Honda CG 2004- whats the largest rear tyre size ?
i2ico
PostPosted: 20:38 - 19 Jan 2013    Post subject: Honda CG 2004- whats the largest rear tyre size ? Reply with quote
Hi everyone, Very Happy
Ive been looking into purchasing a larger rear tyre for my Honda CG 2004, and looking for advice from any other people who have had experience with this or the knowledge.
Manufactor states tyre size: 90/90 x 18
Ive looked on this forum and found the rear rim is: - 1.85 x 18
Im not looking to go crazy, just abit more meat on the tyre, both for cosmetic and a bit more grip.
How big can I go?
Thanks in advance!
2ico
Very Happy Limitations are only what you make of them.
Current: ER5, Stolen/Recovered:Honda CG
neil.
PostPosted: 21:22 - 19 Jan 2013    Post subject: Reply with quote
Stick with the standard sizes, but go for Michelin Pilot Sporty tyres. Larger tyres will probably reduce your speed and affect handling in a bad way on a CG.
blurredman
PostPosted: 21:25 - 19 Jan 2013    Post subject: Reply with quote
I had a 4" on the rear of my cg. But it only just fit, and when I say that, I meant it did rub the subframe as was literally 2mm from the brake torque arm. So I'd suggest 3.5".
Saying that though, the better tyres for that size rim seem to be in the 3" range.
DMCpro
PostPosted: 22:21 - 19 Jan 2013    Post subject: Reply with quote
I've got a 110/90-18 on the back I had to make spacers for the rear brake torque arm Though it feels much more stable now
Honda CB-1, TS125X
VW Golf Estate
ricklincs45
PostPosted: 10:22 - 20 Jan 2013    Post subject: Reply with quote
Stick with the standard size - it's that size for a reason.
Buy the best quality rubber you can afford and run at recommended pressure; you'll achieve nothing other than messing up the handling by fitting a bigger tyre.
Author '80 Bikes, and counting...' Currently getting frustrated with an MZ 125 TS.
DMCpro
PostPosted: 13:23 - 20 Jan 2013    Post subject: Reply with quote
Not true. My cg 125 has been much more stable now I've put a fatter rear tyre on
Honda CB-1, TS125X
VW Golf Estate
ricklincs45
PostPosted: 14:13 - 20 Jan 2013    Post subject: Reply with quote
Personal opinion - I'm fairly sure Honda knew what they were doing when they spec'd tyre size.
i2ico
PostPosted: 16:27 - 20 Jan 2013    Post subject: Reply with quote
Great, thanks, info taken!
Ill go for the 90/90 -18 M/C 57P reinf. Pirelli City Demon
As the front is same model.
Am i right that 90/90 is 3.00 in metric? or close too.
Yeah my rear wheel had a new tyre put on by dealership,"vee rubber" some thai cheap tyres (VRM015-2.75), feels skittish in wet, and doesnt give me confidence in the corners.
DMCpro
PostPosted: 16:59 - 20 Jan 2013    Post subject: Reply with quote
3.00-18 continental conti is a good tyre aswell had these before
And it's roughly the same
Honda CB-1, TS125X
VW Golf Estate
Walloper
PostPosted: 18:24 - 20 Jan 2013    Post subject: Reply with quote
Std fit. Michelin Sporty are all you need. Tunz of grip and live for years.
You can't get enuf power down to the tyres to damage them much. Smile
I put them on our CG and it goes like fuck now. Smile
neil.
PostPosted: 18:30 - 20 Jan 2013    Post subject: Reply with quote
Pilot Sportys are MUCH better than City Demons! Amazing tyres.
Pigeon
PostPosted: 18:40 - 20 Jan 2013    Post subject: Reply with quote
I recently fitted 90/90-18 Metzeler ME22, loads of grip from day 1. The only question mark might be how soft the rubber appears to be. They quote a life of only around 4,000miles and MAY be more prone to puncture, but this is just guesswork compared to the concrete that they replaced.
But so much grip and £32 from moto-tyres.co.uk
Pilot Sporty get good reviews everywhere also.
i2ico
PostPosted: 21:46 - 20 Jan 2013    Post subject: Reply with quote
Thanks again guys lol
Your absolutely right haha, got to be the Pilot Sportys!
Even the "Honda CG125 Owners Club" recommended these tyres.
Plus only £4 difference in price compared to Pirelli demons.
PostPosted: 22:01 - 20 Jan 2013    Post subject: Reply with quote
No reason for it to be any more stable. Just in your head Thumbs Up
i2ico
PostPosted: 19:08 - 22 Jan 2013    Post subject: Chain jerk Reply with quote
While I got some good technical minded people here, before I start a new post lol.
My rear chain seems to be jerking?
Please see video:
https://youtu.be/Nr4eml8yo_E
Is this normal..
Could it be a stiff link?
Rear wheel alignment?
Sprockets?
Alpha-9
PostPosted: 19:16 - 22 Jan 2013    Post subject: Reply with quote
Slack chain, bent subframe
Stretched probably.
I'd change chain and sprockets if they're fucked Thumbs Up
Tighten the slack to spec first if you haven't...doesn't look like it
Fzr-600 1999
ricklincs45
PostPosted: 20:10 - 22 Jan 2013    Post subject: Reply with quote
Agree with Alpha, looks like chain is banjaxed. Make sure you change chain and sprockets together - no point putting a new chain on worn sprockets; old sprockets will knacker a new chain.
If your bike is more than four years old, I'd change the rear wheel cush drive rubbers while it's all apart; those rubbers help take some of the shock out of the transmission and help make chain and sprockets last a bit longer.
Good idea to have a look at rear brake shoe wear/condition too while it's all apart - and to lube the pivot pin that goes through the rear brake plate - they have a tendency to seize-up over time. Thumbs Up
kramdra
PostPosted: 22:10 - 22 Jan 2013    Post subject: Reply with quote
No the video looks perfect, thats what single cylinder bikes do. Mine does it far worse, and that was with a correctly set, lubed, brand new chain and sprockets.
Without some revs to make it smoother, the chain jerk would stall bike at idle and looks a lot more violent than yours.
Tire size... just get a good brand. my 125 has 110 front and 140 rear, and cheap tires are just as bad.
i2ico
PostPosted: 13:56 - 23 Jan 2013    Post subject: Reply with quote
Awesome, thanks kramdra,
Yeah my does get abit violent sometimes haha, when on the stand it rocks.
Will check the sprocket and chain tension as well in case!
What 125 do you have?
PostPosted: 14:54 - 23 Jan 2013    Post subject: Reply with quote
I expect that is down to the fact that you've put new aftermarket rubber on rather than the size of the tyre. A new tyre will always feel better than an old one, especially an old Thai OEM tyre made of bakelite.
i2ico
PostPosted: 16:02 - 12 Mar 2013    Post subject: Speed rating j Reply with quote
Update, Just checked the Vee rubber the dealership put on, speed rating "J" Shocked Embarassed Sick
62 MPH!!!
I've been doing 70+ MPH
Any give on these ratings or is it strictly abide by these rules lol
Going to wait till summer, if it ever comes to change tyres Cool
Alpha-9
PostPosted: 16:05 - 12 Mar 2013    Post subject: Reply with quote
lol max speed for rubbers?
First i've heard of that, weird Laughing
As for the jerky chain, it will be more jerky with no load also, it's when you ride it counts
Fzr-600 1999
PostPosted: 16:53 - 12 Mar 2013    Post subject: Reply with quote
Duh, all tyres are speed rated. Z rated is 150mph+ They now do Z+ rated tyres up to 200mph.
xz130
PostPosted: 18:18 - 13 Mar 2013    Post subject: Reply with quote
Stick with the standard size tyres but get Michelin pilot sportys, that what I'm running on my 07” cg and it has so much more grip than the rubbish Pirelli city demons
i2ico
PostPosted: 19:26 - 14 Mar 2013    Post subject: Reply with quote
Thanks,
What size Michelin sportys your running 90/90?
I also found that, for example my pirelli city demon, the fr tyre is 2.75 from the inner wall and expands to 3.00 to the outer wall.
So there is no true tyre measurement.!?!?!? Evil or Very Mad
So xz130 do you know the true size of your sportys outer tyre?
The last post was made 13 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 132.07 Kb
