| RideLimousin |
 RideLimousin Scooby Slapper
| el_oso |
 el_oso World Chat Champion
| Frost |
 Frost World Chat Champion
| RideLimousin |
| RideLimousin |
| el_oso |
| barrkel |
 barrkel World Chat Champion
 Posted: 01:50 - 16 Jan 2013 Post subject: |
| Frost wrote: | When using photoshop, it has to be loaded from disc into ram, that ram is also read and written to shit loads in processing. So i'd say 4GB of quick ram is going to be much better than 8GB of normal. |
Strongly disagree. RAM speed has only ever had single-digit percentage effects on task-based benchmarks I've seen, and those are ones that stress memory in particular, like compression - most don't.
At best, fast RAM might be 33% faster than slow RAM. But most of the latency of RAM is hidden by CPU cache effects (and programs are written with awareness of this, optimizing for it), while not having enough RAM to fit the entire job means swapping to and from disk, and RAM is 100,000x faster than mechanical disk. A machine without enough RAM for its tasks is almost indistinguishable from a crashed machine.
The machine I'm typing this on has 24G of RAM, but it ought, for optimal memory speed, have matched memory on dual channels. But one of my four 8G modules had a memory error, and I left it out. So I'm not getting full memory speed, but no way would I go down to 16G to get that back. I run jobs that use most of that memory, with lower memory they'd take twice as long because I wouldn't be able to run them all in parallel.
You need enough RAM for your biggest jobs, and RAM can add up quickly in Photoshop when you have multiple raster layers on a high-resolution document. Every 8-bit channel needs width*height bytes, and standard full colour layers with transparency need 4 channels each, for RGB and Alpha transparency. A 21MP photo with 8 bits per channel will take approximately 63MB in memory in a single layer; every full-colour layer you add, if it has transparency, is 84MB. Using lots of layers adds flexibility in editing. It's technically possible to optimize memory usage for layers that only have small areas of actual non-transparent content, but I don't know how far Photoshop goes with that.
Of course, to use >4G of memory in Photoshop, you'll need to be running 64-bit Photoshop on a 64-bit version of Windows.
Video editing will benefit much more from multiple cores than from extra memory; it's heavily CPU dependent. Generally only a handful of frames are processed at a time in batch jobs, so memory requirements aren't large there, but non-linear editors may make assumptions about being run on a beefy workstation and require lots of RAM. I suspect an SSD would be a big help, possibly a bigger help than lots of RAM. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| RideLimousin |
 Posted: 12:57 - 16 Jan 2013 Post subject: |
Hi Barrkel,
From the link I sent does that look like a good deal for what I want it for? is the Bulldozer CPU going to be an issue compared to an Intel with 4 "proper" cores?
And can you recommend a hard drive that is compatible with that motherboard (sata 2) thats not too expensive?
Thanks. ____________________ Motorcycle Touring Holidays in France: Ridelimousin
See my ridelimousin renovation blog: https://ridelimousin.blogspot.fr
See my renovation thread: https://www.bikechatforums.com/viewtopic.php?t=244340 |
| barrkel |
 Posted: 23:52 - 16 Jan 2013 Post subject: |
| RideLimousin wrote: | From the link I sent does that look like a good deal for what I want it for? is the Bulldozer CPU going to be an issue compared to an Intel with 4 "proper" cores? |
Hmmm. When I upgrade every ~18 months, I generally buy 90..95th percentile performance components, so I'm probably not the best person to to give advice on strongly budget-constrained decisions. I willingly spend 10x to get 2x better performance. It'll take a lot of reading and comparing benchmarks that are relevant to your tasks.
The 2G -> 8G jump should make a substantial difference just about everywhere. For video encoding, you'd get a substantial improvement (almost 2x) from 4 Intel cores vs AMD cores - see Handbrake benchmarks like https://www.legitreviews.com/article/1766/7/ .
The price is OK, but similarly priced components can be put together off of ebuyer.com or scan.co.uk without too much difficulty. It's not an outstanding deal, it's competitive, especially as it's tested and preassembled, for people who worry about such things. It wouldn't put me off trying to put together my own system.
Video work is heavily CPU dependent, in your shoes I'd spend extra on a quad-core Intel CPU - encoding time should be more or less halved. But it will cost extra.
For HDD, I'd buy as decently sized 7.2K RPM (i.e. non-green) drive as you can afford. Video is bulky. Any recent HDD will be at least SATA 2.
Consider a backup subscription, if you don't already have one. I use CrashPlan. Bigger HDDs mean more lost when they fail, and they all fail eventually. I own ~15 HDDs in various machines, and see one fail about every 9 months. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| el_oso |
| barrkel |
 Posted: 02:28 - 17 Jan 2013 Post subject: |
| the_godfather wrote: | While a backup solution is advisable. I've never had a hard drive fail catastrophically. I've only ever had two fail in around 10years. |
I've had maybe 7 of 50+ drives fail in 17 odd years. I own more drives (19, not including laptops or unopened spares) now than at any other time, in part because I put a bunch in a Solaris box with zfs raidz for data redundancy. I have a stack of exact match spares for replacement, and I've used two in the past 18 months, but zero data loss because of zfs.
I used to be a computer hardware technician before I became a software engineer. People would come in with dead drives several times a week. I've seen a lot of tears shed over lack of backups; PhD students with years of work lost.
But it's the stuff I lost myself, personally, that hurts more. Once a drive starts clicking, it's 50:50 whether you get it all back. Failure mode is typically pauses on reads as the OS and drive continually retry; it can take hours to get the good bits back and not get bogged down in the bad bits. I've seen drives with high-pitched whining noises, pinging noises, those were dead losses.
Depends on how valuable the data is. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
The last post was made 13 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
