote
Well in that case it sounds like a strip and rebuild is in order.
Robby
Dirty Old Man
PostPosted: 20:04 - 16 Jan 2013    Post subject: Reply with quote
I assume the bearings are pressed into the cases, the crank is fitted, then the whole lot gets bolted up.
The usual trick I've heard of when assembling 2-strokes like this is to give the end of the crank a knock with a hide mallet before bolting it all up, to seat the bearings. Otherwise you get tightness from poorly seated bearings.
arronb
PostPosted: 21:04 - 16 Jan 2013    Post subject: Reply with quote
It roatates nice and freely without my barrel on, only when ive got my topend on it gets tight, does that mean the conrod could be bent?
PostPosted: 21:05 - 16 Jan 2013    Post subject: Reply with quote
You done a full strip/rebuilt and not bought the conrod?
What was the reason for the strip?
arronb
PostPosted: 21:10 - 16 Jan 2013    Post subject: Reply with quote
I fitted a crank but wasnt brand new, the guy said was in good condition but looks like it cant be
arronb
spaz
PostPosted: 08:10 - 17 Jan 2013    Post subject: Reply with quote
Is the piston installed the correct way round?
If not, the piston rings could be fouling the exhaust port. Or, the piston skirt could be fouling the conrod.
What about the rings? Are they installed the correct way up?
bikersupermot...
PostPosted: 18:51 - 18 Jan 2013    Post subject: Reply with quote
When you fitted the crank to the conrod did it move easily on its big end bearing?
If the conrod spins ok then your problem lies either with the conrod big or small end bearing or the piston not sliding freely up and down in the cylinder. I'd take the head off and check where it's binding in one or more of these places.
Let us know how u get on.
tinybikes
andy_uk
PostPosted: 20:53 - 18 Jan 2013    Post subject: Reply with quote
Pull the top end off again.
Did you get the right piston size? How easy did it slide out?
Make sure the crank still rotates freely.
Assuming everything's okay so far, gently push and pull the conrod to make sure there isn't any play in it.
arronb
PostPosted: 08:53 - 20 Jan 2013    Post subject: Reply with quote
the piston is the same one as its not got any damage from when I overheated it and I got told by fitted an new engine casing wont work cause it wont line up properly? apparently it has to be a matching pair of casings otherwise the crank will tighten up?, the casing I bought is for thr rotax 122 engine etc but the guy said it don't matter? any ideas,
cheers for the help guys
The last post was made 13 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 120.5 Kb
