6th cruising gear (Suzuki Idea)
kawashima
PostPosted: 16:47 - 20 Jan 2013    Post subject: 6th cruising gear (Suzuki Idea) Reply with quote
I recently noticed that CB1300 has only 5 gears and revs about 3400rpm at 100km/h(60mph). While GSX1250FA has 6 gears and 3200rpm, GSX1400 has 6 gears and 2900rpm.
I read Big naked has 5 gears with wide ratio to reduce gear changes. And GSX1400 is 5 wide gear + 6th cruising gear.
I often read CB1300 owners wanting 6th gear(or make 5th more higher) cause it revs too high(3400rpm) for its enough torque.
If I think of going for over litre naked/tourer, I will go for Suzuki only for high 6th gear. I like the Idea of 6 gears with wide ratio for big bike.
Cause even on Big naked/tourer, I want better MPG, and its stressful while cruising with unnecessary high revs.
p.s. TDM900 has close 6 gears and 3500rpm.
Do you like this Idea of Suzuki?
own:2020 Serow 250
Maruchino
PostPosted: 16:54 - 20 Jan 2013    Post subject: Reply with quote
One of the main reasons I got my GSX1250FA was to get effortless drive in 6th gear. I'm not sure 200, or even 500rpm will make a huge amount of difference though really.
I don't know a huge amount about it, but I'd guess there were more factors than just gear ratio on what makes a good 'cruising' speed/bike. In reality the GSX1250FA is pretty effortless in any gear - e.g. you can pull away from a standing start in 4th gear and also cruise at 60mph in 4th gear and not have any problems or issues at all. Presume torque comes into this equation at some point too?
PostPosted: 16:56 - 20 Jan 2013    Post subject: Reply with quote
From what I can think, all of my recent bikes have had 6 gears. Tiger Explorer, Street triple R, busa, Goldwing 1800. Wifeys 650 bandit and Kwac ER6 as well.
I would guess that five speed boxes are now only in older design engines or cruisers with large torque and no revs.
kawashima
PostPosted: 17:06 - 20 Jan 2013    Post subject: Reply with quote
Cool I like GSX1250FA too. It looks like a perfect all round big bike both sporty and tourer use, and also has reasonable price.
I imagine most of over litre IL4 bikes of this genre have sufficient torque around 2000-3000 rpm.
own:2020 Serow 250
kawashima
PostPosted: 17:18 - 20 Jan 2013    Post subject: Reply with quote
CB, XJR are older than others. Thanks for pointing this out.
p.s.ZRX1200 DAEG(Japan only) was changed from 5 into 6 gears(ZZR1200 one). I think this is a very rare case.
own:2020 Serow 250
salty21
PostPosted: 17:19 - 20 Jan 2013    Post subject: Reply with quote
how about just buying what you like the look and feel of, then fitting a smaller rear sprocket, or larger front if there is room for it?
I'm planning to seriously 'up' gear my 600RR for this years europe trip...I was planning on getting a more suitable bike but just figured it would be easier to change the gearing and get a more comfortable seat.
Currently my bike sits at about 8000-8500rpm for ~90mph motorway speeds, which is not good for my comfort or the bikes fuel economy Laughing
PostPosted: 17:25 - 20 Jan 2013    Post subject: Re: 6th cruising gear (Suzuki Idea) Reply with quote
My KTM 690 has an overall ratio of about 2.8 I think.
That is that the top gear is 2.8 times the bottom gear. So if first gear will do 60kph, top gear will do 168kph.
Ideally I want a wide ratio gearbox, so first gear is lower and top gear is higher.
For very steep off road stuff I would like a lower first gear, but I'd also like a higher top gear for sitting on the motorway.
The Husky TE610, which is a similar bike has a ratio of 3.4 I believe.
So for the same top speed, first gear would only go to 50kph not 60kph - which would mean it would also idle slower and pull better at low speed.
Note that the BMW G650 is a similar bike which only has 5 gears not 6. Yet the BMW gear ratios between top and bottom actually fall between the KTM and the Husky - so often as you mention, it's not the number of gears but the spacing between them.
For road bikes, generally if I want higher gearing I don't mind gearing the bike higher and losing a bit in first gear, unless it's low powered. Often I will do the opposite, but then not use first gear for much - as a reasonably powerful bike downgeared will wheelie at any point in second gear anyway.
Cheeseybeaner
PostPosted: 17:28 - 20 Jan 2013    Post subject: Reply with quote
I have a ZRX1200, unfortunately the newer fuel injected version with 6 speed gearbox didnt come to the UK - with a sixth speed 'cruising gear' the bike would be lovely, always find myself looking for an extra gear just to slow things down a bit.
My 900 Diversion is exactly the same, feels as if it could happily pull another taller gear which would make it that bit more relaxed in motorways etc.
I think an overdrive top gear is a great idea for covering distances and cruising more generally.
My bikes: 2003 KAWASAKI ZRX1200R, 1996 YAMAHA DIVERSION XJ900S
kawashima
PostPosted: 17:31 - 20 Jan 2013    Post subject: Reply with quote
I think it's a nice method to change the ratio slightly Thumbs Up .
Please be careful, I attached 5 less teeth driven sprocket on my CB400SF and totally spoiled everything. 5 less teeth was too radical on 400. I think 600 is much much more powerful than 400 though.
The problem of smaller driven is higher 1st gear which makes start difficult.
own:2020 Serow 250
Richy CB1000
PostPosted: 17:53 - 20 Jan 2013    Post subject: Reply with quote
My mildy set up CB has approx 115hp 100ft lb, 80 in 5th is around 4100 revs, being a naked that's enough.
A sixth in real life wouldn't really make too much difference, the important bit, not enough for me to limit my choice of machine due to it. The motors are not buzzy at those speeds in fifth.
You just find yourself prodding for an extra change up occasionally if your on a charge but then you realise how much you're doing an are grateful it hasn't got the extra gear!
They're all about torque, that same fifth gear is just about happy at say 25mph so once moving that's it just ride.
Unless you're more into the touring where you'll probably go for a faired bike where slightly on the wrong side of the speed limits maybe entertained more, I wouldn't worry about the sixth.
https://www.youtube.com/watch?v=GqjQLu2w4t8
Just an example of a lad on a fifth gear only CB sounds quite relaxed even at 100 in fifth.
salty21
PostPosted: 17:55 - 20 Jan 2013    Post subject: Reply with quote
i agree, i dont think i would alter the gearing on my superfour either, i think they geared it as high as they could from the factory as mine runs out of power before it reaches max revs in 6th gear and will do about 110 ish at 10k rpm and go no higher. I suspect if i put a smaller rear sprocket on it would actually drop the top speed due to dropping the revs out of the power zone.
wouldnt be concerned with up gearing the CBR though as it pulls pretty well from low/mid revs for a 600 sports so shouldnt have any issues pulling away with the higher gears
kawashima
PostPosted: 17:59 - 20 Jan 2013    Post subject: Re: 6th cruising gear (Suzuki Idea) Reply with quote
G wrote:
My KTM 690 has an over ration of about 2.8 I think.
Thanks about over ration. I checked about it.
CB1000 : 2.72
CB1300 : 2.73
XJR1300 : 2.56
ZRX1200R : 2.64
ZRX1200 daeg : 2.64 (it was same with 1200R Shocked )
GSX1250 FA : 2.87
GSX1400 : 2.92
Daeg's 6 gears was for close ratio, not for cruising gear.
own:2020 Serow 250
Frost
PostPosted: 18:15 - 20 Jan 2013    Post subject: Reply with quote
The reason i got rid on my NC30 is because 80mph was 8000rpm in top gear!
135 top speed in 6th, 65ish top speed in 1st gave a ratio of 135 / 65 = 2.07 Laughing
kawashima
PostPosted: 18:28 - 20 Jan 2013    Post subject: Reply with quote
Your CB is more powerful than normal CB1300 Shocked .
I also hear some of CB owners say less shift is a good thing.
He rides his CB1000 very sporty in this video.
Selecting bike only by how many gears may be wrong idea Thumbs Up
own:2020 Serow 250
robbieguy2003
PostPosted: 19:14 - 20 Jan 2013    Post subject: Reply with quote
Hi, I've got a 1250, and the 6th gear is handy just for highway/motorway use. It will however happily pull from about 20mph in 6th and happily from 30mph.
It's very effortless to drive. I've a 600rr as well, and the power delivery is the polar opposite.
The only thing i 'dislike' about the 1250 plant is that it drops off in power deliver as it gets towards it's rev limit. But the amount of torque at the bottom is great.
It's a great commuter, good tourer - two up barely changes the handling, and it's not bad for the odd hoon, although I prefer the 600 for that.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
kawashima
PostPosted: 04:14 - 21 Jan 2013    Post subject: Reply with quote
Thanks for engine delivery of 1250. It looks like a very good touring bike for me. I prefer bottom torque and cruising so I want to try 1250 someday Thumbs Up
own:2020 Serow 250
Noxious89123
PostPosted: 04:55 - 21 Jan 2013    Post subject: Reply with quote
I think my 600 revs at about 6000rpm at 70mph Laughing
Even my car is doing over 3000rpm at motorway speeds. Close ratio 'box is a bit sucky for motorways, great everywhere else though.
PostPosted: 10:34 - 21 Jan 2013    Post subject: Re: 6th cruising gear (Suzuki Idea) Reply with quote
Sorry, that was a typo, I've now edited it.
It should just say 'overall ratio'; and that's not a specific phrase used either I'm afraid; just how I described it.
The 2006 GSXR1000 I had has an overall ratio of 2.02 as a comparison.
However it never feels lacking because it's still high geared and has plenty of power - I pulled away in fourth once fine (at a guess, fourth gear goes to about 256kph.)
TT_Man
PostPosted: 13:07 - 21 Jan 2013    Post subject: Reply with quote
Hi,
just joined BCF a few weeks ago.
Thinking of getting a GSX 1250FA, could you advise what sort of mpg your getting from it?
Thinking of using it for a 50 mile motorway commute.
Thanks
TT
Maruchino
PostPosted: 13:18 - 21 Jan 2013    Post subject: Reply with quote
Hi,
Thanks
TT
Typically it's up in the 46-48mpg range.
TT_Man
PostPosted: 13:32 - 21 Jan 2013    Post subject: Reply with quote
Thanks
thats not too bad, guess I'll have to go and test ride one!
TT
Maruchino
PostPosted: 14:29 - 21 Jan 2013    Post subject: Reply with quote
TT_Man wrote:
Thanks
TT
It's about what you can expect of a bike in this particular class. Test rode mine back to back with a Kawasaki Z1000SX and it was a no brainer for me. It doesn't do sporty all that well, but everything else is a charm.
The last post was made 13 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 129.86 Kb
