TV probs.
MCW
PostPosted: 19:08 - 18 Jan 2013    Post subject: TV probs. Reply with quote
What does it mean when your TV (not flat screen) develops an interesting arc of green red and blue that nearly fills the screen but doesn't stop you seeing the picture??
Bikeless
PostPosted: 19:34 - 18 Jan 2013    Post subject: Reply with quote
Have you put anything magnetic near the screen?
MCW
PostPosted: 19:37 - 18 Jan 2013    Post subject: Reply with quote
Only my personality...
andy_uk
PostPosted: 19:42 - 18 Jan 2013    Post subject: Reply with quote
^^^This.
Any loudspeakers been put near it?
MCW
PostPosted: 19:44 - 18 Jan 2013    Post subject: Reply with quote
andy_uk wrote:
^^^This.
No. nothing. It's in the corner of a teeny sitting room that has a sofa, an armchair and a bookcase in it. Oh, and my tea, which is sausages and mash and a cuppa.
swampy
PostPosted: 19:46 - 18 Jan 2013    Post subject: Re: TV probs. Reply with quote
It generally means your tv is fucked... Wink
MCW
PostPosted: 19:48 - 18 Jan 2013    Post subject: Re: TV probs. Reply with quote
God. even my tv gets more action than I do... Sad
swampy
PostPosted: 19:54 - 18 Jan 2013    Post subject: Re: TV probs. Reply with quote
MCW wrote:
God. even my tv gets more action than I do...(
Welcome to my world sister..
Bikeless
PostPosted: 20:04 - 18 Jan 2013    Post subject: Reply with quote
Sounds knackered,before you bin it,try running a magnet around the sides of the TV where the screen is,a decent fridge magnet might work.I done this on an old tube TV when I had a RGB mark in one of the corners and it cleared it.
jeddy11
PostPosted: 20:08 - 18 Jan 2013    Post subject: Reply with quote
Scart lead hanging out ? make sure all plugs secure..
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
raak
PostPosted: 20:47 - 18 Jan 2013    Post subject: Re: TV probs. Reply with quote
all the others points, decent comments,
and on the simple method..
.if you haven't, try unplugging it it from the mains for a few minutes..then plug it back in.
ours will drop the colour and look shit if the power surges or the electric goes off.
only thing that fixes it, is an uplug for 30 seconds.. Thumbs Up
Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900
andyscooter
PostPosted: 09:13 - 19 Jan 2013    Post subject: Reply with quote
normally is a sign the cathode ray tube (sp) is on the way out
the crt is were the picture comes from and starts to go green before stopping working all together
or it did with our old tele and the one before
also has anyone been playing video games on it espally football games
Hetzer
PostPosted: 10:20 - 19 Jan 2013    Post subject: Reply with quote
It's the electron-gun dying or out of alignment. I was told they can be re-aligned but it'll probably cost more to do than buying a new flatscreen.
Flatbadger
PostPosted: 11:50 - 19 Jan 2013    Post subject: Reply with quote
A TV which only shows Rainbow - what's the problem?
You're in ISIS
mistergixer
When you power on a CRT TV, a process called 'degaussing' occurs, this effectively 'wipes' the screen clean using a magnet. Whenever you power on the TV, that thumpy hum noise (technical term) is the degaussing circuit doing its job.
If the degaussing circuit fails, it can cause problems like the one you describe. If you happen to know a friendly TV repairman, he should have a 'degaussing wand' (basically a big electromagnet) which he could use to wipe the screen*.
If you look through the menu on the TV, there might be an option to manually degauss, give that a try.
*Much fun can be had with a degaussing wand, there's a great scene in 'Fight Club' where they wipe all the videos in a video rental store with a degaussing wand.
Space Monkey #7
CaNsA
PostPosted: 13:27 - 19 Jan 2013    Post subject: Reply with quote
A fairly strong magnet will do the trick n all, if you know how to do it.
Islander
PostPosted: 18:22 - 19 Jan 2013    Post subject: Reply with quote
No it won't. If it's a CRT then it may distort or magnetise the shadowmask and cause more problems. I've seen this tried by engineers and it's never worked.
A degaussing coil provides a decaying alternating magnetic field - your set, if it's CRT based, has one built in. Switch it off, let it cool down (the current to the coils is controlled by a thermistor which heats up and reduces the current to zero - it has to be cool to work properly) and then switch it back on. It might take a couple of goes.
MCW
PostPosted: 19:53 - 19 Jan 2013    Post subject: Reply with quote
Thanks everyone. I have tried all the suggestions I understood, with no change to the 'rainbow'.
Unitynotso, I may be worth it, but my net worth is about £2.50 until I get paid at the end of feb, so a new tv is not an option.
Islander wrote:
Something in Serbo-Klingon.
Islander, sweetheart. Am grateful for your input, but it was too much for my pretty little head to take in. When I make it up to the Orkneys, please address me in English,with words of no more than 2 syllables, preferably to do with kittens....
Islander
PostPosted: 20:11 - 19 Jan 2013    Post subject: Reply with quote
Switch T-V off. Wait 5-10 min-utes. Switch T-V on. See if pat-tern gone. Wink
Oh and fluffy kittens. Laughing
cimbian
PostPosted: 20:16 - 19 Jan 2013    Post subject: Reply with quote
With a CRT electrons are fired onto the phosphorous material on the inside of the screen. Every now and then you need to open the little hatch and sweep-out all the electrons that build-up there. Wink
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
MCW
PostPosted: 20:18 - 19 Jan 2013    Post subject: Reply with quote
https://www.youtube.com/watch?v=SjxY9rZwNGU
Islander
PostPosted: 20:38 - 19 Jan 2013    Post subject: Reply with quote
I manfully resisted the temptation to link that. Laughing
ScaredyCat
PostPosted: 20:43 - 19 Jan 2013    Post subject: Reply with quote
In this week's episode, Zippy is a cunt and also performs a flounce.
https://www.youtube.com/watch?v=M62SnbNizIM
Andy
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
MCW
PostPosted: 20:50 - 19 Jan 2013    Post subject: Reply with quote
Andy
Zippy is my role model...
The last post was made 13 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 129.2 Kb
