A serious WTF? Or just bad timing?
Wise1
PostPosted: 21:13 - 16 Jan 2013    Post subject: A serious WTF? Or just bad timing? Reply with quote
Ok, so don't laugh but this has got me really puzzled.
GSF1250 2007 plate.
Use it to work Mon - Fri, nothing else. 12 miles a day.
Every morning it starts fine. Every night it starts fine.
However! Every now and then when I fill the tank up It won't start at the petrol station. I say every now and then, thats 4 times now. But only seems to happen when I fill the tank right up than my usual "that will do" approach.
Anyway, happened again tonight. Left work, all fine, drove 6 miles home via the petrol station, filled up. Won't start...
It's like flat battery syndrome. Try to start it and tries to turn once or twice but dies quickly. I could only get it to start with a jump.
Went out a couple of times since and it starts fine, no issue at all.
I have the battery charger on it now just in case but that's 4 times now this has happened after filling up, not every time it seems random. Never does it at any other time. Even the guy in the garage came out and said "Again! It's not my petrol" Smile
So, bad timing and it is the battery or something else. I am really thinking it's just the battery but then Confused
Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600
instigator
PostPosted: 21:40 - 16 Jan 2013    Post subject: Reply with quote
Sounds like your rectifier is on it's way out and it's taking your battery with it. I come to that conclusion because it seems to be happening when you restart the engine after a few minutes which would indicate low battery voltage.
Check battery voltage with multimeter. Or when you get to work, turn bike off, leave a minute or two and try and restart it.
Wise1
PostPosted: 22:24 - 16 Jan 2013    Post subject: Reply with quote
Could be.
When I put a meter on the battery it sits just over 12v, with ignition on its just under 12v and running it's near 14v.
Had it out for 5 mins there, let it sit for a few mins and starts no problem. But then the charger has been on it.
Robby
Dirty Old Man
PostPosted: 22:39 - 16 Jan 2013    Post subject: Reply with quote
I've had the same at a local petrol station with bikes with immobilisers. Not sure if it's something to do with the television transmitter next to it, or the electronic gear at the petrol station, but my immobiliser didn't like it.
The Artist
PostPosted: 22:47 - 16 Jan 2013    Post subject: Reply with quote
I would say this is a problem with hot starting. When were the valve clearances last done?
Wise1
PostPosted: 22:54 - 16 Jan 2013    Post subject: Reply with quote
Valves have never been done, it's got 13,800 miles on it right now so I suppose they could be needing done.
But nah, valves would not mean I could not turn it over and need a jump start from car.
But there are plenty times I stop on my way home at a shop for example and it never does this.
Shocked
The Artist
PostPosted: 23:22 - 16 Jan 2013    Post subject: Reply with quote
Shocked
Ahh, I read jump as bump. Smile
Weird.
Wise1
PostPosted: 23:26 - 16 Jan 2013    Post subject: Reply with quote
Yup. Even when I put the jump leads on it was just 1 touch of the starter and that was it, back to life...
The Artist
PostPosted: 23:44 - 16 Jan 2013    Post subject: Reply with quote
Loose connection somewhere maybe? Just strange it happened at the same place each time.
ricklincs45
PostPosted: 11:01 - 17 Jan 2013    Post subject: Try this? Reply with quote
Just out of curiosity, have you tried using a different fuel station when you fill up? What Robby mentioned about electronic equipment interference rings a vague bell from years ago. Would be interesting to know if the same thing happens at a different location.
If the bike is refusing to turn over, that would point to a power/voltage drain somewhere, whereas it turning over and over without starting would normally point to fuel or mechanical issues.
Rick
Author '80 Bikes, and counting...' Currently getting frustrated with an MZ 125 TS.
ricklincs45
Rick
dougon2wheels
PostPosted: 11:24 - 17 Jan 2013    Post subject: Reply with quote
Had exactly the same many years ago on my cbx750, then later on my zx6, starting from cold.....fine, run for 10 mins, stop for 5 mins and then it wouldn't start again, eventually got to the bottom of it, it was a duff cell in the battery,it had enough current behind it when it was cold, but once its had a bit of current going into it, the cell buckles, making it unable to supply the extra current required to start an engine......probably worth having a heavy current test done on the battery.....or a new battery if your feeling flush
dougon2wheels
PostPosted: 11:25 - 17 Jan 2013    Post subject: Reply with quote
LordShaftesbu...
PostPosted: 11:31 - 17 Jan 2013    Post subject: Reply with quote
12V is a bit low for the battery no?
Alpha-9
PostPosted: 12:49 - 17 Jan 2013    Post subject: Reply with quote
12v is a bit low for a 12v battery? Confused
Fzr-600 1999
dodgydog
PostPosted: 13:18 - 17 Jan 2013    Post subject: Reply with quote
Yep, it ought to be at 12.6 to 12.8 at rest.
12v is only about 20% charged
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
Islander
PostPosted: 13:29 - 17 Jan 2013    Post subject: Reply with quote
Wise1 wrote:
Could be.
Sounds like your battery may be on the way out.
Wise1
PostPosted: 15:10 - 17 Jan 2013    Post subject: Reply with quote
Let me be specific then with the voltages.
Off - 12.57v
Ignition on - 11.91v
Running - 13.9v - 14.3v
That does not seem unreasonable to me.
Wise1
PostPosted: 19:17 - 02 Apr 2013    Post subject: Update Reply with quote
I just got around to the bike again and found out what was causing this whole episode.
I will let the pictures speak for themselves Rolling Eyes
LordShaftesbu...
PostPosted: 20:28 - 02 Apr 2013    Post subject: Reply with quote
Looks like something's broken! But what is it?
The Artist
PostPosted: 20:38 - 02 Apr 2013    Post subject: Reply with quote
Magnets Bitch!
Looks fucked.
DrDonnyBrago
PostPosted: 20:51 - 02 Apr 2013    Post subject: Reply with quote
It appears to be a somewhat fucked starter motor.
Wise1
PostPosted: 20:58 - 02 Apr 2013    Post subject: Reply with quote
Indeed. It is a fucked starter motor, clearly the magnets were moving about to mostly start the bike, but sometimes not.
Anyone got any idea where I can get a new one or decent 2nd hand. Struggling to find anything on the net.
DrDonnyBrago
PostPosted: 21:20 - 02 Apr 2013    Post subject: Reply with quote
The part number you want is 31100-18H00 - seems to be used from 2007-11.
Phone this guy?
https://www.ebay.co.uk/itm/SUZUKI-GSF-GSF1250-1250-BANDIT-BREAKING-ALL-PARTS-AVAILABLE-2010-/121076849909?pt=UK_Motorcycle_Parts&hash=item1c30be1cf5
The last post was made 13 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 123.54 Kb
