Thought I'd have a go at spraying my lid LOL
iMark
PostPosted: 16:55 - 19 Jan 2013    Post subject: Thought I'd have a go at spraying my lid LOL Reply with quote
https://imgur.com/a/iQVWr
This is how it looked previously, but a bit more battered with paint chips etc haha
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash4/306289_10151408213795075_1852601099_n.jpg
K8 GSXR 1000
mysterious_rider
PostPosted: 16:56 - 19 Jan 2013    Post subject: Reply with quote
Whats with all the grit?
If you want a great lacquer that also happens to be petrol resistant, buy some 2k clearcoat (its a duel compound and its pretty awesome)
KAWASAKIIIII
Ichy
PostPosted: 16:58 - 19 Jan 2013    Post subject: Reply with quote
Just be aware that some paints can cause plastic to weaken. You'll find out if there was a problem when you bounce it off the floor.
iMark
Just a cheap aerosol can... plus the temperature outside probably didn't help .. No idea other than that, there is next to no wind etc.
Yeah I heard that a few times before Razz But the helmet is pretty battered with paint chips etc so rather than just scrapping it, Paint it and see if that works.... if it breaks with some pressure applied I know not to use it Wink
K8 GSXR 1000
Ichy
PostPosted: 17:00 - 19 Jan 2013    Post subject: Reply with quote
Hard to say from the photo but it may be moisture or oil contamination.
iMark
PostPosted: 17:03 - 19 Jan 2013    Post subject: Reply with quote
Possibly moisture from the atmosphere then, I rubbed the helmet down after sanding the clear coat off the top of the plastic and left it for a few days to make sure that it didn't knacker the plastic with the cleaner I used
K8 GSXR 1000
BigDan1190
PostPosted: 17:12 - 19 Jan 2013    Post subject: Reply with quote
Yeah, thats a pretty good way of testing if a helmet will still save your head at 70mph.
Why didn't I think of that?!
mysterious_rider
PostPosted: 17:20 - 19 Jan 2013    Post subject: Reply with quote
Tell you what, I sprayed my zzr outside, in 6 degree temperature, a week before the snow set in. Here's how it looked.
https://i270.photobucket.com/albums/jj88/mysterious_rider/DSCF0019-4.jpg
You gotta do the most to keep it grit free, I went by the side of my house down the driveway and I was okay. Granted, rain ruined my lacquer the first time round, So second time I covered it after 3 hrs of touch dry, covered it for four days, then I sat it in a shed with fan heater at 20deg for 12 hours.
KAWASAKIIIII
DMCpro
PostPosted: 02:34 - 20 Jan 2013    Post subject: Reply with quote
Paint looks very low quality how long did the prep take?
Honda CB-1, TS125X
VW Golf Estate
iMark
PostPosted: 03:07 - 20 Jan 2013    Post subject: Reply with quote
took about an hour to sand off the lacquer... then another 5 mins to rub it down and left it for a few days.
Took a while to mask off the vents and the bottom skirt..thing but still managed to miss a few bits due to the aerosol not spraying properly while aiming it upwards, I wasn't expecting a perfect quality finish and I don't particularly care that it isn't perfect Razz
The speckles aren't that noticeable the camera flash make them stand out a bit more... You can notice it in natural light but not as much.
Only managed to give it 2 coats from the rattle can I got, if I had more paint and some fine sand paper I could do a much better job...
This was more of an experiment to check if the helmet would accept being painted with the cheap spraypaint from Poundland.
It seems to have dried now and the plastic doesn't seem to have gone brittle, gave it a bit of a squeeze and a knock here and there with my hand... No cracking... Seems like it will be safe to use
K8 GSXR 1000
jay81
PostPosted: 19:31 - 20 Jan 2013    Post subject: Reply with quote
You must be mad to use that after you have sprayed solvent over it, you have no idea how its affected the structure of the material.
I had the cab driver drive me here backwards, he owes me ?27.50.
KTM 625 SMC
mysterious_rider
PostPosted: 19:39 - 20 Jan 2013    Post subject: Reply with quote
As long as it's gone over the original paint i don't think it'll make a difference.
KAWASAKIIIII
yaigi
PostPosted: 19:45 - 20 Jan 2013    Post subject: Reply with quote
If you used paint from poundland then I will 100% guarantee you it will come off. I got some poundland paint to paint some poundland guns for a fancy dress outfit. The paint didn't last 5 mins so I went out and spent £3.50 on a very small tin of fairly decent spray paint. Even that came off eventually.
mysterious_rider
PostPosted: 19:48 - 20 Jan 2013    Post subject: Reply with quote
Best stuff I've used so far is hycote. (£5.20 a can)
And that lacquer is 2K clearcoat, I can scratch as hard as i want on my newly painted lid and It will not mark it. Smile
KAWASAKIIIII
jay81
PostPosted: 19:57 - 20 Jan 2013    Post subject: Reply with quote
It’s not normally the quality of the paint that makes it flake it the poor prep work that goes into it.
KTM 625 SMC
iMark
PostPosted: 22:02 - 20 Jan 2013    Post subject: Reply with quote
Well I used the lid today in .. pretty cold weather and tonight in even colder weather where moisture just saps onto everything from the air.
No cracking or chips.. Helmet still seem structurally sound.
Considering the helmet is basically 3 layers, the outershell is just plastic with an airgap being the second layer between that and the protective layer.
I see no negative effects from painting it... so as far as I'm concerned it's safe enough to use Rolling Eyes
K8 GSXR 1000
SQL
PostPosted: 01:57 - 22 Jan 2013    Post subject: Reply with quote
God I can smell Hycote at ~1000 paces
Lovely Smell.
https://i.ebayimg.com/00/s/NDM2WDUwMA==/$(KGrHqN,!icFB)eozsToBQhW3Eb1u!~~60_35.JPG
These types ^
The last post was made 13 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 95.27 Kb
